DFI LANPARTY UT nF3 ULTRA-D
  • 82 views sinds 30-01-2008
Matched: nforce3, ultra, dfi, d
Zijn er reeds gebruikers ervaringen betreffende onderstaande moederbord. Dit bord is sinds vorige week te koop in Nederland (http://www.tweakers.net/pricewatch/119722)
DFI LANPARTY UT nF3 ULTRA-D (S939 en AGP )
Afbeeldingslocatie: http://www.magix-photos.com/mediapool/CD/B1/90/00/DA/5D/11/D9/B7/67/DA/92/82/59/EF/6A/10/8B65C8B0DE4A11D984F6249C8259EF6A.jpg
Afbeeldingslocatie: http://www.magix-photos.com/mediapool/CD/B1/90/00/DA/5D/11/D9/B7/67/DA/92/82/59/EF/6A/10/8CFC6E40DE4A11D9BB0DD3A48259EF6A.jpg
Specificaties:
CPU
• AMD Athlon 64 FX / Athlon 64 / Sempron
• Socket 939
Chipset:
• nVIDIA® nForce3 Ultra
Front Side Bus
• 2000MT/s HyperTransport interface
Memory
• Four 184-pin DDR SDRAM DIMM sockets
• Supports dual channel (128-bit wide) memory interface
• Supports up to 4GB system memory
• Supports PC2100 (DDR266), PC2700 (DDR333) and PC3200 (DDR400) DDR SDRAM DIMM
BIOS
• Award BIOS
• CPU/DRAM/AGP overclocking
• CPU/DRAM/Chipset overvoltage
• 4Mbit flash memory
• AMD Cool‘n’Quiet technology
Power Management
• Supports ACPI STR (Suspend to RAM) function
• Wake-On-Events include:
- Wake-On-PS/2 Keyboard/Mouse
- Wake-On-Ring (external modem)
- Wake-On-LAN
- RTC timer to power-on the system
• AC power failure recovery
Hardware monitor
• Monitors CPU/system temperature
• Monitors VCC3/5V/12V/5Vsb/Vbat voltages
• Monitors the speed of the cooling fans
• CPU Overheat Protection function monitors CPU temperature during system boot-up
Audio
• Realtek 6-channel audio CODEC
• S/PDIF-in/out interface
LAN
• Gigabit PHY
• Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and
802.3ab (1000BASE-T) standards
IDE
• Two IDE connectors support four UltraDMA 133Mbps hard drives
• NVIDIA RAID allows RAID arrays spanning across Serial ATA and Parallel ATA
• RAID 0, RAID 1, RAID 0+1 and JBOD
Serial ATA with RAID
• Four Serial ATA interfaces with speed up to 1.5Gbps
- Two Serial ATA ports supported by nForce3 Ultra chip
- Two Serial ATA ports supported by Marvell SATA PHY
IEEE 1394
• VIA VT6307 controller
• Supports two 100/200/400 Mb/sec ports
AGP
• Supports AGP 8x up to 2132MB/sec. and AGP 4x up to 1066MB/sec. bandwidth
for 3D graphics applications
• Supports 0.8/1.5V add-in card
Rear Panel I/O Ports
• 1 PS/2 mouse port
• 1 PS/2 keyboard port
• 1 DB-25 parallel port
• 2 S/PDIF RCA jacks (S/PDIF-in and S/PDIF-out)
• 1 DB-9 serial port
• 1 IEEE 1394 port
• 1 RJ45 LAN port
• 4 USB 2.0/1.1 ports
• Line-in, line-out and mic-in jacks
I/O Connectors
• 2 connectors for 4 additional external USB 2.0/1.1 ports
• 1 connector for 1 external IEEE 1394 port
• 1 front audio connector for external line-out and mic-in jacks
• 1 CD-in internal audio connector
• 1 S/PDIF connector for optical cable connection
• 1 IrDA connector
• 4 Serial ATA connectors
• 2 IDE connectors
• 1 floppy connector
• 1 20-pin ATX power connector
• 1 4-pin ATX 12V power connector
• 1 front panel connector
• 3 fan connectors
• EZ touch switches (power switch and reset switch)
Expansion Slots
• 1 AGP 8x/4x slot
• 5 PCI slots
PCB
• ATX form factor
• 30.5cm (12") x 24cm (9.44")
Link naar fabrikant:
http://www.dfi.com.tw/Pro...&CATEGORY_TYPE=LP&SITE=US
Met dank aan:
http://www.hardwareasylum.com/forums/showthread.php?p=430
[ Voor 28% gewijzigd door Verwijderd op 16-06-2005 12:18 ]
  • ShellGhost
  • Laatst online: 16-12-2021
Geen matches
  • PASware
  • Laatst online: 21:04
Matched: d
Leuke concurrent van de MSI K8N Neo2 Platinum en nog wat goedkoper ook
Tesla Model 3 SR+ | 4425wp (Dak) - 1920wp (platdak) - 840wp (gevel 90gr) | Panasonic 5kW warmtepomp | Hewalex WPB 200L boiler
Net zoals de andere Nforce3 moederborden:
Epox 9NDA3+, Nforce3 Ultra
MSI K8N Neo2 Platinum, nForce 3 Ultra
Gigabyte GA-K8NSNXP-939, nForce3 Ultra
En dan vooral de prijs en als DFI kennende is het ook nog een leuke overklokker :P .
[ Voor 14% gewijzigd door Verwijderd op 16-06-2005 12:25 ]
  • BalusC
BalusC
Carpe diem
Matched: d
Sorry, dit is niet echt de manier om een ervaringentopic te starten ;) Check de tweede post van PMG Beleid voor hoe het wel moet.
