Waarom ziet linux mijn raid controller niet?
  • Master_Egg
  • Laatst online: 11-09 16:44
Master_Egg
Schapie schapie schapie!
cd gebrand, systeem geboot. Wil ik debian gaan installeren blijkt dat linux mijn raid controller niet heeft herkent. En dus ook geen harddisk heeft gevonden. Ik wil geen raid draaien, maar alleen gebruik maken van de ata100 functie. Hoe kan ik er voor zorgen dat linux mijn raid controller wel herkent.
"semi" linux newbie
  • Master_Egg
Master_Egg
niemand? :'(
  • Pantagruel
  • Laatst online: 19-08 21:19
Pantagruel
Mijn 80486 was snel,....was!
Eerder door my gepost op www.vp6-board.com (site opgedragen aan Abit's VP6 dual FCPGA).
Aangezien Abit HighPoint produkten gebruikt zal het onderstaande ook voor dit bord gelden
According to the Highpoint website the device should be support. Only strange that their driver section shows no linux drivers (tar-bal or whatever).
Gentus.com (the Abit way of Linux) seems to be down so no info about their progress.
Abit's website does not mention any support but WinXX.
SuSe Linux 7 does support the HPT366 device but that's only ATA66 and no RAID. The HPT370 is not yet mentioned, neither as normal nor RAID device.
According to RedHat's website RH 7.0 should have drivers supporting the drive on the cd. The first CD does harbour a raidtools-0.90-13.i386.rpm file but this might just as well be something very different.
I'll reboot into linux and browse the RPM database in search of the file.
Update:
Get your browser to:
http://sweb.uky.edu/~mabran3/linux/misc/
This site sports a bootsdisk allowing for linux to be installed on a HPT366/370 attached device. No RAID support. Guess we'll really have to wait for drivers. If you have bought a fresh copy of RH 7.0 just hassle RH dev team about them NOT supporting Highpoint device at install time. They did support USB (albeit buggy) but not the proven Highpoint controller [and what would we rather use USB or HPT?]
Nother Update
Go to: http://www.highpoint-tech.com/370drivers.htm and at the bottom there's a bZip2 file containing the drivers, have a look @ the linux.txt.
And go to : http://www.linux-ide.org/ for futere ATA development.
Asrock Z77 Extreme6, Intel i7-3770K, Corsair H100i, 32 GB DDR-3, 256 GB Samsung SSD + 2 x 3TB SATA, GeForce GTX 660 Ti, Onboard NIC and sound, SyncMaster 24"&22" Wide, Samsung DVD fikkertje, Corsair 500R
  • Master_Egg
Master_Egg
maar hoe kan ik er nou voor zorgen dat linux mijn highpoint 370 controller herkent. Hoe kan ik tijdens de installatie dan de drivers laden voor de hpt370?
  • Master_Egg
Master_Egg
wie o wie?
  • Master_Egg
Master_Egg
:Z
  • Master_Egg
Master_Egg
please......... :'(
  • Da_BoR
  • Laatst online: 11-09 22:45
Linux ondersteund niet standaart de HPT 370 controller (in kernel 2.4.0 wel) maar dan ook alleen software raid
ik heb zo`n ding naast me normale controller zitten ik boot dus niet van me raid controlller, en ik gebruik me hotrod 370 pro als normale controller en maak er onder linux softwarematig een raid array op
das naar mijn weten de enige manier, ik denk dus dat je met de husige distro`s een probleem heb als je het wil installen op zo`n controller
  • Master_Egg
Master_Egg
Op zondag 14 januari 2001 12:01 schreef Da_BoR het volgende:
maar ik heb geen raid array. Ik gebruik hem alleen als ata100 controller. Hoe kan ik deze dan wel laten werken?
  • Da_BoR
uhm, als boot schijf denk ik dat je het nie aan de praat krijgt, als secundaire schijf moet e of de patch laden vanaf highpoint-tech.com
of kernel 2.4.0 installeren
  • mavink
  • Laatst online: 27-05 09:16
Volgens mij is het ding gewoon compatible met de drivers voor de hpt366, en ik heb al ongeveer een half jaar een firewall draaien op een mobotje met zo'n chipje. /dev/hde als rootdisk :)
  • Pantagruel
Pantagruel
Leer es lezen man in mijn posting staat alles wat je nodig hebt !
  • Master_Egg
Master_Egg
Op zondag 14 januari 2001 14:57 schreef Pantagruel het volgende:
Ik heb de info in jou stuk gelezen. Alleen vond ik het niet zo duidelijk. Maar daarom hoef je nog niet zo hoog van de toren te blazen. Maar toch bedankt voor je info. >:)
