Sitecom + Casema disconnect steeds
  • 57 views sinds 30-01-2008
Ik heb het kabelabo basic van Casema in combinatie met een Sitecom DC-202(v3) router.
Laatste weken heb ik het probleem dat de verbinding steeds wegvalt. (MSN Messenger DCt om de kwartier bv.)
Om na te gaan waar het aan lag, heb ik een andere router van hetzelfde model geprobeerd en kreeg het zelfde probleem.
Daarna vinkte ik bij de instellingen Advanced>Logs de optie 'Send E-mail alert immediately when attacked' aan.
Om de paar minuten kreeg ik vervolgens 2 soorten mails:
titel: *Security Alert* [03:11:F4]
inhoud:
2005-07-24 20:38:36 - TCP Flood - Source:192.168.0.3
,2040,LAN - Destination:83.140.65.134,80,WAN
titel: Logs
inhoud:
--------Incoming-------
DateTime From IP To Port
[2005-07-24 20:15:37] | From:[61.238.10.169] | Port:[15445] | [Blocked]
[2005-07-24 20:15:37] | From:[210.6.60.87] | Port:[15445] | [Blocked]
[2005-07-24 20:15:37] | From:[212.127.183.230] | Port:[15445] | [Blocked]
[2005-07-24 20:15:38] | From:[219.78.223.160] | Port:[15445] | [Blocked]
[2005-07-24 20:15:39] | From:[202.171.253.11] | Port:[15445] | [Blocked]
[2005-07-24 20:15:39] | From:[24.100.250.24] | Port:[15445] | [Blocked]
[2005-07-24 20:15:40] | From:[61.92.206.70] | Port:[15445] | [Blocked]
[2005-07-24 20:15:40] | From:[219.77.44.189] | Port:[15445] | [Blocked]
[2005-07-24 20:15:40] | From:[203.218.36.200] | Port:[15445] | [Blocked]
[2005-07-24 20:15:40] | From:[85.224.18.182] | Port:[15445] | [Blocked]
[2005-07-24 20:15:42] | From:[24.37.26.229] | Port:[15445] | [Blocked]
[2005-07-24 20:15:42] | From:[62.194.119.174] | Port:[15445] | [Blocked]
[2005-07-24 20:15:42] | From:[69.196.39.172] | Port:[15445] | [Blocked]
[2005-07-24 20:15:44] | From:[221.127.162.162] | Port:[15445] | [Blocked]
[2005-07-24 20:15:44] | From:[62.103.176.234] | Port:[15445] | [Blocked]
[2005-07-24 20:15:46] | From:[61.216.224.118] | Port:[15445] | [Blocked]
[2005-07-24 20:15:48] | From:[202.171.253.14] | Port:[15445] | [Blocked]
[2005-07-24 20:15:48] | From:[219.78.36.94] | Port:[15445] | [Blocked]
[2005-07-24 20:15:50] | From:[60.49.107.210] | Port:[15445] | [Blocked]
[2005-07-24 20:15:51] | From:[216.136.162.211] | Port:[1337] | [Blocked]
[2005-07-24 20:15:52] | From:[219.79.74.91] | Port:[15445] | [Blocked]
[2005-07-24 20:15:53] | From:[59.148.68.207] | Port:[15445] | [Blocked]
[2005-07-24 20:15:54] | From:[61.18.122.167] | Port:[15445] | [Blocked]
[2005-07-24 20:15:55] | From:[67.66.50.223] | Port:[15445] | [Blocked]
[2005-07-24 20:15:57] | From:[59.115.72.62] | Port:[15445] | [Blocked]
[2005-07-24 20:15:58] | From:[61.149.122.47] | Port:[15445] | [Blocked]
[2005-07-24 20:16:00] | From:[222.167.23.146] | Port:[15445] | [Blocked]
[2005-07-24 20:16:01] | From:[221.126.231.44] | Port:[15445] | [Blocked]
[2005-07-24 20:16:01] | From:[61.64.87.198] | Port:[15445] | [Blocked]
[2005-07-24 20:16:02] | From:[69.86.81.91] | Port:[15445] | [Blocked]
[2005-07-24 20:16:03] | From:[86.132.245.71] | Port:[15445] | [Blocked]
[2005-07-24 20:16:04] | From:[212.187.117.14] | Port:[15445] | [Blocked]
[2005-07-24 20:16:04] | From:[218.190.86.26] | Port:[15445] | [Blocked]
[2005-07-24 20:16:05] | From:[219.232.162.30] | Port:[15445] | [Blocked]
[2005-07-24 20:16:05] | From:[82.58.151.127] | Port:[135] | [Blocked]
[2005-07-24 20:16:09] | From:[201.254.9.222] | Port:[15445] | [Blocked]
[2005-07-24 20:16:12] | From:[24.101.155.82] | Port:[15445] | [Blocked]
[2005-07-24 20:16:12] | From:[24.83.101.162] | Port:[15445] | [Blocked]
[2005-07-24 20:16:12] | From:[69.197.176.59] | Port:[15445] | [Blocked]
[2005-07-24 20:16:12] | From:[202.126.108.110] | Port:[15445] | [Blocked]
[2005-07-24 20:16:13] | From:[222.248.57.3] | Port:[15445] | [Blocked]
[2005-07-24 20:16:14] | From:[172.207.111.115] | Port:[15445] | [Blocked]
[2005-07-24 20:16:24] | From:[69.194.75.160] | Port:[15445] | [Blocked]
[2005-07-24 20:16:26] | From:[221.126.87.69] | Port:[15445] | [Blocked]
[2005-07-24 20:16:30] | From:[24.60.177.192] | Port:[15445] | [Blocked]
[2005-07-24 20:16:30] | From:[62.234.2.220] | Port:[15445] | [Blocked]
[2005-07-24 20:16:34] | From:[221.126.240.229] | Port:[15445] | [Blocked]
[2005-07-24 20:16:37] | From:[24.80.100.52] | Port:[15445] | [Blocked]
[2005-07-24 20:16:37] | From:[203.218.86.102] | Port:[15445] | [Blocked]
[2005-07-24 20:16:43] | From:[58.19.105.22] | Port:[15445] | [Blocked]
[2005-07-24 20:16:46] | From:[207.236.241.79] | Port:[15445] | [Blocked]
[2005-07-24 20:16:47] | From:[218.175.151.111] | Port:[15445] | [Blocked]
[2005-07-24 20:16:47] | From:[62.188.62.211] | Port:[15445] | [Blocked]
[2005-07-24 20:16:48] | From:[219.78.179.174] | Port:[15445] | [Blocked]
[2005-07-24 20:16:50] | From:[82.168.143.75] | Port:[15445] | [Blocked]
[2005-07-24 20:16:50] | From:[172.200.136.95] | Port:[15445] | [Blocked]
[2005-07-24 20:16:50] | From:[219.95.155.237] | Port:[15445] | [Blocked]
[2005-07-24 20:16:54] | From:[60.234.147.168] | Port:[15445] | [Blocked]
[2005-07-24 20:16:57] | From:[218.27.149.82] | Port:[15445] | [Blocked]
[2005-07-24 20:17:02] | From:[203.218.195.103] | Port:[15445] | [Blocked]
[2005-07-24 20:17:03] | From:[60.34.18.113] | Port:[15445] | [Blocked]
[2005-07-24 20:17:10] | From:[219.95.18.65] | Port:[15445] | [Blocked]
[2005-07-24 20:17:12] | From:[70.22.133.253] | Port:[15445] | [Blocked]
[2005-07-24 20:17:14] | From:[219.73.12.141] | Port:[15445] | [Blocked]
[2005-07-24 20:17:16] | From:[67.68.227.87] | Port:[15445] | [Blocked]
[2005-07-24 20:17:18] | From:[218.102.158.152] | Port:[15445] | [Blocked]
[2005-07-24 20:17:20] | From:[201.254.145.29] | Port:[15445] | [Blocked]
[2005-07-24 20:17:27] | From:[147.46.69.216] | Port:[15445] | [Blocked]
[2005-07-24 20:17:29] | From:[70.49.91.82] | Port:[15445] | [Blocked]
[2005-07-24 20:17:34] | From:[218.252.34.94] | Port:[15445] | [Blocked]
[2005-07-24 20:17:35] | From:[81.69.44.21] | Port:[15445] | [Blocked]
[2005-07-24 20:17:38] | From:[202.171.253.13] | Port:[15445] | [Blocked]
[2005-07-24 20:17:38] | From:[219.79.143.187] | Port:[15445] | [Blocked]
[2005-07-24 20:17:39] | From:[86.132.221.20] | Port:[15445] | [Blocked]
[2005-07-24 20:17:40] | From:[81.228.209.59] | Port:[15445] | [Blocked]
[2005-07-24 20:17:42] | From:[203.218.237.64] | Port:[15445] | [Blocked]
[2005-07-24 20:17:42] | From:[80.161.99.88] | Port:[15445] | [Blocked]
[2005-07-24 20:17:46] | From:[65.94.161.53] | Port:[15445] | [Blocked]
[2005-07-24 20:17:48] | From:[207.112.19.1] | Port:[15445] | [Blocked]
[2005-07-24 20:17:50] | From:[65.95.112.205] | Port:[15445] | [Blocked]
[2005-07-24 20:17:51] | From:[82.9.177.165] | Port:[15445] | [Blocked]
[2005-07-24 20:17:57] | From:[24.6.1.143] | Port:[15445] | [Blocked]
[2005-07-24 20:17:58] | From:[61.18.217.116] | Port:[15445] | [Blocked]
[2005-07-24 20:17:59] | From:[62.166.188.26] | Port:[15445] | [Blocked]
[2005-07-24 20:18:03] | From:[82.172.24.186] | Port:[15445] | [Blocked]
[2005-07-24 20:18:15] | From:[69.111.154.38] | Port:[15445] | [Blocked]
[2005-07-24 20:18:15] | From:[220.134.113.28] | Port:[15445] | [Blocked]
[2005-07-24 20:18:19] | From:[67.169.225.238] | Port:[15445] | [Blocked]
[2005-07-24 20:18:22] | From:[67.181.93.26] | Port:[15445] | [Blocked]
[2005-07-24 20:18:24] | From:[218.102.234.11] | Port:[15445] | [Blocked]
[2005-07-24 20:18:25] | From:[69.158.184.72] | Port:[15445] | [Blocked]
[2005-07-24 20:18:29] | From:[203.218.171.101] | Port:[15445] | [Blocked]
[2005-07-24 20:18:29] | From:[24.4.68.174] | Port:[15445] | [Blocked]
[2005-07-24 20:18:31] | From:[70.26.118.92] | Port:[15445] | [Blocked]
[2005-07-24 20:18:35] | From:[67.112.27.42] | Port:[15445] | [Blocked]
[2005-07-24 20:18:36] | From:[203.186.233.190] | Port:[15445] | [Blocked]
[2005-07-24 20:18:37] | From:[221.124.172.54] | Port:[15445] | [Blocked]
[2005-07-24 20:18:40] | From:[82.19.103.110] | Port:[15445] | [Blocked]
[2005-07-24 20:18:45] | From:[82.157.36.103] | Port:[1433] | [Blocked]
[2005-07-24 20:18:45] | From:[66.215.160.93] | Port:[15445] | [Blocked]
Ik heb zowel de firewall van WinXP en ZoneAlarm aanstaan, maar het mocht niet baten.
Heeft iemand enig idee waardoor ditkomt?
Niet alleen hier dubbel. Ook in IT.
