Tetrinet
  • 216 views sinds 30-01-2008
  • Elect
Op de Tweakers.net chat op sorcery worden nu wel eens (newbie) terinet spelen gehouden ..
Maby dat er wel mensen willen meedoen.
De file is hier te downen: Tetrinet
Tis niet zo'n heel moeilijk spel, gewoon tetris, maar dan met wat extra opties om het elkaar zo moeilijk mogelijk te maken (kan met 6 man tegelijk)
ff een cut&paste uit de readme:
occasionally a sphere block with a letter will appear in
your playing field. When you make one or more lines with
any of the lines containing one or more of these special
blocks, the special blocks in the lines will be added
to your inventory which is located near the bottom of the
window. These special blocks do different things to players.
en hier zijn alle Specials:
'A' Block: This is the add line block. It will add a "junk line" to the players field that you choose.
'C' Block: This is the clear line block. It clears the line farthest to the bottom in the playing field.
'N' Block: This removes all blocks from a playing field giving the player a "fresh start".
'R' Block: This removes 10 random blocks from a player's field.
'S' Block: This switches your playing field with another player's field depending on which player number you pressed. If either of the fields' block stack is over 16 blocks high, the stack will be lowered.
'B' Block: This removes all special blocks from a players field.
'G' Block: This "gravity" block takes all the blocks on the field and "pulls" them all towards the bottom of the field eliminating any gaps in the blockstack.
'Q' Block: This causes each of the lines of blocks on a players field to randomly shift left or right or not at all.
'O' Block: This is the block bomb, when used on a player, it clears 3x3 portions on their field anywhere there are 'o' blocks. Any blocks that were in the 3x3 areas are scattered around the field.
Je kunt joinen op de Nederlandse server 4 Tweakers :)
IP: elect.mine.nu
De server is 24/7 dus je kunt altijd aanloggen ...
en met een beetje mazzel zitten er altijd wel mensen ..
ff nog een laatste "waarschuwing" als je begint: Zorg dat onder je Misc Setting in het programma de onderste regen (Graphic/sound/theme) ingesteld staat op de deafault.* die in je tetrimap staat, anders doet ie ut niet bij het spelen !!
  • Zoetemelk
  • Laatst online: 18-10-2024
Hmmm tis wel heeeeeel lang geleden dat ik tetrinet speelde...misschien kan ik het nog een beetje :) denk dat ik binnenkort wel ff een keer ga kijken..
  • Elect
ARG, net verloren van luite .. terwijl ik er zo goed voorstond met veel special bloks ;(
  • Kaj.
Kaj.
1 LED is niet genoeg
----> Spielerei
  • Elect
doen er nog meer mensen mee ?
(of willen er nog meer mensen meedoen :))
  • Tim
  • Laatst online: 23-07 15:18
Tim
Webby was bezig een wedstrijd te organiseren.. Weet niet hoe het daar mee zit.. In #got-onzin werden ook wel eens tertniet wedstijdejs gehouden..
Als er nog ff wat mensen komen
elect is er nu en ik ook
Kom op mensen joinen !!!
dit spel is echt kewl
:9~
yup klopt..
ben ik nog steeds mee bezig lay-out heb ik nu al bijna af maar ben nu erug druk met school dat zuigt enorm maar laatste tijd hebben we heel veel laatste paar uur vrij en dan ben ik nog wel es bezig ermee
php scriptz zijn al af duse das belangerijkste =)
dusse nog eff w88 =)
  • Elect
waarom vergeet iedereen nou de texture file goed te zetten ????
ik heb met de nieuwe zip de standaart directory naar c:\tetrinet gezet, en daar ook de texture file naar verwezen ..
als iedereen dat nou gewoon laat staan zou het misschien voor ons ook wat makkelijker zijn :)
Elect kijk eens op de server ik ben er =)
ook weer eff wennen heb ook al tijdje niet meer gespeelt =)
  • Elect
zijn er nog meer mensen die mee willen doen?
tis namelijk niet zo druk rond 12 uur eigenlijk ... :)
  • Tokus
  • Laatst online: 26-10 12:46
Ik kwam soms op ascetic.net, maar laatste tijd ook niet echt meer.
  • kazuka
  • Registratie: Juli 1999
kazuka
Building Better Worlds
die elect doet ut nie hoor :P
  • Elect
doet ut niet ??
ip: elect.mine.nu ...
100% zeker dat ie ut doet aangezien ik hier ana het chatten bij op tetrinet :)
  • kazuka
kazuka
Unable to locate server zegt ie :?
misschien werkt het wel op IP met nummers ?
  • Elect
neu, anders zou het knap zijn dat je met 6 man in het kanaal zit :)
  • Elect
heb het ip ff opgezocht (als je me niet gelooft :)) het is 62.238.65.117
  • kazuka
kazuka
Sjit, krijg 't niet voor elkaar hoor, Tetrinet.org werkt wel gewoon maar de jouwe |:(
Nu kom ik er ook niet meer in
Nu weer wel
}:O
  • Elect
kazuka, op wat voor gare verbinding zit jij? :)
Niemand is op de server =((((
  • LoekieLeeuw
LoekieLeeuw
Finishing move: Batista Bomb
(overleden)
Jammer er is maar 1 iemand online, en die reageert niet... :(
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning.
  • LoekieLeeuw
LoekieLeeuw
(overleden)
hee, waarom is de server elect.mine.nu uit de lucht??
Weet iemand nog andere tetrinet servers??
probeer eens : 212.187.100.184
  • Zoetemelk
hmm ik ben helemaal alleen op die elect server :(
iemand zin een spelletje??
wow dit is oud! en ik speel het nog steeds op server tetrinet.org (mainserver)
ranking is trouwens 126ste
blijft verslavend :p
(ps. download van www.tetrinet.org)
[ Voor 14% gewijzigd door Verwijderd op 09-12-2003 22:46 ]
  • BasieP
  • Laatst online: 19-10-2025
oei ik speelde altijd met luna en dian en shadowgirl en whisler enzo.. is al xx maanden (misschien wel jaar) terug...
lui van irc.tweakers.net #huiskamer iig
stond altijd 2de :P dian was te goed ;)
[ Voor 12% gewijzigd door BasieP op 09-12-2003 22:48 ]
This message was sent on 100% recyclable electrons.
  • Kettrick
  • Laatst online: 10:00
Kettrick
Rantmeister!
* Kettrick speelt nu op tetrinet.org server :)
  • Gremen
  • Laatst online: 18-10 15:42
Lol net weer eens gespeeld :D
  • Crash
  • Laatst online: 19:29
Bedankt voor deze bijdrage aan een slotje :|
