[Win2000server] Terminal Server installeren
  • 605 views sinds 30-01-2008
  • BMW_M3
BMW_M3
Ondertitel
Hej,
Ik moet Terminal server installeren op een windows 2000 server maar dit lukt me echt niet :S.. ik heb over al gezocht maar ik kom er niet uit. bijv ik heb dit gevonden:
To install Terminal Server
1. Open Configure Your Server Wizard.
2. Click Next and follow the instructions on the Preliminary Steps screen.
3. Click Next, and on the Server Role screen, select Terminal Server.
4. Click Next and follow the instructions in the wizard.
5. Some programs might not work correctly when Terminal Server is installed. If so, you must reinstall these programs for multisession access using Add or Remove Programs after Terminal Server is installed. For more information, see Program Compatibility.
Maar als ik "Configure Your Server " start zie ik die optie niet staan : zie alleen dit
You have successfully completed Windows 2000 Server Setup.
You can now configure this server. Select the first option if you have one server in your network. Select the second option if you have more than one server in your network.
If you prefer to configure your server later, select the third option.
This is the only server in my network.
One or more servers are already running in my network.
I will configure this server later.
als ik de bovenste 2 kies dan krijg ik het volgende te zien:
From the menu at the left, choose the services that you want to run on this server. You can set up any or all of the services, depending on how you want to customize your network.
To set up or find out more about a service, click the service name on the menu.
Find out What's New in Windows 2000 Server.
Check out the latest walkthroughs.
To reopen this window at any time, click Start, point to Programs, point to Administrative Tools, and then click Configure Your Server.
maar zie nergens de optie :
dus de 2e stap.. Kan iemand me helpen kom er echt niet uit.
Bvd
( kon geen screenshots maken vandaar dat ik de lappe text hebt gekopieerd hoop dat ik het overzichtelijk heb gemaakt )
Signature
  • jdsm
  • Laatst online: 21:52
Kan je de Terminal Server service in het Services scherm vinden bij de System Administration optie in het Control Panel ? Daar zou je het proces automatisch kunnen laten starten met windows, voor het configureren was ook een cmd maar die weet ik niet meer helaas.
  • alt-92
alt-92
ye olde farte
En wat dacht je van de Help van Windows 2000 lezen?
  • cOOlrUnnINgs
  • Laatst online: 23-10 16:19
Als je naar add/remove programs gaat, daar kies je voor add windows components en daar moet ie ergens tussenstaan.
  • BMW_M3
BMW_M3
Ondertitel
cOOlrUnnINgs schreef op dinsdag 27 september 2005 @ 11:06:
zie het niet staan
ik zie allen:
Terminal Services
Terminal Services Licensing
En het staat er ook nie tussen "details van die 2"tenmiste niet Terminal Server"
Of is dat het misschien
( ben wel noobie hehe)
Signature
  • cOOlrUnnINgs
Die moet je hebben. (BTW, wat wil je eigenlijk gaan doen precies.)
  • BMW_M3
BMW_M3
Ondertitel
cOOlrUnnINgs schreef op dinsdag 27 september 2005 @ 11:17:
"Die moet ik hebben" 1 van die 2 die ik noemde of?
Signature
  • cOOlrUnnINgs
Terminal Services
  • alt-92
alt-92
ye olde farte
Volgens mij heb je geen enkel idee wat je nou aan het doen bent?
Hoe ziet je organisatie eruit? Heb je slechts 1 server? Meerdere?
Wat moet deze TerminalServer gaan doen, applicaties aanbieden? > application mode
Of is het alleen voor beheer op afstand? > remote administration mode
Hoeveel users?
Heb je een AD domain?
[ Voor 8% gewijzigd door alt-92 op 27-09-2005 11:23 ]
  • BMW_M3
BMW_M3
Ondertitel
BackSlash32 schreef op dinsdag 27 september 2005 @ 11:23:
Hoeveel users?
Ik heb 1 server en ik moet een applicatie bieden naar 4 andere gebruikers in de organisatie en het moet ook beheerd worden op afstand.
Signature
  • Jazzy
  • Laatst online: 23:57
Jazzy
Moderator SSC/PB/AI
Moooooh!
BMW_M3 schreef op dinsdag 27 september 2005 @ 11:25:
Zou het niet handiger zijn om er iemand bij te halen met kennis van zaken? Of eventueel (kost iets meer tijd en moeite) zorgen dat je zelf kennis van zaken krijgt?
Geloof me, als je niet weet hoe je de functie kunt activeren op een server dan wordt de configuratie ook niets.
  • loodgieter
  • Laatst online: 12-06 16:18
loodgieter
Mars Vs. zie hieronder :)
heb je ook een AD dan ?
is wel handig als je TS gaat gebruiken en applicaties wilt gaan aanbieden en je moet dan in application mode installen ipv adminstarstor mode.
maar iemand erbij halen lijkt me een betere optie.
  • cOOlrUnnINgs
In het geval van aanbieden van appl. sluit ik me aan bij het advies van Jazzy.
  • BMW_M3
BMW_M3
Ondertitel
Jazzy schreef op dinsdag 27 september 2005 @ 11:28:
Die persoon is deze week niet aanwezig en ik moest het zelf proberen op te lossen. ik moet een programma "Smart Contact Manager Pro" installeren op de Terminal Server zodat de andere gebruikers hier gebruik van kunnen maken.
De systeembeheerder is er dus niet en ik probeer het zelf op te lossen. Weet nie of iemand me wat instructies kan geven zodat ik dit toch kan maken voor de gebruikers.
Bvd.
Signature
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
BMW_M3 schreef op dinsdag 27 september 2005 @ 12:01:
Geef anders even duidelijk aan welke documentatie je gebruikt en op welk punt die niet duidelijk is.
  • BMW_M3
BMW_M3
Ondertitel
Jazzy schreef op dinsdag 27 september 2005 @ 12:05:
Ik heb alleen het volgende meegekregen:
Instaleer win2000 server maak hiervan een terminal server van en installeer het programma via add/remove programs --> add new programs --> verwijs vandaar dat de installatie begint van de cdrom.
Ik heb het volgende gedaan:
win2000 server geinstaleerd;
Terminal Services;
Terminal Services Licensing;
En toen gewoon de setup gedraaid van de cdrom ( add/remove programs --> add new programs )
Maar ik weet echt niet of dit zowel moet en heeft dit wel zin om zo te installeren of moet ik echt wat aanpassingen doen voordat ik uberhaupt aan de installatie kan beginnen "Smart Contact Manager Pro"
Signature
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
De achterliggende gedachte van mijn reakties is dat je je misschien eerst wat meer moet verdiepen in de materie. Bijvoorbeeld door een kijkje te nemen op Windows 2000 Terminal Services. Daar kun je meer dan genoeg lezen om te weten hoe je een Terminal Server op moet zetten, configureren, beheren, etc.
En? Dan ga je toch zelf op zoek naar meer informatie? Of wacht je tot dat je ook aangereikt wordt?
  • BMW_M3
BMW_M3
Ondertitel
Jazzy schreef op dinsdag 27 september 2005 @ 12:18:
ThnQ voor die link.. Maar hoe kan ik aan meer informatie komen als hij niet bereikbaar is?
Signature
  • alt-92
alt-92
ye olde farte
BMW_M3 schreef op dinsdag 27 september 2005 @ 12:26:
Wat niet, de informatie niet (not likely, je hebt internet dus kun je zoeken) of die beheerder niet?
Eerlijk gezegd zou ik als beheerder liever hebben dat je er dan vanaf bleef dan dat je de boel mogelijk compleet verransd, maar dat ben ik ;)
  • BMW_M3
BMW_M3
Ondertitel
BackSlash32 schreef op dinsdag 27 september 2005 @ 12:37:
De beheerder is er niet dus ik kan niet vragen wat ik moet doen ik heb de alleen de bovenste informatie gekregen en meer heb ik niet en d8 dat jullie me meer konden helpen maar doesnt look like it. thnx anyway
Signature
  • alt-92
alt-92
ye olde farte
Kleine misvatting van jouw kant dan.
De enige die jou kan helpen ben je zelf.
Wij kunnen alleen maar hints geven naar dingen waar je op moet letten, en waar je je kennis mee kan bijwerken.
Dat jij liever bij het handje gehouden wilt worden moet je niet op ons hier gaan afschuiven vind ik.
  • Ora et Labora
  • Laatst online: 23-10 16:13
Heb je intussen al terminal service geinstalleerd vanuit ad/remove programs dan?
Als je deze geinstalleerd hebt, is het wat instellingen doorlopen over applicatie / administrative mode en het zou moeten werken
Who's general failure, and why is he reading my disk?
  • mutsje
  • Laatst online: 21-10 10:45
mutsje
Certified Prutser
Als je via add/remove programs Terminal Server en Terminal license server hebt geinstalleerd moet je bij de license server besluiten welke vorm van license je wilt gaan draaien. (device of user) Hier moet je!! TSCALLS voor aanschaffen bij Microsoft binnen de 120 dagen periode omdat hierna je temp licenses verlopen. Voor de rest als je software op een terminal server gaat installeren doe je dat via add/remove programms > Add new program of je opent een command prompt tikt in Change user /install [enter] (hierna voor je de setup uit) na de setup uitgevoerd te hebben Change user /execute [enter]
Voor de rest bedenk wel dat je een productie server goed omzeep gaat helpen als je niet goed weet wat je doet. Het is dan verstandiger om bij je leidingevende te gaan staan met melding ik wil het best doen maar op jou verantwoording..en dit per email laten bevestigen!. Anders zit jij straks met de gebakken peren omdat een server omzeep is.
  • Bor
  • Laatst online: 00:20
Bor
Coördinator Frontpage Admins / FP Powermod
01000010 01101111 01110010
mutsje schreef op dinsdag 27 september 2005 @ 13:40:
Je moet natuurlijk altijd wel zorgen voor een goede backup en disaster recovery procedure wanneer je dit gaat doen. Het feit dat dit gewoon over dag kan is al een teken dat deze server niet zo heel belangrijk is imho.
Over Bor | Vraag & Aanbod feedback | Frontpagemoderatie Forum
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
Bor de Wollef schreef op dinsdag 27 september 2005 @ 13:43:
Het kan er ook op wijzen dat de TS zich niet helemaal realiseert wat hij aan het doen is.
  • BMW_M3
BMW_M3
Ondertitel
EJVL schreef op dinsdag 27 september 2005 @ 13:32:
Ja heb ik al gedaan en de programma draait nu ook en de users kunnen drbij.. ( het was meer als een "testserver" bedoeld dus ik kon er niet egt veel aan verknoeien maar na wat dingen te hebben uitgeprobeerd is het me tog gelukt.
Thnx allemaal de topic mag dicht,
Signature
  • Ora et Labora
Als je aangeeft dat de licentie's van de client moeten komen, hoef je toch geen TScalls aan te schaffen? Mits je natuurlijk een OS gebruikt bij de clients zoals Winxp Prof die dit ondersteund.
Zo hebben we het al jaren draaien.
  • mutsje
mutsje
Certified Prutser
Heb je dan 2003 TS Server draaien met deze constructie?
  • Ora et Labora
mutsje schreef op dinsdag 27 september 2005 @ 15:44:
Nee hoor, win2k advanced server
  • mutsje
mutsje
Certified Prutser
EJVL schreef op dinsdag 27 september 2005 @ 15:54:
met TS bedoel ik Terminal Server waar je dus TSCALLS voor nodig hebt. met het 2000 OS kun je inderdaad zonder met het 2003 OS is de licentie structuur veranderd.
  • elevator
elevator
Officieel moto fan :)
Dit heeft verder geen zin zo -
BMW_M3 -
Wij zijn natuurlijk geen basiscursus 'Hoe installeer ik een server', jouw bedrijf heeft een systeembeheerder in dienst (toevallig jouw stagebegeleider ook ofzo?) en die is verantwoordelijk voor dit soort zaken. Met de inzet danwel kennis van zaken die jij hier tentoonstelt is het niet mogelijk om je verder te helpen - je probeert namelijk een marathon te lopen daar waar je nog nauwelijks op twee benen kan staan
