Verschil ? NEC ND-3520A & NEC ND-3540
  • 42 views sinds 30-01-2008
NEC ND-3520A
Access Time (CD): 120 ms
Access Time (DVD): 120 ms
Audio Connections: analog-and digital output
Dimensions (HxWxD): 148mm x 42mm x 190mm
Weight: 0.9kg
Interface: IDE/ATAPI Ultra DMA 33 mode 2
Media Supported: DVD-ROM, DVD-R, DVD+R, DVD+R9, DVD-RW, DVD+RW, CD-ROM, CD-R AND CD-RW WITH 80mm AND 120mm diameter
Cache memory: 2 Megabytes
Modes Supported: DVD Video, CD-DA, CD Extra, CD Text, CD-ROM, CD-ROM XA, CD-I, CD-I Ready, CD-Bridge, Photo-CD, CD-Audio
Read Speed:
DVD: 16x CAV (max. 22,000 Kbyte/s)
CD: 48x CAV (max. 7,200 Kbyte/s)
Write Speed:
DVD-R: 16x
DVD-RW: 6x ZCLV
DVD-R DL1: 4x
DVD+R: 16x
DVD+R9: 4x CLV
DVD+RW: 8x ZCLV
CD-R: 48x
CD-RW: 24X
Writing Methods - CD:
DAO (disc at once)
SAO (session at once)
TAO (track at once with zero gap, variable or fixed packet, multisession)
Writing Methods - DVD:
Random Access Writing (DVD+- RW)
Sequential Writing (DVD+-R/DVD+-RW)
NEC ND-3540
Transfer Rate read and write DVD +R: 16x max.
DVD-R: 16x max.
DVD +RW: 8x max.
DVD-RW: 6x max.
DVD +R9: 8x max.
DVD-R DL: 4x
CD-R: 48x max.
CD-RW: 32x max.
Access time DVD 140ms, CD 120ms
Mechanism motorized tray load mechanism for horizontal and vertical use
Interface IDE / ATAPI
Burst transfer rate PIO mode 4 / Ultra DMA 33
Cache 2 MB
Media supported DVD-ROM, DVD-R (DL approx march 2005), DVD-RW, DVD+R, DVD+RW,DVD+R9,CD-ROM, CD-R and CD-RW with 80mm and 120mm diameter
Modes supported DVD-ROM,DVD-Video,CD-DA, CD Extra,CD Text,CD-ROM,CD-ROM XA,CD-I,CD-I Ready,CD-Bridge,PhotoCD, VideoCD
Writing methods DAO, SAO,TAO with zero gap,variable or fixed packet, multisession
Compatibility MPC Level 3, MultiRead, PC2001
Dimensions 148mm x 42mm x 190mm
Kan iemand me vertellen wat het verschil is?
Want ik zie B) het niet :D :D
  • PROnline
  • Laatst online: 11:54
Onlangs kreeg de populaire NEC ND-3520 opvolging in de vorm van de ND-3540, die dual layer DVD+R-schijfjes op achtvoudige snelheid kan branden en CD-RW-discs op 32-speed. De schrijfsnelheid van de overige mediasoorten is gelijk aan de ND-3520:
reviews: Tweakers.net Best Buy Guide: editie mei 2005
Thnx
slotje aub
  • Twynn
  • Laatst online: 27-10 09:54
Met enig zoekwerk dus toch wel te vinden ;)
