[review] Rollei DR5
Afbeeldingslocatie: http://www.digicamnews.net/Images/sm-rollei-DR5.jpg
Technical specifications
Sensor: 1/2.5“ CCD 5.0 megapixels
Image resolution: 2560 x 1920 pixels, 2048 x 1536 pixels, 1280 x 960 pixels, 640 x 480 pixels
Video clips (30 fps): QuickTime Motion, JPG 320 x 240 pixels, 160 x 120 pixels
Storage media: SD and MM cards
12 MB internal memory
Recording formats: JPEG (EXIF 2.2), TIFF, DPOF, AVI
Loudspeaker and microphone built-in
Lens: D-VarioApogon 4.6 – 22.2 mm f/3.3 – 4.8 HFT (approx. 28 – 135 mm in 35mm photography)
Zoom ranges: 4.8 optical, 3.6 digital
Focusing: Autofocus and manual
Focusing range: Autofocus, 30 cm to 8
Macrofocusing: 1 cm to 13 cm
Shutter: Mechanically and electronically controlled, 8 s – 1/2000 s, auto1/30 s – 1/2000 s (video)
ISO speed: Automatic or manual, equivalent to ISO 64, 100,200, 400, 800
Exposure metering: Evaluative, center-weighted average and spot metering
Exposure control: Program AE
Exposure compensation: manual Max. +/- 2,0 EV in 1/3 increments
Shooting modes: Single frames and continuous
White balance: Auto, manual; presets for sun, cloudy, tungsten, fluorescent
Flash: Auto, Off, red-eye-reduction autoflash, red-eye-reduction fill flash, slow sync
Flash ranges: 0.20 m – 2.70 m (W), 0.13 m – 2.10 m (T)
Viewfinders: Optical viewfinder plus LCD monitor
LC monitor: 1.8“ TFT-LCD monitor (110,000 pixels)
Self-timer: 2 s or 10 s delay
Interfaces: USB, video (NTSC, PAL),audio, AC
PictBridge compatible
Power supply: 2x type AA alkaline batteries (1.5 V), 2x type AA NiMH or NiCad batteries (1.2 V),1x lithium-ion battery, AC adapter (optional)
Tripod socket: 1/4“
Dimensions (mm/w x h x d): 100 x 55 x 25
Weight: Approx. 150 g (without batteries and SD card)
Camera kit: Rollei dr5, USB and video cables, standard batteries, wrist strap, driver CD, operating instructions, brief instructions
Prijs: 197 euro
Deze zomervakantie ben ik voor een nieuwe camera gaan kijken. Omdat ik naar de Dominicaanse Republiek ging, en mijn oude Trust 750 Powercam niet zo bijster goed was *kuch* , wilde ik een nieuwe. Mijn maximale budget was 200 euro.
Ik heb deze camera in Duitsland gekocht bij Lambertin Foto. Ik heb hem tevens ook bij de MediaMarkt in Köln gezien, voor dezelfde prijs.
Pluspunten van de camera:
* Snelle opstarttijd, binnen 1 seconde kun je al een foto maken
* 3x Optische zoom
* Prijs/kwaliteitverhouding was goed
* Videofunctie met optische zoom
* SD-kaart
* Robuust design
Minpunten van de camera:
* De sluitertijd is beperkt in te stellen (1,2,4,6,8 seconden)
* Geen ingang voor adapter
* Software om met de pc te verbinden is wat gaar. Hij wordt door XP niet herkend als een opslagapparaat. Je moet daarom de foto's met de bijbehorende software naar de pc downloaden.
Foto 1 Standaard instellingen, geen zoom gebruikt
Foto 2 Standaard instellingen, geen zoom gebruikt. Zelf vind ik dat er een beetje teveel ruis inzit.
Foto 3 Deze vind ik zelf best goed gelukt. De kleur van de lucht springt er als het ware uit. Wederom niets aan de instellingen gedaan. Wel heb ik een stuk ingezoomd.
Foto 4 Ook hier zie je het contrast van de wolken met de blauwe lucht. Wederom alles standaard, ook geen zoom gebruikt
[ Voor 19% gewijzigd door Verwijderd op 24-08-2005 15:39 ]
  • Silent Thunder
  • Laatst online: 03-05 19:14
Beetje magertjes voor een review-topic. Concreet gezien som je gewoon wat plus -en minpunten op.
De rest is copy/past specsinfo; en een onrelevant verhaaltje over het hoe en wat.
* Stop er nog iets meer van jezelf in; bijvoorbeeld sample pics ofzo.
* En vervolgens de kwaliteit tonen bij max./min. zoom, of bij een max./min. diafragma.
* Als je nog een 2e cam/webcam hebt: schiet dan ff wat pics van het apparaat zelf (voor, achterkant, etc).
-edit: aaah, ik zie dat je al het 1 en ander hebt veranderd; prima :)
[ Voor 46% gewijzigd door Silent Thunder op 24-08-2005 15:40 ]
