Een upgrade van MDK 10.0 naar 10.2 verloopt niet helemaal zoals het moet, helaas.
Ik wilde graag VNC-en maar de verbinding komt niet tot stand. Kwam er vrij snel achter dat X niet wilde starten. (dacht dit wel bij de installatie meegeinstalled te hebben)
[root@server misc]# kde
X Window System Version 6.8.2
Release Date: 9 February 2005
X Protocol Version 11, Revision 0, Release 6.8.2
Build Operating System: Linux 2.6.10-3mdksmp i686 [ELF]
Current Operating System: Linux server.mshome.net 2.6.11-6mdk #1 Tue Mar 22 16:04:32 CET 2005 i686
Build Date: 06 April 2005
Before reporting problems, check http://wiki.X.Org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 23 17:17:24 2005
(==) Using config file: "/etc/X11/xorg.conf"
Using vt 7
(EE) Failed to load module "/usr/X11R6/lib/modules/extensions/libglx.a" (once-only module, 136033795)
Fatal server error:
could not open default font 'fixed'
Please consult the The X.Org Foundation support
at http://wiki.X.Org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"
after 0 requests (0 known processed) with 0 events remaining.
In Xorg.0.log meld niks nieuws behalve
Fatal server error:
Echter geen idee hoe ik uit Putty tekst hier kan krijgen via MC, /etc/X11/xorg.conf heb ik wel aangepast via de wiki:
http://wiki.x.org/wiki/FA...03492ed07673aa3f73b6983f1
Somewhere (pretty much at the beginning of the log) there is a message:
Could not init font path element unix/:7100, removing from list!
Zo staat ie wel in de conf, maar word ie niet geladen!? (veranderd op advies topic)
bijgezet:
FontPath "/usr/X11R6/lib/X11/fonts/misc/"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
FontPath "/usr/X11R6/lib/X11/fonts/CID/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
Schijfruimte is ook geen probleem. XFS server is gestart. Wie kan me verder helpen?
Using vt 7
Fatal server error:
for help.
Fatal server error:
bijgezet:
