SLI / PCI EXPRESS...
  • 73 views sinds 30-01-2008
DFI LP-UT-NF4 SLI-D S939 2000FSB ATX MAINBOARD
Dat moederbord wil ik gaan kopen.
Is het zo dat als ik 1 PCI-Express kaart erin doe dat hij werkt, of moeten het er 2 zijn?
INFO:
ATX AMD Socket 939, Athlon 64FX/Athlon 64/Sempron, 2000MT/s, CMOS Reloaded, PCI Express (SLI mode), DDR400, Karajan audio module (8-channel), S/PDIF-in/out, Serial ATA 3Gb/s, RAID 0/1, Dual Gigabit LAN, IEEE 1394 and 10 USB.
Specification
CPU
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
Chipset
NVIDIA nForce4 SLI
- Supports NVIDIA SLI (Scalable Link Interface)
Front Side Bus
2000MT/s HyperTransport interface
Memory
Four 184-pin DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports DDR266, DDR333 and DDR400 DDR SDRAM DIMM
SLI / Single VGA Mode
SLI mode
- 2 SLI-ready graphics cards (use identical cards) on the PCI Express x16 slots.
- The graphics cards are connected via the SLI bridge.
- The bandwidth of each slot is x8; when the graphics cards are connected via the SLI bridge, it runs at x16 bandwidth.
Single VGA mode
- 1 PCI Express graphics card on the PCIE1 slot will run at x16 bandwidth.
- The other PCI Express x16 slot (PCIE4) will run at x2 bandwidth.
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Power Management
Supports ACPI STR (Suspend to RAM) function
Wake-On-Events include:
- Wake-On-PS/2 Keyboard/Mouse
- Wake-On-USB Keyboard/Mouse
- Wake-On-LAN
- RTC timer to power-on the system
AC power failure recovery
Hardware Monitor
Monitors CPU/system/chipset temperature Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vchipset/Vdram voltages
Monitors the speed of the CPU fan, Fan 2 and chipset fan
CPU Overheat Protection function monitors
CPU temperature during system boot-up
Audio
- Realtek ALC850 8-channel audio CODEC
- 6 audio jacks
- 1 CD-in connector
- 1 front audio connector
S/PDIF-in/out interface
LAN
Dual Gigabit LAN - Vitesse VSC8201 Gigabit Phy and Marvell 88E8001 Gigabit PCI
Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IDE
Two IDE connectors that allows connecting up to four UltraDMA 133Mbps hard drives
NVIDIA RAID allows RAID arrays spanning across
Serial ATA and Parallel ATA
RAID 0 and RAID 1
Serial ATA with RAID
Four Serial ATA ports
SATA speed up to 3Gb/s
RAID 0 and RAID 1
NVIDIA RAID allows RAID arrays spanning across Serial ATA and Parallel ATA
IEEE 1394
VIA VT6307
Supports two 100/200/400 Mb/sec ports
Rear Panel I/O Ports
1 mini-DIN-6 PS/2 mouse port
1 mini-DIN-6 PS/2 keyboard port
2 S/PDIF RCA jacks (S/PDIF-in and S/PDIF-out)
Karajan audio module (6 audio jacks)
1 IEEE 1394 port
2 RJ45 LAN ports
6 USB 2.0/1.1 ports
I/O Connectors
2 connectors for 4 additional external USB 2.0/1.1 ports
1 connector for 1 external IEEE 1394 port
1 connector for 1 external serial port
1 front audio connector for external line-out and mic-in jacks (on the Karajan audio module)
1 CD-in internal audio connector (on the Karajan audio module)
1 S/PDIF connector for optical cable connection
1 IR connector
4 Serial ATA connectors
2 IDE connectors
1 floppy connector
1 24-pin ATX power connector
1 4-pin ATX 12V power connector
2 4-pin 5V/12V power connectors (FDD-type and HDD type)
1 front panel connector
5 fan connectors
4 diagnostic LEDs
EZ touch switches (power switch and reset switch)
Expansion Slots
2 PCI Express x16 slots
1 PCI Express x1 slot
1 PCI Express x4 slot
2 PCI slots
PCB
ATX form factor
24cm (9.45") x 30.5cm (12")
All specifications above are subject to change without prior notice.
  • Gunner
Gunner
Invincibles
Werkt ook gewoon met 1 PCI-Xpress kaart
  • GoldenSample
GoldenSample
Huub, Huub, Barbatruc!
je kan gewoon draaien met een kaart :) alleen is er de mogelijkheid om er 1 bij te plaatsen, mits van het zelfde (geschikte) type
maar dit had je toch ook wel zelf kunnen vinden :)
ben er niet zo slim in :)
bedankt
  • Smoothcrimineel
  • Laatst online: 18-11-2025
alleen 2 ati's aanelkaar knopen word wat moeilijk >:)
  • Abbadon
  • Laatst online: 20:34
Deze was vrij simpel zelf te vinden ;)
En je hoeft de volgende keer alleen de relevante info te posten, niet 100 regels met wat er allemaal op dat bord zit, leidt alleen maar af :)
