Sitecom + Casema disconnect steeds
  • 425 views sinds 30-01-2008
Ik heb het kabelabo basic van Casema in combinatie met een Sitecom DC-202(v3) router.
Laatste weken heb ik het probleem dat de verbinding steeds wegvalt. (MSN Messenger DCt om de kwartier bv.)
Om na te gaan waar het aan lag, heb ik een andere router van hetzelfde model geprobeerd en kreeg het zelfde probleem.
Daarna vinkte ik bij de instellingen Advanced>Logs de optie 'Send E-mail alert immediately when attacked' aan.
Om de paar minuten kreeg ik vervolgens 2 soorten mails:
titel: *Security Alert* [03:11:F4]
inhoud:
2005-07-24 20:38:36 - TCP Flood - Source:192.168.0.3
,2040,LAN - Destination:83.140.65.134,80,WAN
titel: Logs
inhoud:
--------Incoming-------
DateTime From IP To Port
[2005-07-24 20:15:37] | From:[61.238.10.169] | Port:[15445] | [Blocked]
[2005-07-24 20:15:37] | From:[210.6.60.87] | Port:[15445] | [Blocked]
[2005-07-24 20:15:37] | From:[212.127.183.230] | Port:[15445] | [Blocked]
[2005-07-24 20:15:38] | From:[219.78.223.160] | Port:[15445] | [Blocked]
[2005-07-24 20:15:39] | From:[202.171.253.11] | Port:[15445] | [Blocked]
[2005-07-24 20:15:39] | From:[24.100.250.24] | Port:[15445] | [Blocked]
[2005-07-24 20:15:40] | From:[61.92.206.70] | Port:[15445] | [Blocked]
[2005-07-24 20:15:40] | From:[219.77.44.189] | Port:[15445] | [Blocked]
[2005-07-24 20:15:40] | From:[203.218.36.200] | Port:[15445] | [Blocked]
[2005-07-24 20:15:40] | From:[85.224.18.182] | Port:[15445] | [Blocked]
[2005-07-24 20:15:42] | From:[24.37.26.229] | Port:[15445] | [Blocked]
[2005-07-24 20:15:42] | From:[62.194.119.174] | Port:[15445] | [Blocked]
[2005-07-24 20:15:42] | From:[69.196.39.172] | Port:[15445] | [Blocked]
[2005-07-24 20:15:44] | From:[221.127.162.162] | Port:[15445] | [Blocked]
[2005-07-24 20:15:44] | From:[62.103.176.234] | Port:[15445] | [Blocked]
[2005-07-24 20:15:46] | From:[61.216.224.118] | Port:[15445] | [Blocked]
[2005-07-24 20:15:48] | From:[202.171.253.14] | Port:[15445] | [Blocked]
[2005-07-24 20:15:48] | From:[219.78.36.94] | Port:[15445] | [Blocked]
[2005-07-24 20:15:50] | From:[60.49.107.210] | Port:[15445] | [Blocked]
[2005-07-24 20:15:51] | From:[216.136.162.211] | Port:[1337] | [Blocked]
[2005-07-24 20:15:52] | From:[219.79.74.91] | Port:[15445] | [Blocked]
[2005-07-24 20:15:53] | From:[59.148.68.207] | Port:[15445] | [Blocked]
[2005-07-24 20:15:54] | From:[61.18.122.167] | Port:[15445] | [Blocked]
[2005-07-24 20:15:55] | From:[67.66.50.223] | Port:[15445] | [Blocked]
[2005-07-24 20:15:57] | From:[59.115.72.62] | Port:[15445] | [Blocked]
[2005-07-24 20:15:58] | From:[61.149.122.47] | Port:[15445] | [Blocked]
[2005-07-24 20:16:00] | From:[222.167.23.146] | Port:[15445] | [Blocked]
[2005-07-24 20:16:01] | From:[221.126.231.44] | Port:[15445] | [Blocked]
[2005-07-24 20:16:01] | From:[61.64.87.198] | Port:[15445] | [Blocked]
[2005-07-24 20:16:02] | From:[69.86.81.91] | Port:[15445] | [Blocked]
[2005-07-24 20:16:03] | From:[86.132.245.71] | Port:[15445] | [Blocked]
[2005-07-24 20:16:04] | From:[212.187.117.14] | Port:[15445] | [Blocked]
[2005-07-24 20:16:04] | From:[218.190.86.26] | Port:[15445] | [Blocked]
[2005-07-24 20:16:05] | From:[219.232.162.30] | Port:[15445] | [Blocked]
[2005-07-24 20:16:05] | From:[82.58.151.127] | Port:[135] | [Blocked]
[2005-07-24 20:16:09] | From:[201.254.9.222] | Port:[15445] | [Blocked]
[2005-07-24 20:16:12] | From:[24.101.155.82] | Port:[15445] | [Blocked]
[2005-07-24 20:16:12] | From:[24.83.101.162] | Port:[15445] | [Blocked]
[2005-07-24 20:16:12] | From:[69.197.176.59] | Port:[15445] | [Blocked]
[2005-07-24 20:16:12] | From:[202.126.108.110] | Port:[15445] | [Blocked]
[2005-07-24 20:16:13] | From:[222.248.57.3] | Port:[15445] | [Blocked]
[2005-07-24 20:16:14] | From:[172.207.111.115] | Port:[15445] | [Blocked]
[2005-07-24 20:16:24] | From:[69.194.75.160] | Port:[15445] | [Blocked]
[2005-07-24 20:16:26] | From:[221.126.87.69] | Port:[15445] | [Blocked]
[2005-07-24 20:16:30] | From:[24.60.177.192] | Port:[15445] | [Blocked]
[2005-07-24 20:16:30] | From:[62.234.2.220] | Port:[15445] | [Blocked]
[2005-07-24 20:16:34] | From:[221.126.240.229] | Port:[15445] | [Blocked]
[2005-07-24 20:16:37] | From:[24.80.100.52] | Port:[15445] | [Blocked]
[2005-07-24 20:16:37] | From:[203.218.86.102] | Port:[15445] | [Blocked]
[2005-07-24 20:16:43] | From:[58.19.105.22] | Port:[15445] | [Blocked]
[2005-07-24 20:16:46] | From:[207.236.241.79] | Port:[15445] | [Blocked]
[2005-07-24 20:16:47] | From:[218.175.151.111] | Port:[15445] | [Blocked]
[2005-07-24 20:16:47] | From:[62.188.62.211] | Port:[15445] | [Blocked]
[2005-07-24 20:16:48] | From:[219.78.179.174] | Port:[15445] | [Blocked]
[2005-07-24 20:16:50] | From:[82.168.143.75] | Port:[15445] | [Blocked]
[2005-07-24 20:16:50] | From:[172.200.136.95] | Port:[15445] | [Blocked]
[2005-07-24 20:16:50] | From:[219.95.155.237] | Port:[15445] | [Blocked]
[2005-07-24 20:16:54] | From:[60.234.147.168] | Port:[15445] | [Blocked]
[2005-07-24 20:16:57] | From:[218.27.149.82] | Port:[15445] | [Blocked]
[2005-07-24 20:17:02] | From:[203.218.195.103] | Port:[15445] | [Blocked]
[2005-07-24 20:17:03] | From:[60.34.18.113] | Port:[15445] | [Blocked]
[2005-07-24 20:17:10] | From:[219.95.18.65] | Port:[15445] | [Blocked]
[2005-07-24 20:17:12] | From:[70.22.133.253] | Port:[15445] | [Blocked]
[2005-07-24 20:17:14] | From:[219.73.12.141] | Port:[15445] | [Blocked]
[2005-07-24 20:17:16] | From:[67.68.227.87] | Port:[15445] | [Blocked]
[2005-07-24 20:17:18] | From:[218.102.158.152] | Port:[15445] | [Blocked]
[2005-07-24 20:17:20] | From:[201.254.145.29] | Port:[15445] | [Blocked]
[2005-07-24 20:17:27] | From:[147.46.69.216] | Port:[15445] | [Blocked]
[2005-07-24 20:17:29] | From:[70.49.91.82] | Port:[15445] | [Blocked]
[2005-07-24 20:17:34] | From:[218.252.34.94] | Port:[15445] | [Blocked]
[2005-07-24 20:17:35] | From:[81.69.44.21] | Port:[15445] | [Blocked]
[2005-07-24 20:17:38] | From:[202.171.253.13] | Port:[15445] | [Blocked]
[2005-07-24 20:17:38] | From:[219.79.143.187] | Port:[15445] | [Blocked]
[2005-07-24 20:17:39] | From:[86.132.221.20] | Port:[15445] | [Blocked]
[2005-07-24 20:17:40] | From:[81.228.209.59] | Port:[15445] | [Blocked]
[2005-07-24 20:17:42] | From:[203.218.237.64] | Port:[15445] | [Blocked]
[2005-07-24 20:17:42] | From:[80.161.99.88] | Port:[15445] | [Blocked]
[2005-07-24 20:17:46] | From:[65.94.161.53] | Port:[15445] | [Blocked]
[2005-07-24 20:17:48] | From:[207.112.19.1] | Port:[15445] | [Blocked]
[2005-07-24 20:17:50] | From:[65.95.112.205] | Port:[15445] | [Blocked]
[2005-07-24 20:17:51] | From:[82.9.177.165] | Port:[15445] | [Blocked]
[2005-07-24 20:17:57] | From:[24.6.1.143] | Port:[15445] | [Blocked]
[2005-07-24 20:17:58] | From:[61.18.217.116] | Port:[15445] | [Blocked]
[2005-07-24 20:17:59] | From:[62.166.188.26] | Port:[15445] | [Blocked]
[2005-07-24 20:18:03] | From:[82.172.24.186] | Port:[15445] | [Blocked]
[2005-07-24 20:18:15] | From:[69.111.154.38] | Port:[15445] | [Blocked]
[2005-07-24 20:18:15] | From:[220.134.113.28] | Port:[15445] | [Blocked]
[2005-07-24 20:18:19] | From:[67.169.225.238] | Port:[15445] | [Blocked]
[2005-07-24 20:18:22] | From:[67.181.93.26] | Port:[15445] | [Blocked]
[2005-07-24 20:18:24] | From:[218.102.234.11] | Port:[15445] | [Blocked]
[2005-07-24 20:18:25] | From:[69.158.184.72] | Port:[15445] | [Blocked]
[2005-07-24 20:18:29] | From:[203.218.171.101] | Port:[15445] | [Blocked]
[2005-07-24 20:18:29] | From:[24.4.68.174] | Port:[15445] | [Blocked]
[2005-07-24 20:18:31] | From:[70.26.118.92] | Port:[15445] | [Blocked]
[2005-07-24 20:18:35] | From:[67.112.27.42] | Port:[15445] | [Blocked]
[2005-07-24 20:18:36] | From:[203.186.233.190] | Port:[15445] | [Blocked]
[2005-07-24 20:18:37] | From:[221.124.172.54] | Port:[15445] | [Blocked]
[2005-07-24 20:18:40] | From:[82.19.103.110] | Port:[15445] | [Blocked]
[2005-07-24 20:18:45] | From:[82.157.36.103] | Port:[1433] | [Blocked]
[2005-07-24 20:18:45] | From:[66.215.160.93] | Port:[15445] | [Blocked]
Ik heb zowel de firewall van WinXP en ZoneAlarm aanstaan, maar het mocht niet baten.
Heeft iemand enig idee waardoor dit komt?
  • Atlas
Atlas
Ik flits niet meer terug!
Verwijderd schreef op zondag 24 juli 2005 @ 23:33:
Zet es 1 van de 2 uit en zie dat het waarschijnlijk beter gaat werken ;)
*edit*
Heb geprobeerd 1tje ervan aan te laten, de verbinding werd eerst normaal. Maar nu disconnect hij weer om de zoveel tijd. :'(
[ Voor 77% gewijzigd door Verwijderd op 24-07-2005 23:59 ]
  • The Eagle
The Eagle
I wear my sunglasses at night
Welk modem heb je? Een Motorola Surfboard of een COM21? In het geval van die laatste: bel de helpdesk en vraag om een omruil. Hebben ze bij mij ook gedaan, doen ze niet moeilijk over als je zegt dat je steeds verbindingsproblemen hebt en dat je internet steeds wegvalt. Ik heb overigens ook een sitecom DC-202 btw ;)
Heb je overigens het aantal half open connecties gepatched? Kan best zijn dat dat last veroorzaakt namelijk :)
Ik heb een witte Motorola modem.
Hoe doe je dat, het aantal half open connecties patchen?
  • The Eagle
The Eagle
Verwijderd schreef op maandag 25 juli 2005 @ 13:43:
Daar is een (niet officiele btw) patch voor. Gebruik de GoT search en je vind hem zo :) Die patch is voor XP SP2 overigens; SP1 heeft hier (nog) geen last van :)
Edit: en als je een wit motorola modem hebt, heb je dus al het mest recente modem dat Casema levert :) Dan zou je alleen nog je heil kunnen zoeken in een firmware-update van je router :Y)
[ Voor 21% gewijzigd door The Eagle op 25-07-2005 13:50 ]
Ik heb Bitcomet uitgezet, meteen werd de verbinding weer ok, MSN disconnecte niet meer.
Best vreemd? :?
  • EricJH
  • Laatst online: 05:13
Verwijderd schreef op maandag 25 juli 2005 @ 21:15:
Best vreemd? :?
Niet vreemd. Iedere modem en router hebben een maximaal aantal gelijktijdige verbindingen dat ze kunnen managen. Meestal is de router de bottleneck.
Mijn ervaring is om max. 60% van je uploadcapaciteit en 60% van het maximaal aantal gelijktijdige verbindingen van de router in te stellen in je p2p programma. Hoeveel de max. gelijktijdige verbindingen voor je Sitecom router is weet ik niet. Bij de Speedtouch die ik gebruik ligt de grens bij 250 gelijktijdige verbindingen. Dus staat het hier op max. 150 verbindingen ingesteld.
Ik heb je advies opgevolgd, stukken beter. Bedankt :)
  • EricJH
Verwijderd schreef op dinsdag 26 juli 2005 @ 20:01:
Heeft het nog gecrasht?
