[RHL] Apache waar?
  • 40 views sinds 30-01-2008
Ik draai redhat linux en ik start apache met 'apachectl' maar nu weet ik niet waar ik de index.php enz moet in gooien.... Weer iemand waar? ik bedoel waar hij de site dan neerzet.
  • MrBarBarian
  • Laatst online: 07-03-2023
man httpd.conf
En onder RH start je apache met "service apache start"
iRacing Profiel
  • ipsec
  • Laatst online: 12-10 11:04
probeer eens /var/www
daar staan alleen paar mapjes, verder geen index.html te bekennen maar ik zie wel dit:
29
30
31
Test Page
This page is used to test the proper operation of the Apache Web server after it has been installed. If you can read this page, it means that the Apache Web server installed at this site is working properly.
If you are the administrator of this website:
You may now add content to this directory, and replace this page. Note that until you do so, people visiting your website will see this page, and not your content.
If you have upgraded from Red Hat Linux 6.2 and earlier, then you are seeing this page because the default DocumentRoot set in /etc/httpd/conf/httpd.conf has changed. Any subdirectories which existed under /home/httpd should now be moved to /var/www. Alternatively, the contents of /var/www can be moved to /home/httpd, and the configuration file can be updated accordingly.
If you are a member of the general public:
The fact that you are seeing this page indicates that the website you just visited is either experiencing problems, or is undergoing routine maintenance.
If you would like to let the administrators of this website know that you've seen this page instead of the page you expected, you should send them e-mail. In general, mail sent to the name "webmaster" and directed to the website's domain should reach the appropriate person.
For example, if you experienced problems while visiting www.example.com, you should send e-mail to "webmaster@example.com".
The Apache documentation has been included with this distribution.
For documentation and information on Red Hat Linux, please visit the Red Hat, Inc. website. The manual for Red Hat Linux is available here.
You are free to use the image below on an Apache-powered Web server. Thanks for using Apache!
You are free to use the image below on a Red Hat Linux-powered Web server. Thanks for using Red Hat Linux!
  • blaataaps
Kijk eens in de configuratie van je apache zou ik zeggen, dit soort dingen is echt basiskennis, en prima uit te vinden door wat willekeurige documentatie door te kijken.
