Ik vraag me af of het beter is om ook op de timeline zelf gebruik te maken van het sleutelwoord this? Dus: this.createEmptyMovieClip() etc. Graag hoor ik jullie mening.Flash ActionScript:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 Using the this keyword Whenever possible, use the this keyword as a prefix instead of omitting the keyword, even if your code works without it. You can use the this keyword to learn when a method or property belongs to a particular class. For example, for a function on the main Timeline, write ActionScript using the following format: circle_mc.onPress = function() { this.startDrag(); }; circle_mc.onRelease = function() { this.stopDrag(); }; For a class, you can write code in the following format: class User { private var m_username:String; private var m_password:String; function User(username:String, password:String) { this.m_username = username; this.m_password = password; } public function get username():String { return this.m_username; } public function set username(username:String):Void { this.m_username = username; } }
[ Voor 5% gewijzigd door Verwijderd op 23-09-2005 14:55 ]
