NTFS 40 Gb resizen
  • 545 views sinds 30-01-2008
Beste,
Ik wil SuSE 9.3 naast Windows Xp op mijn HD (NTFS) installeren.
Ik heb voor "nieuw besturingssysteem" gekozen in Partition Magic 8.02 maar bij het opstarten zei hij:
Error 983 while executing batch.
Error 983: Too many errors found, process halted.
Ik heb mijn C schijf volledig laten controleren bij het opstarten en toen ik het nogmaals probeerde kreeg ik volgende fout:
Error 1513 while executing batch.
Error 1513: bad attribute position in file record.
Bij het resizen van de HD krijg ik tevens bovenstaande fout.
Ik weet niet wat te doen...
PartitionInfo:
PowerQuest PartitionInfo 8.0 -- Windows NT/2000 Version
Date Generated: 08/05/05 20:23:33
Copyright (c)1994-2002, PowerQuest Corporation
Permission is granted for this utility to be freely copied so long
as it is not modified in any way. All other rights are reserved.
PowerQuest, makers of PartitionMagic(r), Drive Image(tm), and DriveCopy(tm), can be reached at:
Voice: 801-437-8900
Fax: 801-226-8941
Web site: http://www.powerquest.com/support/
E-mail: magic@powerquest.com
General System Information:
Total Physical Memory (bytes): 267,894,784
Used Physical Memory: (bytes): 218,087,424
Maximum Page File Size: (bytes): 647,983,104
Current Page File Size: (bytes): 286,294,016
Disk Geometry Information for Disk 1: 4998 Cylinders, 255 Heads, 63 Sectors/Track
System PartSect # Boot BCyl Head Sect FS ECyl Head Sect StartSect NumSects
0 0 80 0 1 1 07 1023 254 63 63 80,292,807
Info: End C,H,S values were large drive placeholders.
Actual values are:
0 0 80 0 1 1 07 4997 254 63 63 80292807
Partition Information for Disk 1: 39,205.5 Megabytes
Volume PartType Status Size MB PartSect # StartSect TotalSects
C: NTFS Pri,Boot 39,205.5 0 0 63 80,292,807
Boot Record for drive C: (Drive: 1, Starting sector: 63, Type: NTFS)
1. Jump: EB 52 90
2. OEM Name: NTFS
3. Bytes per Sector: 512
4. Sectors per Cluster: 1
5. Reserved Sectors: 0
6. Number of FATs: 0
7. Root Dir Entries: 0
8. Total Sectors: 0
9. Media Descriptor: 0xF8
10. Sectors per FAT: 0
11. Sectors per Track: 63 (0x3F)
12. Number of Heads: 255 (0xFF)
13. Hidden Sectors: 63 (0x3F)
14. Total Sectors (>32MB): 0 (0x0)
15. Unused: 0x80008000
16. Total NTFS Sectors: 80292806
17. MFT Start Cluster: 6291456
18. MFT Mirror Start Clust: 40138370
19. Clusters per FRS: 2
20. Clusters per Index Blk: 8
21. Serial Number: 0x74884E8F884E5032
22. Checksum: 0 (0x0)
23. Boot Signature: 0xAA55
  • Pearl
  • Laatst online: 31-10 15:13
Maak eens de rescue disks aan indien je een floppydrive hebt.
Als ik het goed hebt kun je die handelingen in een dos omgeving doen, PM werkt slecht als je de boot/systeemschijf gaat bewerken, in combinatie met XP, met 2000 zal dan ook wel problemen geven, vermoed ik, denkelijk door NTFS.
Een specialist weet alles van niks en een generalist weet niks van alles.
  • alt-92
alt-92
ye olde farte
en uiteraard eerst chkdsk, defrag en zorgen dat je voldoende vrije ruimte hebt (25%).
Pearl schreef op vrijdag 05 augustus 2005 @ 22:09:
Ik heb disks gecreëert maar hij zei nog steeds dezelfde fout "1513".
Ik zal de schijf eens defragmenteren en daarna nogmaals en chkdisk doen.
Ik heb 23,3 gb van de 40 gb gebruikt.
[ Voor 5% gewijzigd door Verwijderd op 06-08-2005 14:37 ]
  • Pearl
Op de site van Symantec staat dat je een patch moet gebruiken voor deze foutmelding.
http://service1.symantec....nDocument&src=bar_sch_nam
Pearl schreef op zaterdag 06 augustus 2005 @ 16:50:
Ik heb de patch geïnstalleerd en opnieuw geprobeerd om een nieuwe partitie aan te maken met PM8.
Na een uurtje zegt hij de volgende error:
Error 1531: Too few clusters
Ik heb PartitionInfo opengedaan en zag dat er een unallocated partitie is, zou ik linux erop installeren? Of beter niet?
