Skype vanaf USB stick
  • 117 views sinds 30-01-2008
op het skype forum zag ik een topic over skype direct vanaf je usb stick te draaien. [linkje]
het voordeel hiervan is dat je altijd skype hebt(nooit installeren dus) en dat je je eigen profiel altijd met je mee neemt.
volgens de readme moet je het volgende uitvoeren:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
!!VITAL: SET USB STICK LABEL TO Skype-USB!!
Right click on your drive in windows explorer->properties->Put "Skype-USB" in the box and click apply.(if you want to keep your original name, you'll have to edit the batch files accordingly)
Assuming you've succeeded in extracting this .zip to your USB drive *autorun.inf and a folder named skype should be in the root of your drive -- if you put the files of this package in a separate folder it will not work---:
First thing is to copy your Skype executable (program files/skype/phone/skype.exe) to a folder that by now should be on your USB drive (Skype/Program/Skype/)
Second: download Junction (http://www.sysinternals.com/files/junction.zip) this is the program used to create virtual links, and extract it to (Skype/Program/Junction/)
Next (and semi optionally), copy your skype profile (C:\Documents and Settings\(your username)\Application Data\Skype\(your skype name)->*this is your profile*  to (Skype/Data/Skype/)
And optionally: copy your skype pictures to (skype/data/pictures) or use the great picture I’ve put there from now on.
nb. Skype received files will be stored in (skype/data/files)
Now check if everything is in the correct folder and unplug your USB stick.
Now, how does it work?
This package comes in two exiting flavors, all rolled in to one.
1:  IF your host system is xp with service pack 2 an autoplay message should pop up when you insert your USB stick. To start using skype--> click Skype Mobile.
A console should pop up for a second, after which skype is loaded from your stick (depending on how fast your drive and the system is, this might take a second or nine) the virtual links are created automatically, so just start using skype.
When you're done, close skype normally, wait 2 seconds for the host system settings are restored and your settings are removed and unplug your stick.
2. If you like to watch what's going on, autoplay is not supported or it just didn't work-> use skype mobile the other way.
(dismiss the autoplay dialogue) and right click on your USB drive in windows explorer.
you should now see 3 options you don't normally see:
register skype mobile
launch skype
unregister skype mobile
Now click on register skype mobile-> a console pops-up and you can check out what's going on. allow the operation to finish and press space. (virtual links will have been created and original settings moved)
Next: launch skype, use and don't forget to close skype when you're finished
When done: unregister skype mobile (clear virtual links and restore original settings on the host system) press space
That’s it!
This package has been tested on an English windows xpsp2, it might work on other versions but i just wouldn't know. Use this package at your own risk.
kortom:
- verander de usb-stick name
- extract de .zip naar de root directory van je stick
- skype.exe gekopieerd naar de stick map
- junction gedownload en extracted.
- profile gekopieerd
nu zou hij dus moeten werken, ik krijg echter de melding dat skype.exe geen geldige win32 toepassing is.
komt dit soms omdat mijn usb-stick fat danwel fat32 is(heb namelijk al enkele malen geformatteerd) en mijn lokale schijf gewoon NTFS is.
het werkt op geen enkele pc, ook niet op een pc met Win-XP UK met SP2.
ik kon hier op GoT ook niks vinden over deze leuk manier van skypen, dus ik hoop dat we het kunnen fixen of dat er iemand is die het al gelukt is.
schop
  • potatox
  • Laatst online: 06-10-2025
potatox
unz unz unz
dat je usb fat is en je schijf ntfs maakt nix uit. als ie aangeeft dat de exe van skype geen geldige 32-bit applicatie is, lijkt het erop dat de exe gewoon beschadigd is, maybe ff opnieuw erop zetten?
_PoTaToX_ schreef op woensdag 05 oktober 2005 @ 09:44:
ik heb de skype.exe al enkele malen gekopierd, en de skype.exe op de pc werkt gewoon, dus dat is het niet, verder is de stick in orde lijkt me.
