CCME met ISDN
  • 167 views sinds 30-01-2008
Wie kan me helpen??
Ik ben pas begonnen met me te verdiepen in Voice over IP. Ik maak gebruik van Cisco CallManager Express 3.2. Intern heb ik de telefoons aan de praat gekregen, maar het lukt me niet om naar buiten te bellen. Ik heb tot nu toe de volgende configuratie:
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Cisco2851
boot-start-marker
boot-end-marker
memory-size iomem 10
network-clock-participate wic 3
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.100.1 192.168.100.10
ip dhcp pool IP_Phones
import all
network 192.168.100.0 255.255.255.0
option 150 ip 192.168.100.1
default-router 192.168.100.1
no ftp-server write-enable
isdn switch-type basic-net3
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/0.100
encapsulation dot1Q 100
ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet0/1
ip address 192.168.3.1 255.255.255.0
duplex auto
speed auto
interface BRI0/3/0
no ip address
isdn incoming-voice voice
isdn static-tei 0
interface BRI0/3/1
no ip address
ip classless
ip http server
tftp-server flash:CP7905040000SCCP040701A.sbin
tftp-server flash:cmterm_7920.4.0-01-08.bin
tftp-server flash:P00305000301.sbn
control-plane
call application voice CCMEAA flash:its-CISCO.2.0.1.0.tcl
telephony-service
load 7960-7940 P00305000301
load 7905 CP7905040000SCCP040701A
load 7920 cmterm_7920.3.3-01-08
max-ephones 96
max-dn 288
ip source-address 192.168.100.1 port 2000
service dnis overlay
system message Wie kan me helpen?!?!?!
user-locale NL
network-locale NL
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 8
moh music-on-hold.au
transfer-system full-consult
ephone-dn 1 dual-line
number 1001
description Ephone 1
no huntstop
ephone-dn 2 dual-line
number 1002
description Ephone 2
ephone-dn 3 dual-line
number 1003
description Ephone 3
ephone-dn 4 dual-line
number 1001
description Ephone 1 overlay
ephone 1
mac-address 000F.F7D4.BF59
fastdial 1 1002 name Ephone2
type 7960
button 1o1,4
ephone 2
mac-address 0011.9350.8B1C
type 7905
button 1:2
ephone 3
mac-address 000A.419E.7447
type 7960
button 1:3 2o1,4
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Ik kom niet meer verder en kan niet naar buiten bellen. Weet iemand wat ik precies moet doen om het probleem op te lossen, zodat ik wel naar buiten kan bellen.
  • MeatGrinder
  • Laatst online: 03-10-2025
Zijn je ISDN interfaces wel voice interfaces (VIC) of mis je soms DSPs (pvdm modules)? Je voice-ports ontbreken namelijk. Misschien handig als je even een 'show version' post.
[ Voor 5% gewijzigd door MeatGrinder op 28-06-2005 21:54 ]
Bij deze de output van sh version:
Cisco IOS Software, 2800 Software (C2800NM-IPVOICE-M), Version 12.3(11)T4, RELEA
SE SOFTWARE (fc4)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Mon 28-Mar-05 20:33 by hqluong
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Cisco2851 uptime is 9 minutes
System returned to ROM by power-on
System image file is "flash:c2800nm-ipvoice-mz.123-11.T4.bin"
Cisco 2851 (revision 53.50) with 237568K/24576K bytes of memory.
Processor board ID FHK0842F0Q8
2 Gigabit Ethernet interfaces
2 ISDN Basic Rate interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62592K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2102
  • MeatGrinder
Post ook nog even een 'show diag' en een 'show voice dsp'. Oorzaak ligt in ieder geval in het ontbreken van of voice interfaces (VIC) of DSPs (of beiden).
Bij deze de output van show diag
Slot 0:
C2851 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : FOC083322MR
Hardware Revision : 1.0
Top Assy. Part Number : 800-21934-02
Board Revision : C0
Deviation Number : 0
Fab Version : 08
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20040816
Chassis Serial Number : FHK0842F0Q8
Chassis MAC Address : 000f.352d.b5f9
MAC Address block size : 32
CLEI Code : CNMJ500BRA
Product (FRU) Number : CISCO2851
Part Number : 73-8282-09
Version Identifier : NA
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 30 38 33 33 32 32 4D 52 40
0x10: 03 E9 41 01 00 C0 46 03 20 00 55 AE 02 42 43 30
0x20: 88 00 00 00 00 02 08 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 31 CC 70 C2 8B 46 48 4B 30 38 34 32
0x40: 46 30 51 38 C3 06 00 0F 35 2D B5 F9 43 00 20 C6
0x50: 8A 43 4E 4D 4A 35 30 30 42 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 35 31 20 20 20 20 20 20 82 49 20 5A
0x70: 09 89 20 20 4E 41 D9 02 40 C1 FF FF FF FF FF FF
WIC Slot 0:
VIC2 - BRI-NT/TE Voice daughter card (2 port)
Hardware Revision : 1.1
Top Assy. Part Number : 800-21861-01
Board Revision : B0
Deviation Number : 0-0
Fab Version : 01
PCB Serial Number : FOC09042N28
RMA History : 00
Version Identifier : V
0x00: 04 FF 40 00 51 41 01 01 C0 46 03 20 00 55 65 01
0x10: 42 42 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 30
0x20: 39 30 34 32 4E 32 38 03 00 81 00 00 00 00 04 00
0x30: 89 56 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
En de output van sh voice dsp
edsp 001 01 g729r8 p 0.1 IDLE 50/0/1.1
edsp 002 02 g729r8 p 0.1 IDLE 50/0/1.2
edsp 003 01 g729r8 p 0.1 IDLE 50/0/2.1
edsp 004 02 g729r8 p 0.1 IDLE 50/0/2.2
edsp 005 01 g729r8 p 0.1 IDLE 50/0/3.1
edsp 006 02 g729r8 p 0.1 IDLE 50/0/3.2
edsp 007 01 g729r8 p 0.1 IDLE 50/0/4.1
edsp 008 02 g729r8 p 0.1 IDLE 50/0/4.2
Ik zie inderdaad geen voice-ports in de config terug komen. En bij een dial-peer kan ik dan ook geen port commando toevoegen.
  • MeatGrinder
Qua hardware zit het toch blijkbaar wel goed, alleen bij de toewijzing van de DSP resources gaat er iets mis. Ik vermoed dat CCME alle DSP resources claimt voor transcoding doeleinden of iets dergelijks waardoor er niets meer overblijft voor de voice interfaces. Ik heb zelf CCME 3.2 gebruikt met een 2610XM/NM-2V/VIC-2BRI-S/T-TE en daarbij had ik dit probleem niet. Wellicht helpt het als je overal expliciet de zelfde codec instelt (bij voorkeur g711alaw).
Het bleek toch dat de hardware niet helemaal in orde was.
De PVDM module zat niet goed in het slot, daardoor kwamen er ook geen voice ports.
Ik heb de module verwijderd en opnieuw in het slot geduwd en jawel hoor, de voice ports zijn aanwezig.
Nu kan ik me lekker bezig gaan houden met het maken van fatsoenlijke voice translation-rules.........
