[RIS] Add intel driver to setup
  • 55 views sinds 30-01-2008
Hoi,
Ik ben hier al een paar dagen bezig met het installeren van RIS. Ik heb een aparte server geconfigureerd waar het hele ris gebeuren op moet gaan draaien.
Als ik een image met "RIPREP" heb gemaakt en ik opnieuw op wil starten om de image terug te zetten geeft hij steeds de volgende melding:
The operating system image you selected does not contain the neccesery drivers for your network adapter. Try selecting a different operating system image
Wij maken hier gebruik van Dell GX60 client pc's deze hebben allemaal een Intel Pro NIC
Ik heb al op internet gezocht en kwam op de volgende site van microsoft:
[Unattended]
DriverSigningPolicy = Ignore
NOTE: The default name of the .sif file is RemoteInstall\Setup\Language\Images\Dir_name\I386\Templates\Ristndrd.sif
NOTE: If the OEM driver is an update of an included Windows 2000 driver (for example, has the same name), the file must be signed or Setup uses the included driver instead. 1. On the RIS server, copy the OEM-supplied .inf and .sys file for the network adapter to the RemoteInstall\Setup\Language\Images\Dir_name\i386 folder. This allows Setup to use the driver during the Text-mode portion of the installation.
2. At the same level as the I386 folder on the RIS image, create a $oem$ folder with the following structure:
\$oem$\$1\Drivers\Nic
3. Copy the OEM-supplied driver files to this folder. Note the folder in which the .inf file looks for its drivers. Some manufacturers place the .inf file in a folder and copy the driver files from a subfolder. If this is the case, create the same folder structure below the one you created in this step.
NOTE: If the RIS image was created with RIPREP, you must perform these steps on both the RIPREP image and the RISETUP image that corresponds to the RIPREP image.
4. Make the following changes to the .sif file to be used for this image installation:
[Unattended]
OemPreinstall = yes
OemPnpDriversPath = Drivers\Nic
5. Stop and restart the BINL service on the RIS server. Type the following lines at the command prompt, pressing ENTER after each command:
net stop binlsvc
net start binlsvc
NOTE: Stopping and restarting the BINL service is necessary because BINL needs to read all the new network interface card-related .inf files and create .pnf files in the image. Because this is a time consuming task, it is only done once, which is when the BINL service starts.
Heb al veel op internet/got gezocht maar kan geen oplossing vinden. Wie kent dit probleem en kan mij verder helpen??
Alvast bedankt,
[ Voor 4% gewijzigd door Verwijderd op 05-10-2005 09:19 ]
  • Krypt
  • Laatst online: 13-10 20:33
Heb je de .inf wel aangepast voor de Intel e100 en e1000 nics? zoals BackSlash32 in dat topic aangeeft? (BackSlash32 in "Intel pro/1000mt nics werken niet mer RI...")
Zoals hier te lezen heb je dat schijnbaar nog niet gedaan.
Open de .inf files voor je netwerk driver, dan moest je volgens mij de '.x86' uit elke inf-section verwijderen (wat tussen de [] staat).. vervolgens terug kopieeren en dan de binlsvc herstarten.
Anders moet je even op intel.com zoeken naar de drivers voor je netwerk kaart.. Daar staan ook aangepast inf files bij voor RIS scenario. (lees: ftp://aiedownload.intel.com/df-support/6759/ENG/readme.rtf)
[ Voor 25% gewijzigd door Krypt op 05-10-2005 09:28 ]
Pvouput live
Krypt schreef op woensdag 05 oktober 2005 @ 09:24:
Ik kan nergens op de intel site aangepaste drivers vinden voor RIS. Het gaat hier om NIC type intel 82557.
Heb al veel op internet gezocht over dit probleem. Het enige wat ik zou moeten doen volgens vele sites zijn:
Dirstructuur aanmaken $oem$\$1\Drivers\Lan
Daar alle drivers inkopieren
en het .SIF filtje aanpassen
Dit alles is gebeurt maar krijg nog steeds de melding dat hij de goede drivers niet heeft!
[ Voor 17% gewijzigd door Verwijderd op 05-10-2005 11:07 ]
  • Krypt
RIS werkt in twee modi... 1tje is de CIW (of ook wel de text-setup genoemd; het blauwe installatie scherm) en de minisetup (grafische unattended installatie).
De drivers die je in $oem$ gooit is voor de unattended setup, maar de CIW moet ook een netwerkconnectie maken. Hij heeft natuurlijk al connectie via PXE, maar de CIW schakeld om in de SMB modus en heeft een netwerkdriver nodig. Deze driver zoekt ie in de i386 directory op je RemoteInstall share. Als je netwerkkaart hebt waarbij de driver niet standaard in de WXP i386 directory staan, dan moet je die toevoegen.
Pakt de driver uit en plaats de .inf, .cat en de .sys files in de i386 directory en hetstart de binlsvc service.
[edit]
Over die 82557 kaart: http://www.intel.com/supp...r/pro100/sb/cs-000596.htm
[ Voor 7% gewijzigd door Krypt op 05-10-2005 12:18 ]
Pvouput live
Krypt schreef op woensdag 05 oktober 2005 @ 12:15:
Tnx, dit was dus het probleem.
Wat ik nu heb gedaan om dit alles werkend te krijgen is:
- De files NET82557.pnf + NET8255a.pnf + NET82557.INF + NET8255a.INF Verwijderd
- De .INF, .CAT, .CAT files van de driver cd naar de map I368 gekopieerd
Toen de boel gerestart en alles werkte!!
  • alt-92
alt-92
ye olde farte
Verwijderd schreef op woensdag 05 oktober 2005 @ 09:56:
dan zoek je niet goed.
http://support.intel.com/support/network/sb/cs-000023.htm
nee, omdat je mijn bovenstaande link niet hebt gevonden ;)
[edit]
Bovenstaande post van Krypt is een workaround overigens die ook werkt.
maar waar ik in dat andere topic al naar verwees is dus simpel te vinden met een [google=intel RIS]
Dan was je dus ook bij http://support.intel.com/support/network/sb/cs-000023.htm terecht gekomen en was je al 5 dagen eerder klaargeweest :)
[ Voor 20% gewijzigd door alt-92 op 05-10-2005 12:33 ]
  • elevator
elevator
Officieel moto fan :)
Ga maar gewoon door in je vorige topic. Dit heeft bovendien niets in Software Algemeen te zoeken.
