Trust bluetooth BT180 krijg hem maar niet draaien onder Xp
  • 1.474 views sinds 30-01-2008
Ik heb een pc met windows XP HOME (!!!) erop en ik krijg bluetooth maar niet draaiende op de pc, bij de installatie opent de computer ineens een stuk of 10 nieuwe poorten en installeert de software wel, maar hij maakt maar geen verbinding met mn mobieltje, het enigste stuk tekst op internet waar ik een beetje wat mee kon was deze van Lockergnome: First of all, Bluetooth in Windows XP is a complete and total frustrating experience. I bought 3 different bluetooth adapters, until I finally got one to work right. The one I recommend is the D-Link one, since they are about the only one that actually gives you something that is easy to understand and works with the widdcomm drivers.
Secondly, thanks for the link to the post on the microsoft knowledge base about the ghosted com ports. I knew that was the problem, but I had no idea how to fix it. I had 20 different com ports from my previous bluetooth failures that I deleted.
Heres how I got it working(Note:I'm using the WIDCOMM drivers and getting those to work is a whole other can of worms.)
I used the post above about getting rid of ghosted ports, so this isn't my idea. Just wanted to clarify for those still confused(Microsoft's help is confusing even.)
1. Right Clck on My Computer and click properties.
2. Click on the Advanced Tab
3. Click on Environmental Variables
4. Under System Variables click new.
5. In the variable name box type : devmgr_show_nonpresent_devices
6. in the value box type: 1
Then click OK. Then goto the Device Manager and Under the View Menu, you should see "View Hidden Devices"
Go under the Com Ports section, and delete everything but your ACTUAL COM PORTS, even the bluetooth ones.
Then right click on the Bluetooth Icon in your taskbar, goto Advanced Configuration, then goto Local Services. If Bluetooth Serial Port is still listed, delete it. Then click Add Serial Service and it should add a Com port in the low numbers.
Thanks to everyone on this board, I FINALLY got Bluetooth Activesync working.
Now, if I could get Bluetooth Networking connected right, then I'd be in business. This whole Bluetooth thing is supposed to be easy, but leave it to Microsoft to complicate the matter.
dat heb ik gedaan, de overige poorten dr uit gedonderd, bluetooth ingesteld zoals ze hier zeggen en nog draait dat verdomde ding niet !!!
weer zoeken op google leverde me lijsten zoekresultaten over problemen met windows xp en bluetooth, maar nergens een oplossing waar ik ook maar iets aan heb.
Ja, ook de site van windows heb ik gecheck maar daar werd ik gestoorder van dan ik al was. . .
  • breinonline
breinonline
Are you afraid to be known?
Gebruik je de Trust software of de standaard ingebouwde MS drivers voor BT, dat is me niet helemaal duidelijk. Welke van de twee werkt(e) niet en heb je nu de WIDCOMM drivers geprobeerd?
probleem is denk ik dat als ik bezig ben met de installatie van de trust drivers dat op een gegeven moment moet die ontvanger in een usb poort, zodra ik die erin steek gaat windows ook installeren en ik vermoed dat het daardoor fout gaat.
alle andere software pakketten op de site van trust hebben hetzelfde gezeur, wel installeren, wel het mobieltje vinden en een hele rits poorten openen, maar niet verbinden...
en ik heb geen flauw idee wat widcomm is, en ernaar google geeft me pagina's resultaten waar ik niets wijzer uit wordt...
schop
Vreemd, ik heb hier bleutooth prima draaiend. Ik hen een dongle van Eminent. Windows XP zag hem meteen al verkeerd, maar even het bijgeleverde CDtje installen en de driver veranderen en werken maar.
pffffffff trust helpdesk heb ik ook niets aan.
tsja meneer dan snap ik het ook niet, hij hoort het gewoon te doen zo. . .
8)7 8)7 8)7
ook gelijk maar ff een schoppie dan. . .
  • Motrax
Motrax
Profileert
Aangezien je niet duidelijk beschrijft wat je probleem is en wat er wel/niet gebeurd kan ik niet zeggen wat je probleem is. Je beschrijft niet eens of je SP1 of 2 voor Windows hebt.
Widcomm zijn goede drivers, maar werken niet altijd ivm met licensing icm je dongle.
Ik heb hier ooit mijn eigen probleem beschreven, misschien dat je hier een stuk verder mee komt:
Qrtek bluetooth dongle & Nokia DWH-3 headset wil niet
In de laatste post staat sowiezo een goede link naar een goede site met uitleg. En goed nieuws, je Trust BT180 staat bij de Tested devices op de site. Succes ermee :)
[ Voor 8% gewijzigd door Motrax op 27-07-2005 21:44 ]
/ \ Analyseert | Modelleert | Valideert | Solliciteert | Generaliseert | Procrastineert | Epibreert |
zal daar es ff kijke
thanks
