CAT5e kabel schadelijk voor de apparatuur!!
  • 114 views sinds 30-01-2008
  • witchdoc
  • Laatst online: 18-08 16:32
klopt, ben effe de link en de .pdf kwijt, maar net email gehad die er redeloijk echt uit zag waarin stond dat cat5e en hoger mogelijk schadelijk zou zijn voor een toestel dat eraan hangt..
zal maandag meer posten.. als iemand dit ook heeft gehoord: posten!
edit: hier het volledige verhaal, geript uit een .pdf
ESTA CPWG Engineering Alert
Cable ESD Alert
There has been a growing trend in the networking industry toward use of CAT-5E and CAT-6 cables and there has also been a noticeable rate of damage being done to Ethernet PHY chips from a phenomenon known as C-ESD (Cable ESD).
Research has shown that the damage comes from a differential voltage that couples through the magnetics after one of the pins on a connector makes contact and current flows from a charged cable through the center-tap of the magnetics. The semiconductor manufacturers are investigating this problem.
IEEE 802.3 will likely make a formal request to the cabling groups, in TIA and the IEC to set a standard limiting this differential voltage. Investigation has found cables that hold a charge all the way up to 6KV, just from ambient charge floating along and sticking to the newer, higher quality dielectrics. This charge builds up on a floating cable which is disconnected at both ends. The cables act like large capacitors and collect charge from the air. Permanent cabling that has one end connected to a hub or switch does not present a danger to devices connected at the outlet. The danger is present only to the first device to be connected to a floating cable.
Recommendations:
1. Do not use CAT-5E or higher cable for portable cable.
2. If CAT-5E or higher is in the permanent cable plant, momentarily short all the connectors on the RJ-45 together to discharge the cable prior to connecting the first piece of equipment to a floating link. Aluminum foil works well.
3. Unless the performance of CAT-5E or higher is required for some other applications using the cable plant, do not use it. It is not required for 10, 100, or 1000BASE-T. Most of the improvement in CAT-5E comes from the connectors, not the cable.
4. 'Cap' unterminated links with an RJ-45 shorting plug for patch panel locations that do not have a jumper to prevent C-ESD build-up.
If you have questions, please contact:
Steven B. Carlson
Co-Chair, ESTA Control Protocols Working Group
Chair, ESTA ACN Task Group
http://www.esta.org
Chair, IEEE 802.3af DTE Power via MDI Task Force
http://www.ieee802.org/3/af/index.html
503.626.4206
FAX 503.626.4206
scarlson@hspdesign.com
heb d'r nog nooit van gehoord... :? waarom zou dit dan ooit op de markt zijn gebracht?
  • witchdoc
broodrooster: het zou pas recentelijk ntdekt zijn enzo.. komt niet vaak voor en dergelijke dingen
Dit lijkt me een echte hoax.. heb er niks maar dan ook niks over gehoord....
Wa nen bullshit is da nu weer , kabels die voor die kaarten gemaakt zijn kunne verdomme toch geen schade geve ????? Anders zouden alle bedrijfjes weer lopen klage zenne
  • WFvN
  • Laatst online: 07:22
WFvN
Gosens Koeling en Warmte
Hehehe.... zouden die kabels soms extra magnetisch veld oppikken en die handel (net als een spoel) in een stroom omzetten.... I mean inductiespanning... VEEEEEL inductiespanning....
Handig man... gratis energiebron... gewoon ff een metertje of 100 UPT cat5 kopen, bij je pc in de powersupply prikken......... |:(
Oftewel... kgloof er geen ruk van
  • mossel
Waarom post je niet voordat je zoiets zeker weet :? Beetje zitten gissen heeft geen zin.
Ik snap het wel, maar ik begrijp het niet. [q]Bassie[/q]
Een kabel geeft iets door, maakt geen ene reet uit wat het is, het zou dus een kabel moeten zijn die zo slim is dattie hetgeen ie doorgeeft versterkt?
Zou een knappe kabel zijn dan.
Ik geloof er geen ruk van (zelfs niet een beetje).
1. klint niet aannemelijk
2. was al eerder bekend geworden en ondertussen had iedereen het via de tam-tam al gehoord (maar nee, zelfs onze Cisco / Cabletron en AT&T distro weet van nix).
Wel leuk bedacht :)
K'heb een cat5e cable op mijn celly 533 en PII 233 en tot nu geen rook ;))
100mbit kaart op een 1000mbit cable Talk about overbodig
  • witchdoc
Op vrijdag 12 januari 2001 22:59 schreef mossel het volgende:
de vraag was dus ook of iemand anders het nog gehoord had he mossel :)
  • witchdoc
het verhaald nog maar eens :)
Cable ESD Alert
Recommendations:
Steven B. Carlson
http://www.esta.org
503.626.4206
FAX 503.626.4206
Ja ik hep het al gehoort (je post het bericht voor de 2e keer |:(....) er zijn domme mensen he :P
  • witchdoc
Op maandag 15 januari 2001 08:54 schreef voxell het volgende:
mm, beetje beleefd mag ook hor :(
en eerste edit haalde het topic niet naar boven dus post als in *bump*
  • Uitvreter
  • Laatst online: 24-08 22:03
Uitvreter
Eet niet thuis vanavond
Ik ken de specificaties van cat 5e niet. Feit is dat een geleider (utp kabel) in een veranderend magnetisch veld een elektrische lading oppikt. Om die lading groot genoeg te laten zijn om schade aan je netwerkspullen aan te richten, moet zo'n geleider bij voorkeur in een nogal sterk wisselend magnetisch veld zitten, liefst over een lange afstand, en bovendien moet de kabel uitstekende isolatie hebben om de lading niet weg te laten lekken voordat iemand de stekker er in prikt.
Ik geloof niet dat we ons als tweakers met korte, goedkope kabeltjes ernstig zorgen hoeven te gaan maken, maar als je professioneel met grote netwerken bezig bent kan ik me best voorstellen dat je zo'n kabel eerst even aardt voordat je hem aansluit.
May clinging breasts always come to your aid in the kitchen!
even ervan uitgaande dat die site en organisatie echt bestaat (ben te lui om te kijken), als je de volledige headers van't emailtje nou eens checked, misschien is daar zo te zien dat't een fake mailtje is..
  • d-Frag
  • Laatst online: 12-07 10:26
d-Frag
74% completed
FF klikken en wat zie ik echt een betouwbare site: |:(
(de eerste regels van de pagina).
Building the Business of Show Business
ESTA is a non-profit trade association representing the North American entertainment technology industry. Our members include dealers, manufacturers, reps, service and production companies, scenic houses, designers and consultants. Click here to see what ESTA Members do for the Entertainment Industry.
The Association addresses areas of common concern such as technical standards, customer service, equipment quality, business practices, insurance, and credit reporting. ESTA provides a wide variety of services to Members in the areas of education and information exchange, member promotion, trade show participation, reduced costs on business services and credit assistance.
Het is beter op onvolmaakte wijze invulling te geven aan je eigen bestemming, dan op volmaakte wijze het leven van iemand anders te leiden. - Bhagavad Gita -
