Cisco 801 Configure probleem
  • 140 views sinds 30-01-2008
Als debug staat aan:
Router1#sh debugging
Dial on demand:
  Dial on demand events debugging is on
  Dial on demand packets debugging is on
PPP:
  PPP authentication debugging is on
  First bytes of multilink packet debugging is on
The following ISDN debugs are enabled on all DSLs:
debug isdn error is             ON.
debug isdn event is             ON.
debug isdn q921 is              ON.
debug isdn q931 is              ON.
Onze debug
Router1#isdn test call interface bri 0 0676085000
Router1#
00:19:06: BR0 DDR: Attempting to dial 0676085000
00:19:06: ISDN BR0 EVENT: UserIdle: callid 0x800D received ISDN_CALL (0x0)
00:19:06: ISDN BR0 EVENT: handle_l2d_srq_mail: Activating Layer 1
00:19:14: ISDN BR0 EVENT: isdn_layer1_failure: Layer 1 not active even after T3
delay
00:19:14: BRI0: wait for isdn carrier timeout, call id=0x800D
00:19:60129542208: ISDN BR0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
00:19:60139773252: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x800D calltype
 1 HOST_DISCONNECT_ACK
00:19:60139772700: ISDN BR0 **ERROR**: host_disconnect_ack: Unfound B-channel on
 Disconnect_Ack call id 0x800D
00:19:14: ISDN BR0 EVENT: service_queue_from_physical_layer: Recvd L1 prim 3 sta
te is 3
Hier onze config
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
Current configuration : 1182 bytes
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname Router1
boot-start-marker
boot-end-marker
enable secret 5 $1$mx88$8SvJzmIGC6RcMy29pyoIo0
username castel309584 password 0 ES5Xkff$
no aaa new-model
ip subnet-zero
no ip domain lookup
isdn switch-type basic-net3
interface Ethernet0
 ip address 10.10.0.254 255.0.0.0
 shutdown
 no cdp enable
interface BRI0
 no ip address
 encapsulation ppp
 shutdown
 dialer pool-member 1
 ppp authentication chap
interface Dialer1
 description inbelverbinding
 ip address negotiated
 encapsulation ppp
 no ip split-horizon
 dialer-group 1
 no cdp enable
 ppp chap hostname xxxxxxxxxxxxxx
 ppp chap password 0 xxxxxxxxxxxxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
ip http server
access-list 100 permit ip any any
dialer-list 1 protocol ip list 100
dialer-list 2 protocol ip permit
no cdp run
line con 0
 transport preferred all
 transport output all
 stopbits 1
line vty 0 4
 login
 transport input all
no rcapi server
end
Iemand weet wat er hier mis gaat ?
  • Question Mark
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Unshut je BRI interface even....
we zijn nu iets verder, nu zien we dit bij dit command ISDN TEST CALL INTERFACE BRI 0 0676085000 dit:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
00:29:90204544452: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x800D calltype 1 HOST_PROCEEDING
00:29:22: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=98, ns=1 nr=1
00:29:22: ISDN BR0 Q931: ALERTING pd = 8  callref = 0x8D
00:29:22: ISDN BR0 Q921: User TX -> RR sapi=0 tei=98 nr=2
00:29:94499511748: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x800D calltype 1 HOST_ALERTING
00:29:22: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=98, ns=2 nr=1
00:29:22: ISDN BR0 Q931: CONNECT pd = 8  callref = 0x8D
    Date/Time i = 0x050A060C2516
    Connected Number i = 0x00C3
00:29:22: ISDN BR0 Q921: User TX -> RR sapi=0 tei=98 nr=3Router1#
00:29:22: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=98, ns=1 nr=3
00:29:22: ISDN BR0 Q931: CONNECT_ACK pd = 8  callref = 0x0D
00:29:22: BR0:2 PPP: Using dialer call direction
00:29:22: BR0:2 PPP: Treating connection as a callout
00:29:22: BR0:2 PPP: Authorization required
00:29:23: ISDN BR0 Q921: User RX <- RR sapi=0 tei=98 nr=2
00:29:23: ISDN BR0 EVENT: UserIdle: callid 0x800D received ISDN_HANGUP (0x1)
00:29:23: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=98, ns=2 nr=3
00:29:23: ISDN BR0 Q931: DISCONNECT pd = 8  callref = 0x0D
    Cause i = 0x8090 - Normal call clearing
00:29:23: ISDN BR0 Q921: User RX <- RR sapi=0 tei=98 nr=3
00:29:23: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=98, ns=3 nr=3
00:29:23: ISDN BR0 Q931: RELEASE pd = 8  callref = 0x8D
00:29:23: ISDN BR0 Q921: User TX -> RR sapi=0 tei=98 nr=4
00:29:98794479044: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x800D calltype 1 HOST_DISCONNECT_ACK
00:29:23: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=98, ns=3 nr=4
00:29:23: ISDN BR0 Q931: RELEASE_COMP pd = 8  callref = 0x0D
00:29:24: ISDN BR0 Q921: User RX <- RR sapi=0 tei=98 nr=4
00:29:33: ISDN BR0 Q921: User RX <- DISCp sapi=0 tei=98
00:29:44: ISDN BR0 Q921: User RX <- IDCKRQ ri=0 ai=98
00:29:44: ISDN BR0 Q921: User TX -> IDCKRP ri=1245 ai=98
00:29:54: ISDN BR0 EVENT: service_queue_from_physical_layer: Recvd L1 prim 5 state is 1
00:29:55: ISDN BR0 EVENT: service_queue_from_physical_layer: Recvd L1 prim 3 state is 2
00:29:55: ISDN BR0 EVENT: isdn_sw_cstate: State = 0, Old State = 4
00:29:236223201280: ISDN BR0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
00:30:45: ISDN BR0 EVENT: UserIdle: callid 0x800E received ISDN_CALL (0x0)
00:30:45: ISDN BR0 EVENT: handle_l2d_srq_mail: Activating Layer 1
00:30:45: ISDN BR0 EVENT: isdn_sw_cstate: State = 4, Old State = 4
00:30:45: ISDN BR0 EVENT: service_queue_from_physical_layer: Recvd L1 prim 1 state is 0
00:30:45: ISDN BR0 Q921: User TX -> IDREQ ri=21166 ai=127
00:30:45: ISDN BR0 Q921: User RX <- IDASSN ri=21166 ai=99
00:30:45: ISDN BR0 Q921: User TX -> SABMEp sapi=0 tei=99
00:30:45: ISDN BR0 Q921: User RX <- UAf sapi=0 tei=99
00:30:45: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=99, ns=0 nr=0
00:30:45: ISDN BR0 Q931: SETUP pd = 8  callref = 0x0E
    Bearer Capability i = 0x8890
        Standard = CCITT
        Transer Capability = Unrestricted Digital
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0x83
    Called Party Number i = 0x80, '0676085000'
        Plan:Unknown, Type:Unknown
00:30:45: ISDN BR0 Q921: User RX <- RR sapi=0 tei=99 nr=1
00:30:45: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=99, ns=0 nr=1
00:30:45: ISDN BR0 Q931: CALL_PROC pd = 8  callref = 0x8E
    Channel ID i = 0x89
00:30:45: ISDN BR0 Q921: User TX -> RR sapi=0 tei=99 nr=1
00:30:193283759556: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x800E calltype 1 HOST_PROCEEDING
00:30:46: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=99, ns=1 nr=1
00:30:46: ISDN BR0 Q931: ALERTING pd = 8  callref = 0x8E
00:30:46: ISDN BR0 Q921: User TX -> RR sapi=0 tei=99 nr=2
00:30:197578726852: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x800E calltype 1 HOST_ALERTING
00:30:47: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=99, ns=2 nr=1
00:30:47: ISDN BR0 Q931: CONNECT pd = 8  callref = 0x8E
    Date/Time i = 0x050A060C262F
00:30:47: ISDN BR0 Q921: User TX -> RR sapi=0 tei=99 nr=3
00:30:201873694148: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x800E calltype 1 HOST_CONNECT
00:30:47: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=99, ns=1 nr=3
00:30:47: ISDN BR0 Q931: CONNECT_ACK pd = 8  callref = 0x0E
00:30:47: BR0:1 EVT: Cstate 4 0x00000000
00:30:47: BR0:1 PPP: Using dialer call direction
00:30:47: BR0:1 PPP: Treating connection as a callout
00:30:47: BR0:1 PPP: Phase is ESTABLISHING, Active Open
00:30:47: BR0:1 PPP: Authorization required
00:30:47: BR0:1 LCP: O CONFREQ [Closed] id 38 len 15
00:30:47: BR0:1 LCP:    AuthProto CHAP (0x0305C22305)
00:30:47: BR0:1 LCP:    MagicNumber 0x101345B9 (0x0506101345B9)
00:30:47: ISDN BR0 Q921: User RX <- RR sapi=0 tei=99 nr=2
00:30:47: BR0:1 EVT: Packet 0 0x02B2F47C
00:30:47: BR0:1 LCP: I CONFREJ [ACKsent] id 38 len 9
00:30:47: BR0:1 LCP: O CONFREQ [ACKsent] id 39 len 15
00:30:47: BR0:1 EVT: Packet 0 0x02B46928
00:30:47: BR0:1 LCP: I CONFREJ [ACKsent] id 39 len 9
00:30:47: BR0:1 LCP: O CONFREQ [ACKsent] id 40 len 15
00:30:47: BR0:1 EVT: Packet 0 0x02B46F20
00:30:47: BR0:1 LCP: I CONFREJ [ACKsent] id 40 len 9
00:30:47: BR0:1 LCP: O CONFREQ [ACKsent] id 41 len 15
00:30:48: BR0:1 EVT: Packet 0 0x02B24624
00:30:48: BR0:1 LCP: I CONFREJ [ACKsent] id 41 len 9
00:30:48: BR0:1 LCP:    AuthProto CHAP (0x0305C22305)
00:30:48: BR0:1 LCP: O CONFREQ [ACKsent] id 42 len 15
00:30:48: BR0:1 LCP:    MagicNumber 0x101345B9 (0x0506101345B9)
00:30:48: BR0:1 EVT: Packet 0 0x02B24920
00:30:48: BR0:1 LCP: I CONFREJ [ACKsent] id 42 len 9
00:30:48: BR0:1 LCP: O CONFREQ [ACKsent] id 43 len 15
00:30:48: BR0:1 EVT: Packet 0 0x02B24C1C
00:30:48: BR0:1 LCP: I CONFREJ [ACKsent] id 43 len 9
00:30:48: BR0:1 LCP: O CONFREQ [ACKsent] id 44 len 15
00:30:48: EVT: Suspending after 20000ms
dit gebeurde toen we ISDN TEI-NEGOTIATION FIRST-CALL hadden ingevoerd.
Het zomaar neerdumpen van stukjes van je config en debug output maakt nog geen topic. Als er niet eens een beetje uitleg in staat en zelfwerkzaamheid blijkt ben je niet juist bezig.
