Op maandag 15 januari 2001 12:49 schreef _Aphex het volgende:
Hoe kan ik dit hoger instellen, en als dit niet kan, wat heb ik dan precies aan die refresh rates? Is er een prog voor dat dit kan instellen?
100Hz is voldoende, draai ik namelijk ook.
Refreshrate:
The refresh rate is the amount of times a display's image is repainted or refreshed per second. The refresh rate is expressed in hertz so a refresh rate of 75 means the image is refreshed 75 times in a second. The refresh rate for each display depends on the video card used. You can change the refresh rate in the display properties. However, if you change the refresh rate to a setting that the display or video card cannot support, the display goes blank or the image becomes distorted. It is recommended to consult the display and video card manuals before changing the settings to determine the supported refresh rates.
An older refresh rate standard, developed by the Video Electronics Standards Association (VESA Local Bus), was only 60 Hz. This refresh rate caused the display's image to flicker causing eye fatigue and headaches in users. A new standard set the refresh rate to 75 Hz. It is believed that 70 Hz or higher eliminates the flicker. When purchasing a monitor, look for a refresh rate of 75 to 85 Hz.
Dynamic random access memory (dynamic random access memory) memory module also have a refresh rate. A DRAM module is made up of electrical cells. These cells must be recharged or refreshed thousands of times per second or they lose their data. The refresh cycles depend on the number of rows that must be refreshed. For example, a DRAM module that has 4 rows of cells has a refresh cycle of 4K. Some DRAM modules are able to refresh themselves independently of the processor or external refresh circuits. Since this reduces power consumption, this kind of DRAM is commonly used in notebook computers
Boven de 85Hz kunnen je ogen het niet meer registreren/zien., dus eigenlijk is 100Hz overkill, maar mijn monitor en kaart kunnen het aan, dus waarom niet.
