Q3 engine OpenGL
  • Nibbles
  • Laatst online: 16-04 12:46
Nibbles
just nibb it
Ik heb Q3ADemo eens geprobeerd en die werkte niet. OK, boeie, ik speel toch voornamelijk UT. Maar nu heb ik zo'n geinig demootje gevonden van Alice in Wonderland die onder in vloed van crack is >:)
Probleem, zelfde engine, en dus ook zelfde foutmelding ;(
Q3 1.11 win-x86 Nov 29 1999
----- FS_Startup -----
Current search path:
G:\Games\Q3Ademo/baseq3
Running in restricted demo mode.
G:\Games\Q3Ademo\demoq3\pak0.pk3 (1387 files)
G:\Games\Q3Ademo/demoq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: patplag
IP: 192.168.0.1
Working directory: G:\Games\Q3Ademo
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...23 PFDs found
...23 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Systeem:
P3 600 EB
256/133 geheugen
Creative GeForce 256 SDR
win98se
Drivers: Creative FastTrax gebaseerd op 5.31
Heb ik dus geen OpenGL drivers ofzo?
Hieruit lijkt me van wel....
Iemand een idee?
je moet http://www.opengl.com instaleeren
  • Redje
  • Laatst online: 07-08 13:00
Nee man... je videokaart drivers zijn brak, of je videokaart ondersteund geen OpenGL
Had dit ook met me Matrox G200... ff zoeke en werke :)
  • Nibbles
Nibbles
just nibb it
Iemand met een soortgelijk systeem misschien een aanrader qua drivers?
  • Freak_NL
  • Laatst online: 20-07 09:47
Je kan proberen de Nvidia detonator drivers te installeren www.nvidia.com -> drivers voor GeForce.
Je systeem is denk ik niet het probleem.
  • Mr Magic
  • Laatst online: 07-08 13:39
Als je per se de Creative FastTrax drivers wilt: de laatste versie is 6.34.
Anders de NVidia reference drivers, versie 6.47 o.i.d.
