[SBS 2003] SP1 vraagt om SP1?*
  • 112 views sinds 30-01-2008
  • CPZ
  • Laatst online: 04-09 10:49
Laat maar, ik heb het gevonden.
Bedankt voor de support.
[ Voor 89% gewijzigd door CPZ op 17-07-2005 21:42 ]
  • lier
  • Laatst online: 14:40
lier
MikroTik nerd
Volgens mij staat er dat je eerst Windows2003 SP1 moet installeren, voordat je SBS2003 SP1 kan installeren.
Mij staat bij dat je een aantal stappen moet doen, voordat deze service pack te installeren is...
Dit staat er...:
System Requirements
Supported Operating Systems: Windows Small Business Server 2003
Before you can install Windows SBS SP1, the following updates must be installed on the server:
* Service Pack 1 for the Windows Server® 2003 operating system
* Windows SharePoint® Services 2.0 Service Pack 1
* Exchange Server 2003 Service Pack 1
* Windows XP SP2 for Client Deployment(*)
Instructions
Before You Install Windows SBS SP1
* Print these instructions for quick reference. The installation process requires the computer to restart one or more times.
* Create a shortcut to this Web page on your Windows desktop. The shortcut will enable you to quickly access this information after the computer restarts, or if your browser is closed.
* Read the release notes. These notes contain information that was not available when these instructions were written.
* This service pack cannot be uninstalled. Before you install Windows SBS SP1, we strongly recommend that you perform a complete backup of your existing Windows SBS installation. For information about how to back up your server, see the "Setup Best Practices" documentation on the Microsoft Web site (http://go.microsoft.com/fwlink/?LinkId=44619).
Setup Instructions
Perform the following steps to install the latest service packs and updates for Windows Small Business Server 2003. Complete the steps in the sequence listed.
Notes
* If one or more of the listed components is already installed, you can skip to the next step.
* Be sure to allocate adequate time. As a part of this process, you must download five separate files, which could take a considerable amount of time depending upon the speed of your Internet connection.
* Because user input is required during the installation process, be sure to schedule enough time to complete all of the steps. If you find it necessary to perform other tasks while Setup is running, be sure to check back often to determine if your input is needed.
Step One: Download the updates
1. On the computer running Windows SBS, create a folder named SP1 on your local hard disk.
2. Download and save the following updates into the SP1 folder:
1. Windows Server 2003 Service Pack 1
2. Windows SharePoint Services 2.0 Service Pack 1
3. Exchange Server 2003 Service Pack 1
4. Windows XP SP2 for Client Deployment
5. Windows Small Business Server 2003 Service Pack 1
Note
* If you have already obtained Windows XP SP2, it is not necessary to download Windows XP SP2 for Client Deployment. Alternately, follow the steps outlined in the following KB articles:
1. Update for Windows Small Business Server 2003: KB 872769
2. Update for Windows Small Business Server 2003: KB 884032
Step Two: Install Windows Server 2003 Service Pack 1
1. In Windows Explorer, open the SP1 folder, and then double-click WindowsServer2003-KB889101-SP1-x86-ENU.exe.
2. Follow the instructions on the screen to complete the installation.
Note
* When the Service Pack 1 Setup dialog box appears informing you that Setup will automatically stop and then restart the Windows Internet Name Service (WINS), click Continue.
3. Allow the computer to automatically restart.
Step Three: Install Windows SharePoint Services 2.0 Service Pack 1
1. In Windows Explorer, open the SP1 folder, and then double-click WSS2003SP1-kb841876-fullfile-enu.exe.
Step Four: Install Exchange Server 2003 Service Pack 1
1. In Windows Explorer, open the SP1 folder, and then double-click E3SP1ENG.exe.
2. In the Choose Directory for Extracted Files dialog box, click Ok.
3. When the self-extraction process is complete, click OK.
4. In Windows Explorer, double click the E3SP1ENG folder, double-click the setup folder, and then double-click the i386 folder.
5. Double-click Update.exe, and then follow the instructions on the screen.
Step Five: Install Windows XP SP2 for Client Deployment
Perform this step only if you have not already installed Updates KB872769 and KB884032.
1. In Windows Explorer, open the SP1 folder, and then double-click SBS2003-KB891193-X86-ENU.EXE.
Step Six: Install Windows Small Business Server 2003 Service Pack 1
1. In Windows Explorer, open the SP1 folder, and then double-click SBS2003-KB885918-SP1-X86-ENU.EXE.
[ Voor 98% gewijzigd door lier op 15-07-2005 14:45 ]
  • alt-92
alt-92
ye olde farte
CPZ schreef op vrijdag 15 juli 2005 @ 14:37:
Hebben ze bij Microsoft gevoel voor humor;
Altijd, zeker als het gaat om mensen die geen readme's lezen ;)
