[XP] Dual boot installatie Vista b1 64bit vanuit XP 32bit*
  • Bram77
  • Laatst online: 10-07-2023
Ik probeer Windows Vista beta 1 64bit te installeren als dual boot naast WIndows XP pro 32bit op mijn AMD 3400+ x64 systeem.
In de installatie instructies op de cd staat het volgende...
Dual-boot configuration with Windows XP
If you want to have more than one operating system on the same computer, you can install "Longhorn" on a specific partition. (This is called a dual-boot or multiboot configuration.) If you do this, be sure to install "Longhorn" on a different partition from the partition where your current version of Windows is installed.
Choose this method if you want to keep your current Windows XP installation and you have an available drive or partition.
To install a dual-boot configuration with Windows XP
Insert the "Longhorn" installation disc into your computer's DVD-ROM drive.
The Install Windows menu should appear automatically. If not, click Start, and then click My Computer. Double-click the drive containing the DVD, and then click setup.exe.
On the Install Windows menu, click Install now.
On the Install Windows page, click Next.
On the Type your product key page, type the 25-character product key. You can find your product key sticker on the installation disc folder.
On the Please read and accept the License Terms page, if you accept the license terms, click I accept the License Terms.
On the Which type of installation do you want? page, click Custom.
On the Your installation settings page, change any settings that you want to change.
To choose where to install Windows, click Install Windows on this drive, and then follow the instructions on the screen.
Continue to follow the instructions on your screen.
Dit zou allemaal prima kunnen werken ware het niet dat ik de 'setup.exe' niet kan openen in mijn 32bit XP installatie. "Geen geldige DOS applicatie" oid...
Uiteraard heb ik al geprobeerd om de installatie direct vanaf de Vista DVD te booten...wat goed gaat. Tot op het moment dat de installatie zichzelf opnieuw opstart. Op de eerste plaats is het enige wat ik te zien krijg bij de reboot dan een knipperende cursor (hoe lang ik ook wacht), op de 2e plaats is mijn XP bootsector dan verkracht. Die kan ik dan wel weer fixen met FIXBOOT vanuit Recovery Console, maar dat maakt nogsteeds niet dat ik de Vista setup kan voortzetten. Als ik kies voor 'Vista' ofwel Longhorn in het bootmenu blijft het scherm zwart.
Ik weet dat Vista een nieuwe bootloarder gebruikt en dat daarin ergens het probleem en dus de oplossing moet zitten.
Iemand die dit probleem toevallig ook al is tegengekomen en het heeft opgelost? Toevallig?
Zoeken leverde geen antwoorden op. Op dit forum niet en via google niet.
  • Bram77
Nu dan toch maar de 32bit versie geprobeerd.
Dat gaat al een stuk beter. Na de eerste restart vanuit XP krijg ik gewoon de Longhorn bootmanager...zoals het hoort. Dan gaat de installatie weer een half uurtje verder (tot +/- halverwegen de installatie), totdat die bij de volgende restart komt. Dan krijg ik een lockup. Ik zie dan het lege Vista installatiescherm (alleen de blauwe achtergrond) en mijn mousepointer...die dus niet meer kan bewegen. Toen heb ik dus de computer handmatig moeten resetten. Helaas werkte geen van de 2 bootmanagers meer hierna. Ik krijg enkel een knipperende cursor linksbovenin, ook na een tijdje wachten gebeurde er niets.
Met FIXBOOT ben ik nu weer in XP gekomen. Ik kan geen informatie vinden over dit probleem. emand ideen over hoe ik dit aan kan pakken?
Wat zegt een sterretje, wat ik er zelf niet heb neergezet, achter de topictitel?
[ Voor 7% gewijzigd door Bram77 op 09-08-2005 20:16 ]
ik denk dat een sterretje betekend dat de topictitel iets verduidelijkt is
P.S. nu ik het toch over fora heb... het KF ligt weer es op zijn gat :'(
  • sanfranjake
sanfranjake
Computers can do that?
(overleden)
Dat betekent dat een van de moderatoren je topictitel ietsje heeft aangepast. Ik was het in ieder geval niet :P
Mijn spoorwegfotografie
  • PcDealer
  • Laatst online: 29-09 22:26
PcDealer
HP ftw \o/
Je probeerde een 64bit Vista te installeren vanuit een 32bit Windows XP. Nee, dat lukt niet.
Je hebt XP erop staan. Met Vista booten en installeren op een andere partitie. Werkte XP dan niet meer? Dan een Repair uitvoeren met XP bootcd.
LinkedIn WoT Cash Converter
  • Bram77
Ik zou idd een 2e MBR kunnen gebruiken door een andere acgijf ls primair toe te wijzein in mijn bios. Zo doe ik dat ook met Kubuntu. Ik heb ook een 3e schijf waarop dat kan, maar dat is niet wat ik wil met Vista 64bit.
Inmiddels is er nieuw probleem, met de 32bit versie...zoals te lezen is.
