Error tijdens installatie demo AOE 3
Hallo
Op het eind van de installatie krijg ik onderstaande fouten.
Heb reeds 2 installatiefiles gedownload, 2 keer zelfde fout.
Wat kan het probleem zijn ?
Bedankt
Dimitri
Afbeeldingslocatie: http://home.tiscali.be/sjock2005/aoe3-1.gif
Afbeeldingslocatie: http://home.tiscali.be/sjock2005/aoe3-2.gif
  • mrboomblaster
  • Laatst online: 18-07 11:33
mss dat hier wat bij staat voor je?
Error 1603 is a generic machine-specific issue. One or more of the following fixes may resolve the error.
1. This error is known to occur on computers that do not have enough disk space for the installation. To increase your hard disk space, follow the instructions in How Do I Increase Hard Disk Space on My Computer?
2. The Temp directory is not clean. To clean the Temp directory, follow the instructions in Clean the Temp Directory.
3. A certain file on the machine is locked. To fix this:
1. Close all applications running in the background.
2. Reboot your computer.
3. Run the installation again.
4. If you are using Windows 95, 98, ME, 2000, or NT, the Windows Installer Service may not be properly installed on the machine. Update the system with the latest Windows Installer Service by following the instructions in How Do I Install the Windows Installer Engine on My Computer?
5. On Windows NT, 2000, or XP, make sure you have administrative privileges. To confirm you have administrative privileges, follow the instructions in Acquire Administrative Privileges on Your Computer.
6. Use Microsoft’s Windows Installer Cleanup utility to remove traces of previous installations. This utility does not remove files installed by the installation, which may need to be removed manually. For more information, refer to Microsoft’s Knowledge Base article Description of the Windows Installer CleanUp Utility.
D2 acc: *Mrboomblasterhc
  • Crash
  • Laatst online: 19:36
Hoi, en welkom op GoT :)
Je topicstart is zeer karig, en zoals mrboomblaster al laat zien heb je zelf niet al te best gezocht naar een oplossing of de oorzaak van het probleem. Verder mist er belangrijke informatie zoals je system specs, drivers en relevante software. Wij verwachten van onze users dat ze zelf de moeite nemen om tot een oplossing te komen en anders een zo goed mogelijke topicstart in elkaar steken.
Vul dus aub je topicstart aan, anders gaat hier een slotje op. En resize dan ook gelijk even je plaatjes ;)
