/var/log/syslog en messages zijn beide leeg.
dmesg geeft
Linux version 2.6.8.1-12mdk (quintela@n5.mandrakesoft.com) (gcc version 3.4.1 (Mandrakelinux (Alpha 3.4.1-3mdk)) #1 Fri Oct 1 12:53:41 CEST 2004
BIOS-provided physical RAM map:
Linux Plug and Play Support v0.97 (c) Adam Belay
PnPBIOS: Disabled
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
PCI: Enabled i801 SMBus device
PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
PCI: Transparent bridge - 0000:00:1e.0
PCI: Using IRQ router PIIX/ICH [8086/24c0] at 0000:00:1f.0
PCI: IRQ 0 for device 0000:00:1f.3 doesn't match PIRQ mask - try pci=usepirqmask
PCI: Found IRQ 9 for device 0000:00:1f.3
PCI: Sharing IRQ 9 with 0000:00:1f.5
ICH4: IDE controller at PCI slot 0000:00:1f.1
PCI: Found IRQ 9 for device 0000:00:1f.1
PCI: Sharing IRQ 9 with 0000:00:1d.2
USB Universal Host Controller Interface driver v2.2
PCI: Found IRQ 5 for device 0000:00:1d.0
PCI: Sharing IRQ 5 with 0000:01:00.0
uhci_hcd 0000:00:1d.0: UHCI Host Controller
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: irq 5, io base 0000d800
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
PCI: Found IRQ 9 for device 0000:00:1d.1
uhci_hcd 0000:00:1d.1: UHCI Host Controller
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: irq 9, io base 0000d400
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
PCI: Found IRQ 9 for device 0000:00:1d.2
PCI: Sharing IRQ 9 with 0000:00:1f.1
uhci_hcd 0000:00:1d.2: UHCI Host Controller
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: irq 9, io base 0000d000
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
usb 2-2: new low speed USB device using address 2
PCI: Found IRQ 11 for device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: EHCI Host Controller
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: irq 11, pci mem f89e5000
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 4
PCI: cache line size of 128 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: USB 2.0 enabled, EHCI 1.00, driver 2004-May-10
usb 2-2: can't set config #1, error -71
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 6 ports detected
usb 2-2: new low speed USB device using address 4
EXT3 FS on hda5, internal journal
Adding 1630556k swap on /dev/hda6. Priority:-1 extents:1
usbcore: registered new driver hiddev
input: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1d.1-2
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
usbcore: registered new driver usbmouse
drivers/usb/input/usbmouse.c: v1.6:USB HID Boot Protocol mouse driver
ts: Compaq touchscreen protocol output
Linux video capture interface: v1.00
bttv: driver version 0.9.15 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
PCI: Found IRQ 9 for device 0000:02:0a.0
PCI: Sharing IRQ 9 with 0000:02:0a.1
bttv0: Bt878 (rev 17) at 0000:02:0a.0, irq: 9, latency: 32, mmio: 0xee800000
bttv0: subsystem: 107d:6609 (UNKNOWN)
please mail id, board name and the correct card= insmod option to kraxel@bytesex.org
bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=003ff502 [init]
bttv0: using tuner=-1
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: registered device video0
bttv0: registered device vbi0
Linux agpgart interface v0.100 (c) Dave Jones
agpgart: Detected an Intel 845G Chipset.
agpgart: Maximum main memory to use for agp memory: 941M
agpgart: AGP aperture is 64M @ 0xf8000000
kjournald starting. Commit interval 5 seconds
EXT3 FS on hda7, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
Supermount version 2.0.4 for kernel 2.6
NTFS driver 2.1.15 [Flags: R/O DEBUG MODULE].
NTFS volume version 3.1.
loop: loaded (max 8 devices)
hdc: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
b44.c:v0.94 (May 4, 2004)
PCI: Found IRQ 9 for device 0000:02:05.0
PCI: Sharing IRQ 9 with 0000:02:0c.0
eth0: Broadcom 4400 10/100BaseT Ethernet 00:e0:18:af:c2:d6
Loaded prism54 driver, version 1.2
PCI: Found IRQ 9 for device 0000:02:0c.0
PCI: Sharing IRQ 9 with 0000:02:05.0
inserting floppy driver for 2.6.8.1-12mdk
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
NET: Registered protocol family 17
PCI: Found IRQ 9 for device 0000:00:1f.5
PCI: Sharing IRQ 9 with 0000:00:1f.3
PCI: Setting latency timer of device 0000:00:1f.5 to 64
bootsplash 3.1.6-2004/03/31: looking for picture.... found (800x600, 10377 bytes, v3).
bootsplash: status on console 0 changed to on
bootsplash: status on console 1 changed to on
bootsplash: status on console 2 changed to on
bootsplash: status on console 3 changed to on
bootsplash: status on console 4 changed to on
bootsplash: status on console 5 changed to on
cdrom: hdc: mmc-3 profile capable, current profile: 9h
ISO 9660 Extensions: Microsoft Joliet Level 3
ISOFS: changing to secondary root
Ik heb nog een lan kaart, welke uit staat bij het opstarten, net zoals mijn wlan kaart trouwens. Ik wil elke keer handmatig mijn wlan kaart aanzetten en dus niet automatisch bij het opstarten.
