[FC4] Yum
Hallo ik heb net mijn Fedora Core 4 test3 geupdate naar Fedora core 4 (stable)
maar als ik in mijn yum.conf kijk is hij nu bijna leeg:
[main]
cachedir=/var/cache/yum
debuglevel=2
logfile=/var/log/yum.log
pkgpolicy=newest
distroverpkg=redhat-release
tolerant=1
exactarch=1
retries=20
obsoletes=1
gpgcheck=1
# PUT YOUR REPOS HERE OR IN separate files named file.repo
# in /etc/yum.repos.d
Dus toen wou ik livna toevoegen dus deed ik dit erbij
[fedora.us-stable]
name=Fedora.us Stable
baseurl=http://download.fedora.us/fedora/fedora/$releasever/$basearch/RPMS.stable/
gpgcheck=1
[fedora.us-testing]
name=Fedora.us Testing
baseurl=http://download.fedora.us/fedora/fedora/$releasever/$basearch/RPMS.testing/
gpgcheck=1
[fedora.us-unstable]
name=Fedora.us Unstable
baseurl=http://download.fedora.us/fedora/fedora/$releasever/$basearch/RPMS.unstable/
gpgcheck=1
[livna-stable]
name=Livna stable
baseurl=http://rpm.livna.org/fedora/$releasever/$basearch/yum/stable/
gpgcheck=1
[livna-testing]
name=Livna testing
baseurl=http://rpm.livna.org/fedora/$releasever/$basearch/yum/testing/
gpgcheck=1
[livna-unstable]
name=Livna unstable
baseurl=http://rpm.livna.org/fedora/$releasever/$basearch/yum/unstable/
gpgcheck=1
Maar toen gaf hij deze fout:
Setting up Install Process
Setting up repositories
http://rpm.livna.org/fedo...able/repodata/repomd.xml: [Errno 4] IOE rror: HTTP Error 404: Date: Sat, 25 Jun 2005 11:41:00 GMT
Server: Apache/2.0.51 (Fedora)
Content-Length: 323
Connection: close
Content-Type: text/html; charset=iso-8859-1
Trying other mirror.
Cannot open/read repomd.xml file for repository: livna-stable
failure: repodata/repomd.xml from livna-stable: [Errno 256] No more mirrors to t ry.
Toen ik naar de site ging (http://rpm.livna.org/fedo...table/repodata/repomd.xml) deed hij het niet,omdat op die site geen yum file zit onder fedoracore 4 (wel bij 3) maar de url voor de repomd.xml onder fedora core 4 is http://rpm.livna.org/fedora/4/i386/RPMS.lvn/repodata/
hoe kan ik dit laten werken (livna voor fc4)
  • joggie
  • Laatst online: 03-02-2025
joggie
Wie niet gek is, is saai
Op de fedorafaq.org site kon je tot Fedora Core 3 een Yum.conf file downloaden, die goed werkte. Ik heb zelf een tijdje terug ook de Stable versie van Fedora Core 4 geinstalleerd, en had hetzelfde probleem.
Op deze link - http://rpm.livna.org/configuration.html#Core4 - vind je een beschrijving hoe je de livna Repro voor Fedora Core 4 kunt toevoegen.
Succes.
Joggie ;)
Kijk eens in yum.repos.d in /etc
