Ik heb een SVCD (avi + subs omgezet naar svcd) via nerovision express 3.1.0.16 gebrand.
Nu geeft ie een error tijdens het branden.
Heb al verschillende fora bezocht maar die kunnen niet met het antwoord komen. Hebben het over de firmware van de speler, maar deze is vrij nieuw (max 2 maanden terug gekocht).
Dit is (het laatste stukje van) de error log:
[19:14:46] NeroVision Book type: 'Automatic'
[19:14:46] NeroVision Properties of your project:
[19:14:46] NeroVision Aspect ratio: Automatic
[19:14:46] NeroVision Video mode: PAL
[19:14:46] NeroVision Quality: Automatic
[19:14:46] NeroVision Used disc space: 3.92 GB
[19:14:46] NeroVision Your project contains the following:
[19:14:46] NeroVision Sample format: Automatic
[19:14:46] NeroVision Audio format: Automatic
[19:14:46] NeroVision Encoding mode: Fast Encoding (1-Pass)
[19:14:46] NeroVision Number of titles: 1
[19:14:46] NeroVision 1. The Jacket (Video Title, 1h 43m 05s)
[19:14:46] NeroVision Aspect ratio: 4:3
[19:14:46] NeroVision Quality: Standard play (5073 kbps)
[19:14:46] NeroVision Resolution: 704 x 576 (D1)
[19:14:46] NeroVision Audio SmartEncoding ratio: 0.0 %
[19:14:46] NeroVision Video SmartEncoding ratio: 0.0 %
[19:14:46] NeroVision Number of menus: 1
[19:14:46] NeroVision - Main menu (1 page)***WEGGEHAALD***
[19:14:46] NeroVision ***WEGGEhAALD***
[19:14:46] NeroVision Windows XP 5.1
[19:14:46] NeroVision IA32
[19:14:46] NeroVision WinAspi: -
[19:14:46] NeroVision ahead WinASPI: File 'C:\Program Files\Ahead\NeroVision\NeroFiles\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26-10-2004 18:35:34
[19:14:46] NeroVision Nero API version: 6.6.0.16
[19:14:46] NeroVision Using interface version: 6.6.0.10
[19:14:46] NeroVision Installed in: C:\Program Files\Ahead\NeroVision\NeroFiles\
[19:14:46] NeroVision Application: ahead\NeroVision
[19:14:46] NeroVision Internal Version: 6, 6, 0, 16b
[19:14:46] NeroVision Recorder: <LITE-ON DVDRW SOHW-1673S>Version: JS02 - HA 3 TA 0 - 6.6.0.16
[19:14:46] NeroVision Adapter driver: <atapi> HA 3
[19:14:46] NeroVision Drive buffer : 2048kB
[19:14:46] NeroVision Bus Type : default (0) -> ATAPI, detected: ATAPI
[19:14:46] NeroVision === Scsi-Device-Map ===
[19:14:46] NeroVision DiskPeripheral : Maxtor 6Y160M0 atapi Port 1 ID 0 DMA: On
[19:14:46] NeroVision CdRomPeripheral : LITE-ON DVDRW SOHW-1673S atapi Port 3 ID 0 DMA: On
[19:14:46] NeroVision CdRomPeripheral : E-IDE CD-ROM 48X/AKU atapi Port 3 ID 1 DMA: Off
[19:14:46] NeroVision === CDRom-Device-Map ===
[19:14:46] NeroVision LITE-ON DVDRW SOHW-1673S F: CDRom0
[19:14:46] NeroVision E-IDE CD-ROM 48X/AKU G: CDRom1
[19:14:46] NeroVision =======================
[19:14:46] NeroVision AutoRun : 1
[19:14:46] NeroVision Excluded drive IDs:
[19:14:46] NeroVision WriteBufferSize: 83886080 (0) Byte
[19:14:46] NeroVision ShowDrvBufStat : 0
[19:14:46] NeroVision BUFE : 0
[19:14:46] NeroVision Physical memory : 1023MB (1047788kB)
[19:14:46] NeroVision Free physical memory: 428MB (438736kB)
[19:14:46] NeroVision Memory in use : 58 %
[19:14:46] NeroVision Uncached PFiles: 0x0
[19:14:46] NeroVision Use Inquiry : 1
[19:14:46] NeroVision Global Bus Type: default (0)
[19:14:46] NeroVision Check supported media : Disabled (0)
[19:14:46] NeroVision 16.8.2005
[19:14:46] NeroVision NeroAPI
[19:14:46] NeroVision 18:47:15 #1 Phase 111 File APIProgress.cpp, Line 276
[19:14:46] NeroVision DVD-Video files sorted
[19:14:46] NeroVision 18:47:16 #2 Text 0 File Reader.cpp, Line 127
[19:14:46] NeroVision Reader running
[19:14:46] NeroVision 18:47:16 #3 Text 0 File Writer.cpp, Line 122
[19:14:46] NeroVision Writer LITE-ON DVDRW SOHW-1673S running
[19:14:46] NeroVision 18:47:16 #4 ISO9660GEN -11 File geniso.cpp, Line 3309
[19:14:46] NeroVision First writeable address = 0 (0x00000000)
[19:14:46] NeroVision 18:47:17 #5 ISO9660GEN -11 File geniso.cpp, Line 3309
[19:14:46] NeroVision 18:47:17 #6 Text 0 File Burncd.cpp, Line 3233
[19:14:46] NeroVision Turn on Disc-At-Once, using DVD media
[19:14:46] NeroVision 18:47:17 #7 Text 0 File DlgWaitCD.cpp, Line 270
[19:14:46] NeroVision Last possible write address on media: 2298495 (510:46.45, 4489MB)
[19:14:46] NeroVision Last address to be written: 2031039 (451:20.39, 3966MB)
[19:14:46] NeroVision 18:47:17 #8 Text 0 File DlgWaitCD.cpp, Line 282
[19:14:46] NeroVision Write in overburning mode: NO (enabled: CD)
[19:14:46] NeroVision 18:47:17 #9 Text 0 File DlgWaitCD.cpp, Line 2483
[19:14:46] NeroVision Recorder: LITE-ON DVDRW SOHW-1673S, Media type: DVD-R
[19:14:46] NeroVision Disc Manufacturer: EuroDi - g-Disc
[19:14:46] NeroVision Disc Application Code: 64, Disc Physical Code: 193
[19:14:46] NeroVision 18:47:17 #10 Text 0 File DlgWaitCD.cpp, Line 448
[19:14:46] NeroVision >>> Protocol of DlgWaitCD activities: <<<
[19:14:46] NeroVision =========================================
[19:14:46] NeroVision 18:47:17 #11 Text 0 File ThreadedTransferInterface.cpp, Line 838
[19:14:46] NeroVision Setup items (after recorder preparation)
[19:14:46] NeroVision 0: TRM_DATA_MODE1 ()
[19:14:46] NeroVision 2 indices, index0 (150) not provided
[19:14:46] NeroVision original disc pos #0 + 2031040 (2031040) = #2031040/451:20.40
[19:14:46] NeroVision relocatable, disc pos for caching/writing not required/ required, no patch infos
[19:14:46] NeroVision -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2031040 blocks [LITE-ON DVDRW SOHW-1673S]
[19:14:46] NeroVision --------------------------------------------------------------
[19:14:46] NeroVision 18:47:17 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1051
[19:14:46] NeroVision Prepare recorder [LITE-ON DVDRW SOHW-1673S] for write in CUE-sheet-DAO
[19:14:46] NeroVision DAO infos:
[19:14:46] NeroVision MCN: ""
[19:14:46] NeroVision TOCType: 0x00; Session Closed, disc fixated
[19:14:46] NeroVision Tracks 1 to 1:
[19:14:46] NeroVision 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4159569920, ISRC ""
[19:14:46] NeroVision DAO layout:
[19:14:46] NeroVision __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
[19:14:46] NeroVision 0 | lead-in | 0 | 0x41 | 0x00
[19:14:46] NeroVision 0 | 1 | 0 | 0x41 | 0x00
[19:14:46] NeroVision 0 | 1 | 1 | 0x41 | 0x00
[19:14:46] NeroVision 2031040 | lead-out | 1 | 0x41 | 0x00
[19:14:46] NeroVision 18:47:19 #13 Phase 24 File APIProgress.cpp, Line 276
[19:14:46] NeroVision Caching of files started
[19:14:46] NeroVision 18:47:19 #14 Text 0 File Burncd.cpp, Line 4120
[19:14:46] NeroVision Cache writing successful.
[19:14:46] NeroVision 18:47:19 #15 Phase 25 File APIProgress.cpp, Line 276
[19:14:46] NeroVision Caching of files completed
[19:14:46] NeroVision 18:47:19 #16 Phase 36 File APIProgress.cpp, Line 276
[19:14:46] NeroVision Burn process started at 2x (2.770 KB/s)
[19:14:46] NeroVision 18:47:19 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2654
[19:14:46] NeroVision Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
[19:14:46] NeroVision 18:47:19 #18 Text 0 File DVDR.cpp, Line 2379
[19:14:46] NeroVision Recording mode: Sequential Recording Mode
[19:14:46] NeroVision 18:47:19 #19 Text 0 File Mmc.cpp, Line 21708
[19:14:46] NeroVision Set BUFE: Buffer underrun protection -> ON , SMART-BURN : ON
[19:14:46] NeroVision 18:47:19 #20 Text 0 File DVDR.cpp, Line 2534
[19:14:46] NeroVision Start write address at LBA 0
[19:14:46] NeroVision DVD high compatibility mode: Yes
[19:14:46] NeroVision 18:47:19 #21 Text 0 File Cdrdrv.cpp, Line 8862
[19:14:46] NeroVision ---- DVD Structure: Physical Format Information (00h) ----
[19:14:46] NeroVision Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
[19:14:46] NeroVision Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
[19:14:46] NeroVision Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
[19:14:46] NeroVision Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
[19:14:46] NeroVision Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
[19:14:46] NeroVision Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
[19:14:46] NeroVision End Physical Sector Number of Data Area: 0 h
[19:14:46] NeroVision End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
[19:14:46] NeroVision Data in Burst Cutting Area (BCA) does not exist
[19:14:46] NeroVision Start sector number of the current Border-Out: 0 h
[19:14:46] NeroVision Start sector number of the next Border-In: 0 h
[19:14:46] NeroVision Media Specific [16..63]:
[19:14:46] NeroVision 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
[19:14:46] NeroVision 18:47:48 #22 Text 0 File Cdrdrv.cpp, Line 1286
[19:14:46] NeroVision 18:47:48.921 - LITE-ON DVDRW SOHW-1673S\H3 T0 : Queue again later
[19:14:46] NeroVision 19:13:45 #23 Text 0 File WriterStatus.cpp, Line 116
[19:14:46] NeroVision <LITE-ON DVDRW SOHW-1673S> start writing Lead-Out at LBA 2031040 (1EFDC0h), lenght 0 blocks
[19:14:46] NeroVision 19:13:45 #24 Text 0 File ThreadedTransfer.cpp, Line 228
[19:14:46] NeroVision all writers idle, stopping conversion
[19:14:46] NeroVision 19:13:46 #25 Text 0 File DVDR.cpp, Line 2774
[19:14:46] NeroVision EndDAO: Last written address was 2031039
[19:14:46] NeroVision 19:14:44 #26 SCSI -1194 File Cdrdrv.cpp, Line 1180
[19:14:46] NeroVision SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x049D4A00
[19:14:46] NeroVision Status: 0x04 (0x01, SCSI_ERR)
[19:14:46] NeroVision HA-Status 0x00 (0x00, OK)
[19:14:46] NeroVision TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
[19:14:46] NeroVision Sense Key: 0x03 (KEY_MEDIUM_ERROR)
[19:14:46] NeroVision Sense Code: 0x73
[19:14:46] NeroVision Sense Qual: 0x04
[19:14:46] NeroVision CDB Data: 0x51 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
[19:14:46] NeroVision Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
[19:14:46] NeroVision 0x00 0x00 0x00 0x00 0x73 0x04
[19:14:46] NeroVision 19:14:44 #27 CDR -1194 File ThreadedTransferInterface.cpp, Line 1909
[19:14:46] NeroVision PMA update failure
[19:14:46] NeroVision 19:14:44 #28 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1909
[19:14:46] NeroVision Could not perform end of Disc-at-once
[19:14:46] NeroVision 19:14:44 #29 Text 0 File DVDR.cpp, Line 2774
[19:14:46] NeroVision EndDAO: Last written address was -1
[19:14:46] NeroVision 19:14:44 #30 CDR -201 File WriterStatus.cpp, Line 167
[19:14:46] NeroVision Invalid write state
[19:14:46] NeroVision LITE-ON DVDRW SOHW-1673S\H3 T0
[19:14:46] NeroVision 19:14:44 #31 TRANSFER -24 File WriterStatus.cpp, Line 167
[19:14:46] NeroVision 19:14:44 #32 Phase 38 File APIProgress.cpp, Line 276
[19:14:46] NeroVision Burn process failed at 2x (2.770 KB/s)
[19:14:46] NeroVision Existing drivers:
[19:14:46] NeroVision Registry Keys:
[19:14:46] NeroVision HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
