BenQ keuze tussen FP91V+ en FP91E
Ik ben niet echt super op de hoogte van de details die belangrijk zijn bij de lcd's dus vraag ik jullie experst om hulp bij mijn keuze.
Model FP91V+
Product Color Silver-Black
Panel Spec * * * * * * * * * * * * * * * * * * * * *
LCD Size 19.0"
Display Area 376.3 x 301.1 (mm)
Pixel Pitch (mm) 0.294
Brightness (typ.) 400 cd/㎡
Max. Brightness 420 cd/㎡
Contrast (typ.) 450:1
Max. Contrast 600:1
Viewing Angle (L/R;U/D) (CR>=10) 140 / 140
Viewing Angle (L/R;U/D) (CR>=5) 160 / 160
Response Time(rise+fall) typ. 12 ms (6 GTG)
Display Colors 16.2 million
Monitor Spec * * * * * * * * * * * * * * * * * * * * *
Resolution (max.) 1280 x 1024 (SXGA)
Hor. Frequency (KHz) 31-81
Ver. Frequency (Hz) 56-76
Video Bandwidth (MHZ) 25-135
Input Connector D-Sub / DVI
Power Supply Built-in (90~264 AC)
Power Consumption On mode :60W(max)
Power saving mode:1W / 115V, 2W / 230V
Color Temperature Reddish / sRGB / Bluish + user mode
OSD Language 8
i Key Yes
Kensington Yes
CTN Dimensions (HxWxD) 495 x 570 x 256 (mm)
Dimensions(HxWxD) 419.3 x 410.8 x 215.4 (mm)
Net Weight (kg) 6
Gross Weight (kg) 8.5
Special Feature * * * * * * * * * * * * * * * * * * * * *
Speaker 2W x 2
USB No
VESA Wall Mouting 100x100 (mm)
Pivot No
Swivel (left / right) No
Title (down / up) -2 / 20
High Adjustment (mm) No
Accessories * * * * * * * * * * * * * * * * * * * * *
Signal Cable VGA and DVI cable
Others Audio cable
Reliablity Spec * * * * * * * * * * * * * * * * * * * * *
MTBF (hr, exclude lamp) 60,000
Lamp life (hr) min 30,000
Lamp life (hr) Typical 50,000
Model FP91E
LCD Size 19.0"
Brightness (typ.) 250 cd/㎡
Max. Brightness 280 cd/㎡
Contrast (typ.) 1000:1
Max. Contrast 1050:1
Viewing Angle (L/R;U/D) (CR>=10) 170 / 170
Viewing Angle (L/R;U/D) (CR>=5) 178 / 178
Response Time(rise+fall) typ. 25 ms (8 GTG)
Display Colors 16.7 million
OSD Language 8
i Key Yes
Kensington Yes
Net Weight (kg) 6
Speaker 2W x 2
USB No
Pivot No
Others Audio cable
