Is dit een Radeon 9500 Pro of 9700?
  • Pimmuz
  • Laatst online: 19-08 14:32
quote 3dmark05
RADEON 9500 PRO / 9700 Driver 6.14.10.6571
Description RADEON 9500 PRO / 9700
Manufacturer ATI Technologies Inc.
Total Local Video Memory 256 MB
Total Local Texture Memory 256 MB
Total AGP Memory 128 MB
Driver File ati2dvag.dll
Driver Version 6.14.10.6571
Driver Details 8.172-050830a1-026409C-ATI
Driver Date 8-30-2005
Driver WHQL Certified true
Max Texture Width 2048 px
Max Texture Height 2048 px
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 2.0
Pixel Shader Version 2.0
Max Vertex Blend Matrices 37
Max Texture Coordinates 8
VGA Memory Clock 263.3 MHz
VGA Core Clock 263.3 MHz
PCI
Name RADEON 9500 PRO / 9700
Vendor ID 0x1002
Device ID 0x4e45
SubSystem ID 0x30021002
Revision ID 0x0000
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [UYVY]
FourCC [YUY2]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
Betreft een Dell Dimension 4550, Bij de omschrijving stond 9700TX
Dus dit is z'n OEM kaart die terug geklokt is? (core/mem beide 263mhz :? :? )
Zou graag willen zien hoeveel pipes vertex shaders etc dit kaartje heeft...
  • The__Virus
  • Laatst online: 10:29
De TX is een afgeslankte versie van de 9700 (Pro). Hij zal evenveel vertex pipes hebben, alleen draait hij op een lagere kloksnelheid. Waarom wil je dit weten eigenlijk? Kun je met Rivatuner niet zien hoeveel pipes ie heeft?
  • Aapenootjes
  • Laatst online: 12-07 02:48
Het is wellicht wel de moeite waard om hem te overklokken, ik had een 9500 (zelfde core, maar met wat pipes disabled), en daarvan draaide de core zonder problemen op 405mhz. Dat was met standaart koeling en die kaart loopt standaart ook maar 270mhz. Er valt dus wellicht nog flink wat uit die kaart te halen.
  • Barre_Code
  • Laatst online: 31-08 19:55
9700tx? doet me sterk denken aan een 9600tx in zo'n aldi pctje die ik ooit heb gehad. Dat was in feite een 9500pro. Aangezien er 9500 voor staat denk ik at het hier hetzelfde kaartje betreft. Als dat zo is is hij leuk te overclocken! Haalde in 3Dmark05 geloof ik max. 1800 punten.
  • Skyline GT-R
  • Laatst online: 28-07 06:51
Skyline GT-R
RB26DETT
Nee dat is 9700TX, ik heb er ook zo eentje gehad. Dat is een 9700Pro die zowel mem als core op 263MHz loopt. Dus 8 pipes enzo, en ik vond het een prima kaartje! Ik heb hem toen ook naar een 9700Pro geflash zonder enig probleem! Je moet alleen de geheugensnelheid naar beneden instellen wat de standaard 310MHz haalt hij niet! 300MHz was bij mij de max. Maar de core kreeg ik met standaard koeler makkelijk te op 345MHz ;)
  • Pimmuz
en nou komt de mooiste vraag hehe...
hoe gaan we dat doen? overclocken ik ga zodadelijk even hier in de faq gluren..
maar kan ik dan bv 300 instellen en dat even testen dat ik geen artifacts krijg?
maar heeft dat wel nut me nieuwe systeem komt eraan gaat ik nu btw ff in me signature zetten :)
  • Barre_Code
Als je toch een nieuwe krijgt wacht dan gewoon ;)
  • Ultraman
  • Laatst online: 31-08 15:36
Ultraman
Boefje
Je kunt overclocken met tools als RivaTuner? En dan testen? Of zie ik dat verkeerd? :?
Deze kaart heb ik ook! gwn een lager geclockte 9700Non Pro gooi er een Zalman VF700 erop en gegarandeerd 400+ >:) ow jah de geheugen doet max 310 bij mij zonder koeling erop.
Suc6 ermee!
[ Voor 27% gewijzigd door Verwijderd op 07-10-2005 22:50 ]
  • Phyth0n
  • Laatst online: 31-08 19:49
juaNto schreef op vrijdag 07 oktober 2005 @ 20:22:
Lol wel een mooi Systeem heb je nu in je sig. :) ;)
  • Pimmuz
Thnx Amd4all :)
Daarom laat ik dit kaartje met rust heeft sinds april 2003 z'n werk goed gedaan!
Deze bak word nu me server dus heb dan zowiso weining aan een overclockte videokaart...
sorry van dit topic maar vroeg me gewoon af of die mem/core wel goed liepen nou blijkbaar wel dus :D
Ik denk ook niet dat ik veel met die gtx ga doen ik laat het lekker allemaal stock lopen
Is inderdaad een teruggeklokte 9700 pro, heb hem hier zelf ook. Bij mij doet ie core 360 mhz en geheugen op 335. Heb er een 80mm ventilator onder hangen op 7 volt. Prima kaartje, kan er nog prima op gamen.
  • Pimmuz
Geloof best dat er nog prima mee te gamen valt maar ik laat hem in zijn waarde :)
strax hoeft hij niet meer te gamen alleen maar windows appz draaien en 24/7 aanstaan...
maar toch leuk dat er dus best wel wat mensen met deze kaart zijn en heb ook lekker hoog hebben gekregen...
wat was dan het nut van deze kaart als het een pro is kwa mogelijkheden maar kwa speeds lager is maar het dus schijnbaar wel aankan!
apart..
Deze kaart was bij dell leverbaar tegelijkertijd met de geforce 4 mx 460, en de 9700 pro..dit was zeg maar de middenmoot. Ze zullen wel bij ati een hoop kaarten hebben gekocht welke niet op pro speeds konden lopen voor een dumpprijs of iets dergelijks
  • Teun_2
  • Laatst online: 31-08 08:16
Wat ik weet is dat het verschil tss een 9500 pro en een 9700 een andere pcb is en een lagere geheugenbus (128 vs 256), voor de rest zijn ze identiek. de 9500 was voor die prijsklasse wat overpowered. De 9500pro zit op ongeveer hetzelfde niveau als de 9600xt.
  • Teun_2
Tw34jer schreef op vrijdag 07 oktober 2005 @ 19:54:
Dat Aldikaartje is een overklokte 9500, die had maar 4 pixelpipelines.
