Fur Fusion Barebone
  • 58 views sinds 30-01-2008
Ik heb dit een jaar geleden al gevraagd, was benieuwd over er niet één stilzwijgend tweakertje is die ook de Fur fusion H845E barebone heeft. Lijkt me toch sterk dat ik de enige ben.
Specs: Design ATX Form Factor (17.5x24)
Chipset Intel 845GE Graphics Memory Controller Hub (GMCH)
Intel 82801DB I/O Controller Hub (ICH4) Chipset
CPU Socket Support Intel P4 478 Pin package (Flip-Chip)
Pin Grid Array (FC-PGA2) package
Support 400 & 533 FSB
Support 1.5-3.06G Processors with Hyperthreading
Memory Socket 184-pin DDR SDRAM module socket x 2
Support DDR266/DDR 333 DDR SDRAM
Expandable to 2.0 gig
Expansion headers and Slots AGP slot x1 for AGP 1.5V standard only, support AGP 2.0 & 4X mode.
32-bit PCI x1
Intergrated IDE Two PCI IDE Controllers support PCI Bus Mastering, ATA PIO/DMA and the ULTRA DMA 33/66/100 functions that deliver the data transfer up to 100 MB/s.
1394 Port VIA VT6307S 1394 Controller chip provided two 1394 device ports support 100/200/400mb bandwidth.
Compliant with IEEE 1294A-2000 standard.
LAN On Board Realtek RTL8101L PCI LAN Controller Chip.
Supports 10/100mb/sec data transfer.
Intergrated VGA Intergrated High Performance and High Quality 3D Accelerator
Support Ultra-AGPII with 2GB/s Bandwidth
Built in 24-bit RAMDAC
Frame buffer size between 8mb and 64 mb
Audio Realtek ALC 650 6-channel AC97' Codec intergrated.
SPDIF-In/ SPDIF-Out Optical support.
Audio driver and utility included
BIOS Award 2MB Flash ROM
Multi I/O PS/2 keyboard and PS/2 Mouse connectors
Floppy drive connector x1
Parallel x1, Serial port headers x 2
USB 2.0 x 4
Audio Connector Line in, Line Out, MIC (all x 2).
Plaatje:
Afbeeldingslocatie: http://www.walibe.com/pics/ff/ff12_thumb.JPG
Review:
http://www.walibe.com/sections-viewarticle42-page1.html
  • Murcielago
  • Laatst online: 24-09 00:49
ehm, wat wil je weten eigenlijk?
PSN: djmurcielago
Nou ervaringen uitwisselen, tweaks, mogelijkheden etc. En gewoon interesse (als dat hier toegestaan is ;-)
  • Revodrone
  • Laatst online: 16:40
Als je ervaringen wilt uitwisselen, laten we dan beginnen met de ervaring die jij hebt
[ Voor 6% gewijzigd door Revodrone op 07-07-2005 14:30 ]
Fair enough :Y)
- Stabiel, degelijk afgewerkt, standaard heatpipe systeem.
- Er zit maar 1 fan voor zowel de voeding als de processor, deze heb ik vervangen door een papst.
- P4 2.533 MHz
- 1024 MB
- POV TI4200 128 MB SE videokaart
- Hauppage 250 MCE TVkaart
- 2 x 80 GB HD
- 1 x DVD R/Writer
- Extra Papst 80 MM van geplaats die tegen de HD's en DVD blaast
- Windows XP sp2 Voor normaal PC gebruik
- Draai MediaPortal voor HTPC gebruik
Heb nu net een Thermaltake Big Water aangeschaft en zit nu te puzzelen hoe ik deze (Gedeeltelijk) in mijn al overvolle doosje ga proppen.
(Zit met smart te wachten op mijn bestelde DELL FP2405 om mijn bescheiden HTPC setje eens lekker tot zijn recht te kunnen laten komen)
[ Voor 4% gewijzigd door Verwijderd op 07-07-2005 15:29 ]
  • Laurent
Sorry, maar dit is eigenlijk niet de manier waarop je een ervaringen topic dient te openen. :) Meer informatie over de richtlijnen hiervoor vind je in de CSL Policy. :)
