[js + php] Volgorde in selectbox wordt niet verstuurd
Ik heb de volgende code:
url: http://dev1.topsite.nl/test.php
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>test</title>
<script type="text/javascript" language="javascript">
function move(index,to) {
    var list = document.getElementById('list');
    var total = list.options.length-1;
    if (index == -1) return false;
    if (to == +1 && index == total) return false;
    if (to == -1 && index == 0) return false;
    var items = new Array;
    var values = new Array;
    for (i = total; i >= 0; i--) {
        items[i]  = list.options[i].text;
        values[i] = list.options[i].value;
        if (index == i) {
            list.options[i + to] = new Option(items[i],values[i + to], 0, 1);
            list.options[i] = new Option(items[i + to], values[i]);
            i--;
        } else {
            list.options[i] = new Option(items[i], values[i]);
    list.focus();
function toggleList(blnSelect){
    for (i = total; i >= 0; i--){
        list.options[i].selected = blnSelect;
        alert('Value: '+list.options[i].value+' - Text: '+list.options[i].text);
    return blnSelect;
</script>
</head>
<body>
<form onsubmit="return toggleList(true);" method="post" action="" name="form">
<select name="list[]" size="5" multiple="multiple" id="list" style="width: 200px;">
      <option value="optie1">optie 1</option>
      <option value="optie2">optie 2</option>
      <option value="optie3">optie 3</option>
      <option value="optie4">optie 4</option>
      <option value="optie5">optie 5</option>
  </select>
    <p>
    <a href="javascript:void(0);" onclick="javascript:move(document.getElementById('list').selectedIndex,-1)";>omhoog</a><br />
    <a href="javascript:void(0);" onclick="javascript:move(document.getElementById('list').selectedIndex,+1)";>omlaag</a><br />
    <a href="javascript:void(0);" onclick="javascript:toggleList(true);">alles selecteren</a><br />
    <a href="javascript:void(0);" onclick="javascript:toggleList(false);">reset</a>
    </p>
    <input type="submit" name="Submit" value="Submit" />
</form>
print '<pre>';
print_r($_POST['list']);
print '</pre>';
</body>
</html>
Ik pas dus middels javascript de volgorde aan.
Na het submitten worden de verstuurde waarden getoond.
Hieruit blijkt dus dat de originele volgorde wordt verstuurd en NIET de aangepaste volgorde.
Kan iemand mij vertellen wat ik fout doe en eventueel aangeven hoe ik het aan moet pakken?
  • MueR
  • Laatst online: 22:06
MueR
Admin Devschuur® & Discord
is niet lief
Je zal de value van het object moeten veranderen. Er eventueel een 2e cijfer achter zetten, welke de volgorde aangeeft.
Anyone who gets in between me and my morning coffee should be insecure.
Die wordt toch veranderd?! De volgorde blijkt uit de index van $_POST['list'] ... dus dat komt wel goed.
[ Voor 60% gewijzigd door Verwijderd op 24-06-2005 11:52 ]
  • ecageman
  • Laatst online: 19-06 21:42
Als ik het test, dan zie ik middels de popups de values nog steeds in de originele volgorde voor bij komen, alleen de text is in de volgorde die ikzelf had aangegeven. Dus je zult toch echt wat met de values moeten doen.
AMD Athlon 2800+, MSI K7N2Delta-L, 1024MB PC3200, SB Audigy2, XFX GF4MX440, BenQ DVD+-RW, NEC 1300A DVD+-RW, 2x WD 120GB 8mb, 2x Maxtor 250GB, Chenbro Gaming Bomb, Tagan 480W, 17" Iiyama monitor
  • Janoz
  • Laatst online: 21-09 13:51
Janoz
Moderator Devschuur®
!litemod
Over de volgorde wordt helemaal niks gegarandeerd. Je kunt beter aan het onSubmit event een stukje javascript hangen die de volgorde uitleest en dit in een hidden field op slaat. Dat veld kun je vervolgens binnen je php gebruiken.
