Registercleaners
  • 2.681 views sinds 30-01-2008
  • DFC-Neo
  • Laatst online: 21-04-2022
DFC-Neo
PES FC 0817 3795 9910
Ik wil graag jullie ervaringen en meningen weten over dergelijke programma's. Ze zijn toch belangerijk om je pc in goede vorm te houden.
Helaas kan ik nog geen freeware registercleaner vinden. Ik heb wel deze kunnen vinden.
jv 16 tools2005 http://www.jv16.org/
Enkele features
  • Clean the system registry using the first AI (Artificial Intelligence) powered Registry Cleaner on the market
  • Generic MRU history data cleaner in the Registry Cleaner can flush the privacy-threatening MRU lists of hundreds of applications
  • Clean the History and MRU lists of many common Windows applications with the History Cleaner
  • List and remove even the most hidden registry traces of installed software with the Software Manager
  • Finally get rid of system modifications created by old software using the Registry Manager
  • Fix broken shortcut from the start menu and desktop with the Start Menu Fixer
  • Manage and take control of Cookies and web browser history items with the Cookie Manager and History Manager
  • Privacy Protector can clear all unwanted Cookies and History items at every system startup.
  • Find obsolete and not-used files, such as unused shared DLL and OCX files, unused fonts and leftover temp files with the File Cleaner
  • Analyze the contents of unknown files with the File Analyzer
  • Encrypt, merge, analyze, copy, mass rename or wipe files with the File Tool
  • Monitor what goes on inside the registry, undo the changes easily or remove the changed items with the Registry Monitor
  • The multilingual user interface allows you to use the program in all major languages or to translate it into your own language very easily
  • Automatic backup and safety features which can also be turned off
RegSupreme (pro) http://www.jv16.org/
  • Clean your computer's registry with one of the most advanced registry cleaner available today
  • Find and remove hidden traces of any installed software
  • Manage which programs automatically start with Windows
  • Uninstall or remove software from Windows' Add/Remove software list
  • Remove operating system interface features you don't need
  • Remove unneeded file types
  • Remove unneeded shell extensions
  • Remove items from Internet Explorer's context (right click) menu
  • Modify Windows' Open With menu
  • Automatic repair of found problems
  • The automatic backup feature makes backups of everything the program removes or modifies
Winrescue http://www.superwin.com/index.htm
RegPack the Registry
*Removes the mush and rebuilds the Registry decreasing the size of the Registry and allowing
Windows to run more effieciently.
Dit programma heeft heleboel features waar veel niet onder het register vallen. Waaronder back-up en terughalen van gegevens.
Ultra PC Cleaner http://www.superwin.com/index.htm
  • Avoids system errors and PC crashes by identifying and cleaning up problem files.
  • Removes hidden files that do nothing but take up space and slow down your computer.
  • The main scan of A1 Cleaner can be done in one of three ways:
  • Clean PC
  • With one click of a button, A1Click Ultra PC Cleaner goes through 45 processes to safely find and remove clutter on your computer. Some of these processes find useless, outdated files which Windows loves to hoard.
  • Remove Tracks
  • With the click of another button, A1Click Ultra PC Cleaner utilizes 25 processes of the latest technology to find Windows' secret records of your activity and remove them. This prevents others from spying on you. Some of these processes have yet to be discovered by other software.
  • Do-It-Yourself
  • A1Click Ultra PC Cleaner allows you to build your own assortment of 87 processes to clean and remove tracks on your computer. Once set up, these can be run with one easy click. This is called Run Settings in the program.
  • These bonus tools go beyond other cleaners and help you manage the messy rooms on your computer. The bonus tools are Duplicate File Finder, Font Remover, Recent List, Uninstaller, Registry Cleaner, and Favorites List.
  • No Remains Deletion
  • A1Click Ultra PC Cleaner incorporates a special 4 stage strategy when deleting files to insure that hackers will not be able to uncover them later. Without this strategy, deleted files can be rebuilt and used to spy on you.
  • By default, the questionable files that are deleted are saved for 7 days in undo zip files. You can change this to not save any files, to save all files temporarily or indefinitely, or any combination of this.
RegVac http://www.superwin.com/index.htm
  • Because your computer accesses the registry frequently, keeping it clean allows your computer to run faster and more efficiently.
  • Sloppy programmers exist in the most popular software companies. Their sloppiness puts your computer in danger of a crash. RegVac regularly cleans out their bugs.
  • Besides the normal dirt that RegVac and other registry cleaners clean, there are thousands of dirt piles hiding which other registry cleaners don't even attempt to get. You will find them in RegVac's Stash Vac, OpenWith Editor, and AutoComplete Editor. If you want to do a complete job at cleaning your registry, RegVac is the tool to have.
  • When something goes wrong in the Registry, it can cause Windows and/or applications to mess up. Reports are coming in from all over the world about how RegVac has fixed stubborn software problems.
  • RegVac is updated often to give you the best and latest in computer technology. Yet you only pay once for RegVac. All future updates of RegVac are free to registered users.
  • Are you a novice? Are you afraid that you will delete something that will mess up your computer? Then the RegVac's Novice Mode is for you. Novice Mode safely cleans the Registry with one click of the button.
  • One click of the button cleans up to seven sections: Classes, Stash, File Lists, Software, Bad Links, System Config, and Junk. Automation can be set up to run on startup daily, weekly, bi-weekly, or monthly.
  • Similar to RegClean, Classes Vac cleans the Classes section of the registry.
  • The registry is littered with history lists, recent lists, and tips. This tool removes 27 of the most common stashes and allows you to add the location of more stashes.
  • They abound all through the registry, references to files that no longer exist. This vac finds them and removes them.
  • The largest part of the registry is the Software section. This tool searches through the Software section and finds keys that may be left over from long deleted files.
  • Looks from one end of the registry to the other for references to files that do not exist on your computer. It then allows you to check and remove any of the bad entries.
  • This is actually the popular program, Add/Remove Pro. It checks your Add/Remove Programs list for programs that have already been deleted and allows you to uninstall programs, remove entries, and test entries.
  • This is a neat little Windows utility otherwise known as msconfig.exe. RegVac will open it for you. One disadvantage of this utility is that it does not actually remove entries from the registry. It only disables them. RegVac will remove entries disabled by msconfig.
  • Lists the extensions that are configured through the Open With... dialog box in Windows and allows you to remove them.
  • Every time you type something in a web form, it is saved in the registry. This editor allows you to remove the ones you want to.
  • Spyware and Adware love to put entries in your registry. This tool checks to see of you have any of the common ones and removes them.
  • Make full backups of the registry and restore them. Remove fragmentation from the registry files with Registry Pack.
  • The easily manageable Ignore List dictates what will be skipped during the scans.
  • If you want to undo something, Undo allows you to restore all registry settings removed by RegVac.
Dus post hier jullie ervaringen met deze programma's. Andere registercleaners zijn natuurlijk welkom.
realityalways start as a dream
  • Resistor
Resistor
Niet meggeren!
Niet echt een pure registrycleaner, maar EasyCleaner heeft ook een functie om het register op te ruimen.
EasyCleaner
http://personal.inet.fi/business/toniarts/ecleane.htm
[q]• Very nice interface!• Finds invalid registry entries ----> deleting them speeds up your computer!
• Finds duplicate files ----> deleting them will free disk space!
• Finds all unnecessary files like backups, temps etc. ----> deleting them will free disk space!
• Finds all invalid shortcuts ----> deleting them will free disk space and increase usability!
• Manage programs starting at Windows startup! ----> who knows, you might even catch a virus before it gets serious!
• Manage Windows' add/remove software listing!
• Easily remove Internet Explorer's temporary Internet files, history and cookies!
• Very user friendly!
• Shows some intresting info about your disk space usage.
• Very customizable.
• Multi-language support!
• Uses only little amount of recources while running!
• Huge help file which gives you every little detail about EasyCleaner!
• And much more...
Heel snel, maar ik heb niet het idee dat het erg nauwkeurig is, geen backupmogelijkheid voor verwijderen items.
What will end humanity? Artificial intelligence or natural stupidity?
  • Guardian Angel
Guardian Angel
Bejaard en langharig tuig
Regclean van Microsoft, freeware en voldoet.
ARME AOW’er
  • Rooster
  • Laatst online: 13:18
Ik heb hier ook een algemene 'cleaner', genaamd BeClean. Geen idee hoe hij is in vergelijking met andere programma's maar het is echt een no nonsence programma. Het programma gebruikt bij mij zo'n 10 mb van het interne geheugen, eigenlijk ook geen idee of dat veel of weinig is voor zo'n programma, maar het reageert goed :)
BeClean Features:
* Registry Cleaner, clean up registry entries from the files that no longer exist on the system
* Internet Cleaner, clean up internet cache and related
* History Cleaner, clean up common Windows applications recent file lists
* Temporary Files Cleaner, clean up temporary files
* Start Menu Cleaner, clean up Start Menu of broken links
* Desktop Cleaner, clean up Desktop of broken links
* Empty Recycle Bin, clean up all deleted files in the Recycle Bin
* Custom Cleaner, clean up your specified folders and registry keys
* Disk Clean Wizard, clean up your computer drives
  • frickY
  • Laatst online: 03-10 19:20
Heb nog nooit een register cleaner gebruikt en gok dat mn OS nu al ruim 5 jaar vlekkeloos draait.
Gewoon opletten met wat je installeerd, en altijd netjes deïnstalleren en niet zomaar de map wegflikkeren.
Dus snap niet waarom je het zulke belangirjke software vind...
  • DrivinUCrazy
  • Laatst online: 22:40
DrivinUCrazy
Vechte, valle en opstoan
@ FrickY: draai dan eens zo'n cleaner. Je komt gegarandeerd aan de 1000 fouten. (daarna kun je aangeven dat ze verholpen moeten worden, dus er is dan nog niets schadelijks gebeurd) Van die hoeveelheid fouten schrik je de eerste keer iig wel. De computer wordt er echt weer sneller door. Ik gebruikte Regsupreme, maar de probeerperiode is afgelopen. (dat is een maand, dacht ik)
  • Sayko
  • Laatst online: 13-09 16:19
Sayko
Knowledge Is Power
Das een goeie want ik heb nou net een goede cleaner nodig voor mn registry.
  • sanfranjake
sanfranjake
Computers can do that?
(overleden)
Wat zijn je eigen ervaringen met die regcleaners?
Mijn spoorwegfotografie
  • Borromini
Borromini
Mislukt misantroop
Ik vond BeClean ook heel goed werken... Freeware, doet z'n werk goed en snel. En ziet er best nog leuk uit ook :).
  • DFC-Neo
DFC-Neo
Ik heb altijd regcleaner gebruikt eerst toen het nog freeware was.
Nu is het helaas niet meer zo. Het heet nu regsupreme(pro). Je kan wel 30 dagen uitproberen. Het is snel en vind wel aardig wat maar niet alles. Al draai ik 1 van de andere programma's in mijn startpost vind ik er wel nog wat.
Dus aardig programma, genoeg optie, snel, overzichtelijk maar helaas geen freeware.
Misschien moet ik wel gewoon alle cleaners installeren. En 1 regelmatige gebruiken. En de andere af en toe nog laten nascannen. Het probleem is dat er geen testen voor dit soort programmas zijn.
[ Voor 22% gewijzigd door DFC-Neo op 29-08-2005 22:37 ]
  • Jeroen 98675432
  • Laatst online: 15-09-2021
Ik ben al een tijdje op zoek naar een (freeware) tool om automatisch alles wat naar een specifiek pad verwijst, uit de Registry te verwijderen.
Bijvoorbeeld: alles uit het register verwijderen waar het pad C:\Program Files\ApplicatieX\ in voorkomt, maar zonder dat deze directory ook daadwerkelijk verwijderdt wordt.
(vergelijkbaar met F3 - zoeken op padnaam, en Delete in RegEdit, maar dan automatisch)
Iemand een tip? :)
  • Maestro.mosjuh
ik heb het idee dat regcleaners soms meer kwaad dan goed doen... maar dat kan ook alleen een gevoel zijn.
is het wel echt nuttig om ze te draaien (haal je er ook winst uit?)
At the beginning there was nothing. So God said 'apt-get install light'.
wat dacht je van regcleaner
http://www.worldstart.com...chives/reg-cleaner4.3.htm
je kan aparte entry's wegooien
opstart entry's
automatisch opschoonen
uninstall menu entry's weggooien
file type's
en shell extensies
en er zit een backup functie op zodat je bij foute verwijdering het weer gewoon terug kan zetten
makkelijke user interface
en het is gratis _/-\o_
ik gebruik het al jaren nog nooit probleemen mee gehad wat wil je nog meer
  • Jeroen 98675432
...wat wil je nog meer
Nou, dit bijvoorbeeld
Ik wil namelijk een padnaam in kunnen geven, en hoppeta, Delete All, zonder dat de mappen zelf worden weggemikt, die moeten namelijk blijven staan, samen met alle data die er in zit. Dit kan ik ook in regcleaner niet vinden.
Overigens werkt die regcleaner onder XP alleen als de compatibility mode in Windows 2000 wordt gezet.
Laat dat laatste maar zitten, die regcleaner werkt absoluut niet goed onder Windows XP SP2.
Als je naar de site van de maker gaat, dan blijkt het een verouderde versie te zijn van de huidige producten van http://www.jv16.org/
[ Voor 14% gewijzigd door Jeroen 98675432 op 09-09-2005 11:32 ]
Tuneuputilities werkt goed, je kunt ook zoeken naar strings etc alleen kun je die dan alleen stuk voor stuk verwijderen en niet allemaal ineens. En het programma is niet gratis. (wel trialware)
Het programma stelt je tevens in staat om je hele XP-settings door te lichten qua verbindingsnelheden, processorgebruik, windows-opties etc.
Your TuneUp Utilities advantages:
    * Personalizes your Windows desktop
    * Frees your system of unnecessary clutter
    * Improves the performance of your PC
    * Accelerates your internet connection
    * Defragments your registry
    * Frees up system memory
    * Gives tips about hardware and software
    * Displays detailed system information
    * Recovers accidentally deleted files
    * Destroys sensitive information
http://www.tune-up.com/products/tuneup-utilities/details/
[ Voor 45% gewijzigd door Verwijderd op 09-09-2005 11:59 ]
ik gebruik al jaren Microsoft Regclean. Heel eenvoudig maar werkt goed.
En Gratis
  • Skaah
Ik vraag me af of zo'n register cleaner eigenlijk wel zin heeft. Verandert er echt iets aan je systeem?
  • Remy
  • Laatst online: 30-09 09:31
Remy
I usually get 100% accuracy
Skaah schreef op vrijdag 09 september 2005 @ 12:58:
De loze bagage wordt natuurlijk eruit gemikt zodat je registry sneller wordt geladen: ook is er minder kans op fouten doordat je registry 'schoon' is van orphan verwijzingen. Dus ja: het heeft wel degelijk zin :)
LinkedIn
Instagram
Kweet niet of dit topic te oud is :X
Kheb net A1click ultra pc cleaner geïnstalleerd want mijn explorer.exe is echt enorm instabiel , constant crashen enzo.
omfg , 17000 24000 :/ problemen and counting
en 2 3.5 GB (veronderstel dat dat nutteloze data is )
het grootste gedeelte lijkt in cache en temp folders te zitten.
Afbeeldingslocatie: http://img177.imageshack.us/img177/1329/regclean2sn.gif
zou het echt? :7
[ Voor 31% gewijzigd door Verwijderd op 22-04-2006 19:08 ]
  • Spider.007
Spider.007
* Tetragrammaton
Waarom schop je een oud topic met een popup wat zo te zien gewoon een stuk spyware is?
Prozium - The great nepenthe. Opiate of our masses. Glue of our great society. Salve and salvation, it has delivered us from pathos, from sorrow, the deepest chasms of melancholy and hate
Nu dit topic toch gebumpt is, leek me dit vergelijkend warenonderzoek toch een leuk linkje voor degenen die nog op zoek zijn naar dit soort software.
Spider.007 schreef op zaterdag 22 april 2006 @ 19:13:
ja sorry hoor ,en daarbij ik zei dat ik die regcleaner had geïnstalleerd , dat bericht kreeg ik toen het gedaan was met scannen.
XraYZ is een heel tevreden regseeker gebruiker
  • Bor
  • Laatst online: 22:25
Bor
Coördinator Frontpage Admins / FP Powermod
01000010 01101111 01110010
Verwijderd schreef op zaterdag 22 april 2006 @ 19:28:
Uiterst dubieus onderzoek waar je niet direct echt waarde aan moet gaan hechten. Effectiviteit is bv niet goed gemeten en de persoonlijke voorkeuren van de reviewer lijken ook aardig zwaar mee te wegen. Daarbij vind ik opties als "Clean Unneeded Junk, Temp, and Obsolete files" nou niet echt iets voor een pure reg cleaner.
[ Voor 11% gewijzigd door Bor op 22-04-2006 21:24 ]
Over Bor | Vraag & Aanbod feedback | Frontpagemoderatie Forum
  • artacis
  • Laatst online: 17-08 14:53
Wat dacht je van Registry TuneUp van Ace Utils?
  • The fastest, safest, and comprehensive utility to clean registry errors.
  • Built-in ignore list to protect many important registry entries.
  • Scan and clean all parts of registry.
  • Allows you to undo a cleaning if you want.
  • Expert / normal mode of registry cleaning.
  • Shows you why each entry in the registry is not needed.
Advanced
  • Auto decides whether to delete either the entire registry subkey or just the entry.
  • Expert users can view the registry entries ignored, and delete them if needed.
  • Scan and clean invalid ActiveX, Application Paths, Add-remove software, start menu order, shared dll section, font, help, IE context menu, IE toolbar, file extensions, and more from the registry . No other software scans this much in the registry.
  • Allows expert users to exclude selected registry entries permanently in the future.
http://www.acelogix.com/regtune.html
  • Bor
Bor
artacis schreef op zaterdag 22 april 2006 @ 21:31:
Advanced
Wat is je eigen ervaring met deze tool? No offence maar aan commercieel reklame geblaat van een website heeft echt niemand iets. Zeker niet omdat andere producenten met dezelfde kreten "the fastest and best" schermen in hun reclame praatjes.
Zelf heb ik goede ervaringen met RegSupreme. Kleine programma, redelijk goede detectie, mogelijkheid tot het maken van een backup zodat eventueel te veel weggehaalde zaken kunnen worden teruggezet. Hiernaast is ook Regsupreme behoorlijk snel.
Overigens snap ik sommige functies die in de eerder genoemde test worden opgenoemd niet echt. Wat moet je bv met een scheduler in een reg cleaner? Je dient imho altijd de te verwijderen registersleutels nog met de hand te controleren. Dit omdat veel van de programma's ook regelmatig toch iets te veel willen weghalen of zaken die je net niet wilde verwijderen. Daarnaast kun je elk programma natuurlijk schedulen met de normale scheduler van Windows zelf.
  • spacecom
  • Laatst online: 01-10 11:51
Wordt verschillend over gedacht 8)
Op XP-myts (http://mywebpages.comcast.net/SupportCD/XPMyths.html) vond
ik het volgende:
Myth - "Registry Cleaners improve performance."
Reality - "A few hundred kilobytes of unused keys and values causes no noticeable performance impact on system operation. Even if the registry was massively bloated there would be little impact on the performance of anything other than exhaustive searches. Registry Cleaners can fix problems associated with traces of applications left behind due to incomplete uninstalls. So it seems that Registry junk is a Windows fact of life and that Registry cleaners will continue to have a place in the anal-sysadmin's tool chest, at least until we're all running .NET applications that store their per-user settings in XML files - and then of course we'll need XML cleaners."
