De nieuwe DURON van AMD
  • 134 views sinds 30-01-2008
Is er al wat over zijn prestaties bekend?
Wanner komt hij in nederland?
Gaat Intel er NU eidelijk aan?
Als je tweakers.net in de gaten houdt weet je al een heleboel. http://www.tweakers.net/nieuws.dsp?ID=10706
Fortunately, the Duron won't be as crippled as the new Celeron, since it will feature the same 100MHz DDR EV6 Bus (effectively 200MHz) that brought the Athlon so much attention upon its release. As we proved in our review of Intel's new Celeron, its 66MHz FSB and 66MHz memory bus is definitely holding back the performance of the CPU, and unless overclocked, this will give the Duron an easy performance advantage over the Celeron.
The Duron will feature the same 128KB L1 cache from the Athlon in addition to a full speed on-die L2 cache. While AMD isn't ready to disclose exactly how large that L2 cache is, they are willing to say that the Duron will feature more total on-die cache (L1 + L2) than the Celeron (which features 32KB L1 + 128KB L2). At the same time, the Duron will obviously have less L2 cache than the upcoming Thunderbird part (256KB), so you can safely guess as to what the actual cache size of the Duron will be.
M.A.W. Hij wordt erg snel voor z'n geld
