Asus W3x
Iemand ervaring met deze laptop? Ik ben er wel naar geinteresseerd maar kon maar weinig erover vinden op dit forum.
Plaatjes:
http://www.laptops4u.nl/laptopinfo?n=(Detail)foto's%20Asus%20W3V&pagina=120
Specs:
Processor
Intel® Pentium® M processor 730 - 770, 533MHz, 1.60-2.13GHz, 2MB L2 Cache
Chipset
Intel 915GM (W3A)/ 915PM (W3V)
BIOS
AMI 4MB Flash EPROM, PMU, Plug & Play
Boot from IDE ODD and USB FDD
Intel OSB Requirement
Support Power4 Gear Function
Support Pad-Lock Function
Display
14" WXGA (1280x768) Glare-Type LCD
Video
ATI Mobility™ Radeon™ X600 , 64MB VRAM
Memory
DDR2 400/533 DRAM, 2x SO-DIMM socket expandable to 2Gb
Storage
2.5” 9.5mm IDE HDD /w Ultra DMA/133 / S.M.A.R.T. supported
40 / 60 / 80GB supported
DVD-Dual
DVD-R/RW: 8X/4X or 4X/2X,
DVD+R/RW: 8X/4X or 4X/2.4X,
CD-R/RW:24X/10X or 16X/10X,
DVD-ROM:8X,
CD-ROM: 24X
Swappable Bay support (Hot Swappable)
4-in-1 cardreader: SD/MMC/MS/MS PRO
Connections
Integrated V.92 MDC Fax/Modem, with AC-Link Version. 2.1 Compliant
AC 97 s/w MODEM and 10/100/1000 Base T
PCI LAN on board
Pass and support worldwide regulation
IEEE 802.11g
Built-in Bluetooth™
Audio
Built-in Azalia compliant audio chip, with 3D effect & full duplex
Built-in speaker and microphone
Audio-DJ for play/pause, stop, forward, rewind
Interfaces
1x VGA port/Mini D-sub 15-pin for external monitor
1 x Headphone-out jack (SPDIF)
1 x Microphone-in jack
1 x RJ11 Modem jack for phone line
1 x RJ45 LAN Jack for LAN insert
3 x USB 2.0 ports
1x IEEE 1394 port
1 x TV Out (S-Video composite)
1 x Type II PCMCIA 2.1 compliant
1 x SIR-115.2Kbps supported
1 x Infrared Port
LED Status Indicator
Power On/Suspend, Battery Full /Charging/Low, Email, WLAN Accessing/Activity, Audio DJ Accessing/Activity, Storage Access, Caps Lock, Number Lock
Hot keys
Instant launch Keys
4 buttons: Power4 Gear +, Email, Internet, Touchpad Lock
Function Keys
Fn+F1 Suspend switch
Fn+F2 Wireless switch
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT switch display
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Powersupply & Battery
Output: 19 V DC, 3.42 A, 65W
Input: 100— 240V AC, 50/60Hz universal
8 cells & 4cells, 4800mAh / 2400mAh, 70/35Whrs
2nd battery module supported
2nd battery module supported(6-cell Hot Swappable Battery Module)
Software
ASUSDVD XP 5.0
Power Director V3.0 DE
Medi@Show V2.0 SE
Symantec Norton AntiVirus 2005
Adobe Acrobat Reader 5.1
NERO Express V 6.3
ASUS NB Probe
ASUS Live Update
ASUS ChkMail
ASUS Hotkey
ASUS Power4 Gear+
Keyboard & special controls
19 mm full size 88key with MS-Windows function keys
2.35mm travel
Security
BIOS Booting User Password Protection
HDD User Password Protection and Security Lock
Kensington Lock hole provided
Weight/ Dimensions
330 x 247 x 30-32.7 mm (W x D x H)
2 Kg (4-cell battery, traveler’s drawer)
Operating System
Operating system: Microsoft® Windows XP HOME NL version
Accessoiries
Optical Mouse
Multi-functional carrying bag
USB Pendrive 128MB (Asus AI Flash 128MB)
Warranty
2-year limited global hardware warranty
1-year battery pack warranty
On-line problem resolution through web interface (BIOS, Driver update)
OS (Microsoft Windows XP) install/uninstall consultation
Bundled software install/uninstall consultation
ASUS software supporting (Liveupdate,Power4 Gear+, ASUS Probe)
Review:
http://www.mobile-review.com/nb/review/asus-w3-en.shtml (beetje bagger vertaald, maarja)
  • Just_I
  • Laatst online: 12-10 21:36
Just_I
What did you just say?
Mja, er kunnen best mensen zijn hier die ervaring hebben met die laptop. Maar er blijft toch de vraag wat je wilt weten? Alleen een lijstje met specs hier posten en vervolgens vragen of er ervaringen mee zijn is niet genoeg.
[ Voor 3% gewijzigd door Just_I op 04-09-2005 18:36 ]
\o\o\o\o\o\o\o\o\o\o \o\o\o\o \o\o\o\o\o\o \o\o\o\o\o\o\o \o\o\o\o\o\o \o\o\o \o\o\o\o\o\o\o \o\o\o\o\o\o\o\o\o \o\o\o\o\o\o\o
Ten Thousand fists in the air! \o
  • pegox
  • Laatst online: 25-09 15:12
Ok, hier is een concrete vraag. Deze laptop schijnt maar een probleem te hebben: de warmte productie. Vooral de harde schijf schijnt overmatig veel warmte te veroorzaken. Aan de eigenaars van een W3x: 1) is de warmte storend tijdens gebruik (warme palmrests? hete lucht uit airvent opzij?) 2) hoe warm wordt de harde schijf (bvb tijdens "gewoon" gebruik of bij gamen)?
  • pegox
Voor meer algemene info over de W3x: zie www.notebookforums.com. Het Asus forum staat vol met W3V reviews, foto's, etc... De W3x (vooral de W3V) blijkt zeer populair te zijn in de states, hier vooralsnog niet helemaal...
Inmiddels heb ik de Asus W3V een paar dagen en ben er superblij mee! Het scherm is echt prachtig, en de laptop ziet er ZO goed uit. Het is niet zoals meestal dat het plaatje er goed uit ziet op internet, maar dat de laptop er in het echt lelijk uit ziet. Kvind h'm mss nog wel mooier nu ik h'm irl zie. Vooral die power button aan de zijkant is zo cool _/-\o_ Jammere is alleen dat er al wel veel programma's op staan als je de recovery van windows draait. Kheb 52 processen zonder zelfs iets te instaleren! Maarja die kan ik er natuurlijk afgooien. Kheb er nog 512 mb 533 mhz bij laten zetten, dus in totaal nu 1024 mb kingston 533 dual channel.
Last but not least. Kwil ff me waardering kwijt over Laptops4u. Helaas kan ik in de shopsurvey niet reageren omdat ik geen account heb en geen email adres van mijn internet provider. Ik heb maandag (deze week) de Asus W3V bestelt en gevraagd op 1024 mb 533 mhz Kingston. Me order verzonden en na 5 minuten was de order al in behandeling en goedgekeurd, en ik kreeg een gig Kingston geheugen. Elke keer als er een wijziging in status was kreeg ik een mailtje. En de volgende dag werd ik al op gebeld of ze de laptop konden langs brengen!! _/-\o_ De volgende dag rond 4 uur had ik de laptop al in mijn bezit. Kon gemakkelijk met pin betalen. Kheb wel vaker iets via internet besteld, maar dat ik het de volgende dag ook daadwerkelijk kreeg geleverd heb ik nog nooit meegemaakt. Echt hulde. Scherm was al op pixels gecheckt... Kheb voor de zekerheid pixelgarantie genomen.
  • Delerium
Delerium
Mythology
mm, als ik dat ding zo eens bekijk is 'ie minstens net zo goed voorzien als de willekeurige andere bak. Echter, design en 14" en vooral de 2 kilo maken 'm nogal af.
Ik ga deze denk ik ook maar bestellen. HDD boeit me niet, ik heb er al eentje liggen.
Ecteinascidin schreef op donderdag 20 oktober 2005 @ 17:53:
ja mss dat wel maar je vindt echt niet zo snel een 14 inch widescreen. De meeste zijn 15 of 15.4" . Ik denk dat dit wel 1 van de beste 14 inch notebooks is.
  • Delerium
Delerium
Mythology
Ik bedoel in dit geval de finishing touch, dat 'ie tenminste beeldoppervlak heeft. Widescreen is leuk, maar heeft wel minder oppervlak..... en boeit me niet, ik heb een 24" widescreen.
Dus, 14" is een +, slechts 2 kilo en ook een X600. Warmte schijnt een issue te zijn, maar dat is gek genoeg de HD die dat doet. Nou zijn er smart-tools die het mogelijk maken om daaraan te sleutelen....
Ecteinascidin schreef op donderdag 20 oktober 2005 @ 20:44:
die 2 kilo is volgens mij zonder accu. Met accu is ie wel zwaarder. Hij is zwaarder dan ik had gedacht. Maar mij ging het meer om het formaat dan om het gewicht. Tillen kan ik het zoiezo zo wel of het nou 2 of 3 kilo is. Maar hij voelt wel stevig aan, dat is dan wel mooi...
