Apache Service problemen
  • Dionisus19
  • Laatst online: 27-03-2024
Dionisus19
Blah != Meuk
Holla,
Ik draai enige tijd apache2
Heeft altijd goed gedraait tot op vanavond
Errorlog:
[Fri Sep 02 22:41:29 2005] [error] (OS 10038)An operation was attempted on something that is not a socket. : Child 612: Encountered too many errors accepting client connections. Possible causes: dynamic address renewal, or incompatible VPN or firewall software. Try using the Win32DisableAcceptEx directive.
Deze melding herhaalt zich zegmaar 4 x per seconde totdat ik de service stop.
Na enig gegoogle, schijnt het dat er een oplossing is en dat zou zijn door de regel Win32DisableAcceptEx aan je config file toe te voegen.
Uiteraard gedaan, met als resultaat:
[Sat Sep 03 00:00:34 2005] [notice] Apache/2.0.54 (Win32) PHP/5.0.3 configured -- resuming normal operations
[Sat Sep 03 00:00:34 2005] [notice] Server built: Apr 16 2005 14:25:31
[Sat Sep 03 00:00:34 2005] [notice] Parent: Created child process 4064
[Sat Sep 03 00:00:34 2005] [notice] Disabled use of AcceptEx() WinSock2 API
[Sat Sep 03 00:00:34 2005] [notice] Child 4064: Child process is running
[Sat Sep 03 00:00:34 2005] [notice] Child 4064: Acquired the start mutex.
[Sat Sep 03 00:00:34 2005] [notice] Child 4064: Starting 250 worker threads.
[Sat Sep 03 00:00:34 2005] [notice] Child 4064: Listening on port 80.
[Sat Sep 03 00:00:34 2005] [error] (OS 10038)An operation was attempted on something that is not a socket. : Too many errors in select loop. Child process exiting.
[Sat Sep 03 00:00:34 2005] [notice] Child 4064: Exit event signaled. Child process is ending.
[Sat Sep 03 00:00:35 2005] [notice] Child 4064: Released the start mutex
[Sat Sep 03 00:00:35 2005] [notice] Child 4064: Waiting for 250 worker threads to exit.
[Sat Sep 03 00:00:35 2005] [notice] Child 4064: All worker threads have exited.
[Sat Sep 03 00:00:35 2005] [notice] Child 4064: Child process is exiting
[Sat Sep 03 00:00:35 2005] [notice] Parent: child process exited with status 0 -- Restarting.
Tevens krijg ik de melding:
[Fri Sep 02 23:52:18 2005] [notice] Disabled use of AcceptEx() WinSock2 API
bij het starten van de service.
OS: Win2003
Geen S/w firewall (ook niet die van Windows)
NAV corporate 8 virus scan.
Geen VPN en/of firewall software etc installed
Tevens kan ik ook nergens uit herleiden wat er fout gegaan is, als ik in Eventviewer kijk dan wordt ik er ook niet veel wijzer van, gezien het "all of a sudden" begon....
Help? :X
  • loodgieter
  • Laatst online: 27-10 11:59
loodgieter
Mars Vs. zie hieronder :)
In de commandprompt (cmd.exe) en dan naar de bin dir gaan van apache2
cd c:\programfiles\apache..\..\..\bin
apache.exe -k [start, stop of restart]
als je dat doet geeft die een foutcode mee misschien dat je daar wat kan uithalen
[ Voor 10% gewijzigd door loodgieter op 03-09-2005 00:31 ]
  • Dionisus19
Dionisus19
Blah != Meuk
Geeft geen foutcode mee tenzei ik Win32DisableAcceptEx in me config heb staan.
Dan krijg ik: [Fri Sep 02 23:52:18 2005] [notice] Disabled use of AcceptEx() WinSock2 API
in me command prompt
  • loodgieter
loodgieter
de apache site geeft soms ook wel uitkomst.
zie hier.
http://httpd.apache.org/docs/2.0/mod/mpm_winnt.html
draai je een Vscanner (McAfee bijv) of VPN achtig iets dan ligt het daar aan?
[ Voor 12% gewijzigd door loodgieter op 03-09-2005 00:39 ]
  • Dionisus19
Dionisus19
Blah != Meuk
No offence Twix... Maar als je niet de moeite neemt te lezen wat ik reeds gedaan heb, zeg dan maar nix!
  • loodgieter
loodgieter
Dionisus19 schreef op zaterdag 03 september 2005 @ 00:41:
Xcuus ik was meer geconcentreerd op de log :z . Misschien mogelijk dat je een nieuwe versie installeerd en dat je je *.conf file backupped incl alle toegevoegde files. kijken of het dan nog weer voorkomt.
  • Dionisus19
Dionisus19
Blah != Meuk
Current version is 2.0.54
Oudere versies hebben geen nut gehad (reinstall van current version ook niet)
Tevens vind ik het nog steeds vreemd dat het "all of a sudden" begonnen is, ik zie niet dat er bepaalde services gestart zijn of dat er applications installed zijn op of rondom die tijd.
Ook het uitschakelen van NAV Corporate heeft geen nut gehad
  • loodgieter
loodgieter
ik weet dat je al gegoogled hebt dus ik weet niet of je deze link bent tegen gekomen ik geef heb je toch maar even. misschien dat je hier wat aan hebt
http://www.apache.org/dist/httpd/binaries/win32/
suc6!
  • Dionisus19
Dionisus19
Blah != Meuk
Nop... Ik zou ook niet weten wat ik aan de download dir van Apache zou hebben :S
  • loodgieter
loodgieter
Dionisus19 schreef op zaterdag 03 september 2005 @ 01:05:
ff naar beneden scrollen of die linkje aan kliken boven aan de download dir.
