Als je wilde overklokken, had je beter een Asus P4T mobo kunnen nemen ($). Thomas Pabst had geen moeite om de P4 middels FSB te overklokken:
Many of the overclockers of this world were afraid that Pentium 4's quad-pumped 100 MHz bus would make bus overclocking of this processor as difficult and restrictive as with Athlon and its dual-pumped 133/100 MHz-bus. I can bring you the surprisingly positive news that Pentium 4 is as overclockable as Intel processors always have been. You can imagine that the multiplier of official Pentium 4 processors will be locked, but with a good P4-motherboard you won't have any problems overclocking the bus.
I took advantage of the jumperless-mode of the Asus P4T-motherboard and managed to let two different Pentium 4 processors run at up to 125 MHz bus clock. I even included a 1.4 GHz Pentium 4 overclocked to 14 x 115 MHz = 1610 MHz as well as the evaluation 1.5 GHz Pentium 4 overclocked to 16 x 108 MHz = 1728 MHz in the benchmark results. I only had to raise the voltage from 1.7 to 1.8 V. There was no thermal issue, as Pentium 4 heat sinks are already designed for much higher heat dissipation than what current Pentium 4 processors are actually able to produce.
Intel mobo omruilen/verkopen -> Asus P4T halen
? Kun je later altijd nog een 2Ghz in douwen en overklokken...Of de nieuwe Gigabyte GA-8TX P4 mobo. Die ondersteunt FSB's van 100/105/110/133 MHz (x4 quadpumped) en is goedkoper dan de Asus. Mzzl.
