Call of Duty, Could not load OpenGL*
  • 189 views sinds 30-01-2008
mensen,
ik heb het volgende probleem met Cod
ik kan alles goed installeren enz enz, maar als ik het eenmaal opstart krijg ik de volgende foutmelding:
COD 1.0 build win-x86 Oct 5 2003
----- FS_Startup -----
Current language: english
Current search path:
C:\PROGRA~1\CALLOF~1\main\pak6.pk3 (3 files)
C:\PROGRA~1\CALLOF~1\main\pak5.pk3 (4858 files)
C:\PROGRA~1\CALLOF~1\main\pak4.pk3 (1668 files)
C:\PROGRA~1\CALLOF~1\main\pak3.pk3 (1992 files)
C:\PROGRA~1\CALLOF~1\main\pak2.pk3 (694 files)
C:\PROGRA~1\CALLOF~1\main\pak1.pk3 (2642 files)
C:\PROGRA~1\CALLOF~1\main\pak0.pk3 (12828 files)
C:\PROGRA~1\CALLOF~1/main
C:\PROGRA~1\CALLOF~1\main\localized_english_pak1.pk3 (3736 files)
localized assets pak file for english
C:\PROGRA~1\CALLOF~1\main\localized_english_pak0.pk3 (1204 files)
File Handles:
29625 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec config.cfg
couldn't exec autoexec.cfg
========= autoconfigure
configure.csv: using configuration 1200 cpu MHz 256 sys MB 64 vid MB
execing configure.cfg
fs_basepath is write protected.
fs_homepath is write protected.
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Measured CPU speed is 1.47 GHz
System memory is 256 MB (capped at 1 GB)
Video card memory is 64 MB
Streaming SIMD Extensions (SSE) supported
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...shutting down QGL
...unloading OpenGL DLL
Forcing 640x480 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 3: 640 480 FS
...calling CDS: ok
...created window@0,0 (640x480)
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
----- CL_Shutdown -----
RE_Shutdown( 1 )
Could not load OpenGL. Make sure that you have the latest drivers for your video card from the anufacturer's web site.
(heb ik gedaan, dus nvidia forceware 77.72 voor een geforce 2 mx mx 400(64mb geheugen) video kaart)
dus eerst de oude eraf gegooit en dan de nieuwe erop, opnieuw opstarten en nog deed hij het niet.
daarna rechtsklik -> eigenschappen en dan de beeldresolutie (640x480) uitgezet wil ook niet werken.
weet iemand wat ik moet doen?
  • Crash
  • Laatst online: 19:36
Dit is echt al ontzettend vaak voorbij gekomen. Zowel voor Call of Duty, als Quake 3, of Return to Castle Wolfenstein, en alle andere Q3 engine based games. Search op: Could not load OpenGL. Ik weet zeker dat hier de oplossing voor je tussen staat :)
