[Java jre 1,5,0_04] JavaCallJS.class error
Hoi, mede tweakers.
Ik kamp sinds een tijdje met een vaag probleem.
Als ik bijvoorbeeld naar www.java.com ga, dan krijg ik de volgende melding:
load: class JavaCallJS.class not found.
Dit is de log van de java console
Java Plug-in 1.5.0_04
Using JRE version 1.5.0_04 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\Robin de Koeijer
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
basic: Registered modality listener
basic: Referencing classloader: sun.plugin.ClassLoaderInfo@1a3eab6, refcount=1
basic: Added progress listener: sun.plugin.util.GrayBoxPainter@811e10
basic: Loading applet ...
basic: Initializing applet ...
basic: Starting applet ...
network: Connecting http://www.java.com/jsp_utils/JavaCallJS.class with proxy=DIRECT
network: Connecting http://www.java.com/jsp_utils/JavaCallJS/class.class with proxy=DIRECT
java.lang.ClassNotFoundException: JavaCallJS.class
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadCode(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.plugin.AppletViewer.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: open HTTP connection failed.
at sun.applet.AppletClassLoader.getBytes(Unknown Source)
at sun.applet.AppletClassLoader.access$100(Unknown Source)
at sun.applet.AppletClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 10 more
basic: Exception: java.lang.ClassNotFoundException: JavaCallJS.class
... 10 more
basic: Modality pushed
basic: Modality popped
basic: Stopping applet ...
basic: Removed progress listener: sun.plugin.util.GrayBoxPainter@811e10
basic: Finding information ...
basic: Releasing classloader: sun.plugin.ClassLoaderInfo@1a3eab6, refcount=0
basic: Caching classloader: sun.plugin.ClassLoaderInfo@1a3eab6
basic: Current classloader cache size: 2
basic: Done ...
basic: Joining applet thread ...
basic: Destroying applet ...
basic: Disposing applet ...
basic: Quiting applet ...
basic: Joined applet thread ...
basic: Unregistered modality listener
Ik draai windows xp sp2.
Dit probleem is zowel met IE, als met firefox :? .
Verder heb ik al verschillende keren opnieuw geherinstalleerd van java maar dit wil ook niet helpen.
Met google kom ik wel op de zelfde problemen, maar niemand schijnt hiernog een oplossing voor te hebben.
Zijn er hier mensen met hetzelfde probleem? en hebben die dit al kunnen oplossen.
[ Voor 14% gewijzigd door Verwijderd op 02-10-2005 15:17 ]
niemand? ;(
