Meuktracker submit
  • 66 views sinds 30-01-2008
  • Spixo
  • Laatst online: 07:25
Ik heb net de nieuwe versie van Kaspersky in de meuktracker toegevoegd. Helaas ben ik een changelog vergeten. Ik weet echter niet hoe ik dit achteraf kan aanpassen, bij deze dus de changelog:
Version 5.0.372 Release date: 17.06.05:
- Enhancements:
1. Error that allowed user to get the advanced privileges has been fixed
2. Error causing the system crash (with the NTFS disk scan (chkdsk) option enabled) at the system startup has been fixed
3. Error that occurs when the protection against network attacks is enabled if StyleXP application is used has been fixed
4. The stability and reliability of the application's operation under increased loads has been improved
5. The graphical user interface of the application has been revised
- Known problems:
1. The application freezes when performing a mail scan if a problem occurs when connecting to the Microsoft Exchange Server
2. Incompatibility with previous versions of Kaspersky Anti-Spam Personal (up to 1.0.0.25)
3. Limited compatibility with Sygate firewall. In order to solve this problem, disable the Enable driver protection option using the Sygate interface and install an additional utility program klimsetup.exe
4. Occasionally a problem occurs when obtaining access to HTTP servers that require online authorization. In order to solve this problem, disable the script monitoring function
5. Incompatibility with the MсАfee Parental Controls application
6. The feature of updating via FTP proxy servers is not available
7. Incompatibility with Kaspersky Anti-Hacker 1.5 under Microsoft Windows 9x. In order to solve this problem, upgrade to Kaspersky Anti-Hacker 1.7
8. Pop-up information messages are not displayed when working under Microsoft Windows NT 4.0
  • Robin
Thanks, ik heb het changelog erbij gezet :).
