Resolutie in Kubuntu met XFree86
Hey,
Ik ben nu een dag aan het klooien met de resolutie op mijn Kubuntu machine, ik heb al een nieuwe reconfigure gedaan en de goede syncs ingevuld, maar me resolutie kan niet hoger dan 1024x768, en ik wil m net op 1280x1024 hebben :P. Ook met de sneltoets CRTL - ALT - + werkt t nie. Ik lees t allemaal af op mijn Samsung Syncmaster 172x 17' inch.
Ik zal hieronder mijn xorg.conf posten;
# /etc/X11/xorg.conf (xorg X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package.
# If you have edited this file but would like it to be automatically updated # again, run the following commands:
# cp /etc/X11/xorg.conf /etc/X11/xorg.conf.custom
# sudo sh -c 'md5sum /etc/X11/xorg.conf >/var/lib/xfree86/xorg.conf.md5sum'
# sudo dpkg-reconfigure xserver-xorg
Section "Files"
FontPath "unix/:7100" # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
# paths to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc104"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "true"
Option "ZAxisMapping" "4 5"
EndSection
Section "Device"
Identifier "ATI Technologies, Inc. 3D Rage Pro (AGP)"
Driver "ati"
BusID "PCI:1:0:0"
Option "UseFBDev" "true"
EndSection
Section "Monitor"
Identifier "SyncMaster"
Option "DPMS"
HorizSync 30-80
VertRefresh 56-75
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies, Inc. 3D Rage Pro (AGP)"
Monitor "SyncMaster"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
  • DizzyWeb
  • Laatst online: 26-10 10:25
DizzyWeb
Ondertiteld
HorizSync 30-80
VertRefresh 56-75
Zeker dat die 2 goed staan?
Ik kon niets anders vinden
  • Arx
  • Laatst online: 20-10 10:20
Arx
Two Thoughts Ahead!
@SandervR: Er zijn al talloze topics hierover geweest, gebruik de zoek knop ook eens :). Maar om je toch een hint te geven: Weet je echt heel erg zeker dat je je specificaties van je Samsung 172X hebt opgezocht? Ik geloof daar niets van. ;)
Copywight 2000,2001,2002,2003,2004,2005,2006,2007 Arx. All wights wesewved. | PS Network tag -> Arx_nl
Arx schreef op dinsdag 02 augustus 2005 @ 14:30:
De zoekknop gebruik ik in ieder geval vaker dan dat ik inlog om een vraag te stellen :P. Maar wil je dan AUB wel de goede instellingen posten, ik kon niets vinden
Ik vind net dit, als ik deze aanpas, werkt het dan?
Section "Monitor"
Identifier "Monitor1"
VendorName "Samsung"
ModelName "SyncMaster 172x"
HorizSync 30-63
VertRefresh 56-75
EndSection
Section "Device"
Identifier "Ti4200"
VendorName "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen1"
Device "Ti4200"
Monitor "Monitor1"
DefaultDepth 24
Subsection "Display"
Depth 8
Modes "1024x768" "800x600" "640x480"
EndSubsection
Depth 16
Modes "1280x1024" "1024x768" "800x600" "640x480"
EndSubsection
Depth 24
Modes "1280x1024"
EndSubsection
Depth 32
Modes "1280x1024"
EndSubsection
EndSection
  • Randal Peelen
  • Laatst online: 24-08 15:44
Dan zou ik eerder dat wat je al hebt aanpassen met wat er in deze nieuwe config staat over je monitor... de instellingen van je videokaart zullen namelijk waarschijnlijk wel kloppen, en met de standaard 'ati' drivers zit je, om gewoon beeld te geven, sowiezo wel goed :).
Je kunt later nog een keer naar ati's eigen fglrx drivers kijken, dan heb je ook (betere) 3D support en dergelijke :).
http://twitter.com/randalpeelen
Kijk eens of je ergens dit programma kunt installeren
ddcxinfo-knoppix
Dit programma scant je monitor voor alle resoluties die de monitor aankan en geeft je dan de Monitor sectie voor je xorg.conf die je dan zelf kunt invoegen.
  • Arx
Arx
Two Thoughts Ahead!
Verwijderd schreef op dinsdag 02 augustus 2005 @ 14:36:
Yep, dat zijn de instellingen van deze monitor! Je hebt ze gevonden. :P
Misschien heeft je rage pro niet genoeg videogeheugen?
Zet em eens op defaultdepth 16
