[Fedora core 4] yum
Hallo
Ik heb net Fedora core 4 geinstalleerd maar yum doet het niet goed wie kan me helpen hiermee.
Setting up Update Process
Setting up repositories
development 100% |=========================| 1.1 kB 00:00
extras-development 100% |=========================| 1.1 kB 00:00
livna-stable 100% |=========================| 951 B 00:00
livna-unstable 100% |=========================| 951 B 00:00
livna-testing 100% |=========================| 951 B 00:00
Cannot open/read repomd.xml file for repository: extras
failure: repodata/repomd.xml from extras: [Errno 256] No more mirrors to try.
mijn yum.conf:
[main]
cachedir=/var/cache/yum
debuglevel=2
logfile=/var/log/yum.log
pkgpolicy=newest
distroverpkg=fedora-release
tolerant=1
exactarch=0
# Added this because some mirrors go down and then retying takes forever.
retries=1
timeout=10
# Basic Repos are in /etc/yum.conf.d/ #
## Fedora Extras ##
[extras]
name=Fedora Extras - $releasever - $basearch
baseurl=http://fr2.rpmfind.net/linux/fedora/extras/$releasever/$basearch/
http://mirrors.kernel.org...as/$releasever/$basearch/
http://mirror.hiwaay.net/...as/$releasever/$basearch/
http://www.mirrorservice....as/$releasever/$basearch/
# http://download.fedora.re...as/$releasever/$basearch/
gpgcheck=0
gpgkey=http://download.fedora.redhat.com/pub/fedora/linux/extras/RPM-GPG-KEY-Fedora-Extras
## Livna.org ##
[livna-stable]
name=Livna.org - Fedora Compatible Packages (stable)
baseurl=http://rpm.livna.org/fedora/$releasever/$basearch/RPMS.stable
http://livna.cat.pdx.edu/...ver/$basearch/RPMS.stable
#gpgcheck=1
[livna-unstable]
name=Livna.org - Fedora Compatible Packages (unstable)
baseurl=http://rpm.livna.org/fedora/$releasever/$basearch/RPMS.unstable
http://livna.cat.pdx.edu/...r/$basearch/RPMS.unstable
#gpgcheck=1
[livna-testing]
name=Livna.org - Fedora Compatible Packages (testing)
baseurl=http://rpm.livna.org/fedora/$releasever/$basearch/RPMS.testing
http://livna.cat.pdx.edu/...er/$basearch/RPMS.testing
#gpgcheck=1
# Jpackage #
# JPackage is a GREAT repository for Java Software.
# However, you may have to compile some SRPMs to use it,
# so it's commented out by default. See
# <http://mirrors.sunsite.dk/jpackage/1.6/generic/non-free/SRPMS>
# For the SRPMs, and <http://www.jpackage.org/rebuilding.php> for
# the general details.
# Note: JPackage IS compatible with the fedora.us repositories.
# You can use JPackage and fedora.us at the same time, without
# any trouble. It's also compatible with the Alternate Repositories,
# for the most part.
[jpackage-generic]
name=JPackage Cross-Platform Packages
baseurl=http://mirrors.sunsite.dk/jpackage/1.6/generic/free
ftp://jpackage.hmdc.harvard.edu/JPackage/1.6/generic/free
http://sunsite.informatik...jpackage/1.6/generic/free
failovermethod=priority
enabled=0
#gpgcheck=1
[jpackage-fedora]
name=JPackage Fedora Packages
baseurl=http://mirrors.sunsite.dk/jpackage/1.6/fedora-$releasever/free
ftp://jpackage.hmdc.harva...6/fedora-$releasever/free
http://sunsite.informatik...6/fedora-$releasever/free
enabled=0
#gpgcheck=1
## Alternate Repositories ##
# To use these repos, either use the --enablerepo
# command-line argument to yum, or change "enabled=0"
# to "enabled=1". Note: Some packagesfrom these repositories
# may conflict with the fedora.us packages. If you use these
# repositories, you may wish to disable the fedora.us and
# livna.org repositories.
[freshrpms]
name=FreshRPMs
mirrorlist=http://ayo.freshrpms.net/fedora/linux/$releasever/mirrors-freshrpms
enabled=0
#gpgcheck=1
[dag]
name=Dag APT Repository
baseurl=http://dag.freshrpms.net/fedora/$releasever/en/$basearch/dag/
http://dag.atrpms.net/fedora/$releasever/en/$basearch/dag/
http://ftp.heanet.ie/pub/...easever/en/$basearch/dag/
enabled=0
#gpgcheck=1
[dries]
name=Dries APT/YUM Repository
baseurl=http://ftp.freshrpms.net/pub/dag/dries/fedora/linux/$releasever/$basearch/dries/RPMS/
http://mirrors.ircam.fr/p...ver/$basearch/dries/RPMS/
http://apt.sw.be/dries/fe...ver/$basearch/dries/RPMS/
http://dries.studentenweb...ver/$basearch/dries/RPMS/
enabled=0
#gpgcheck=1
[newrpms]
name=NewRPMs
baseurl=http://newrpms.sunsite.dk/apt/redhat/en/$basearch/fc$releasever
http://newrpms.atrpms.net...n/$basearch/fc$releasever
enabled=0
#gpgcheck=1
[atrpms]
name=ATrpms - Stable
baseurl=http://apt.atrpms.net/fedora/$releasever/en/$basearch/at-stable
http://ftp-stud.fht-essli...er/en/$basearch/at-stable
http://wftp.tu-chemnitz.d...er/en/$basearch/at-stable
enabled=0
#gpgcheck=1
[atrpms-testing]
name=ATrpms - Testing
baseurl=http://wftp.tu-chemnitz.de/pub/linux/ATrpms/fedora/$releasever/en/$basearch/at-testing
http://apt.atrpms.net/fed...r/en/$basearch/at-testing
http://ftp-stud.fht-essli...r/en/$basearch/at-testing
enabled=0
#gpgcheck=1
# Warning: Don't enable this "bleeding" repo if you want stable software!
[atrpms-bleeding]
name=ATrpms - Bleeding
baseurl=http://apt.atrpms.net/fedora/$releasever/en/$basearch/at-bleeding
http://ftp-stud.fht-essli.../en/$basearch/at-bleeding
http://wftp.tu-chemnitz.d.../en/$basearch/at-bleeding
enabled=0
#gpgcheck=1
## Miscellaneous ##
# Semi-official Macromedia repository containing the flash-plugin rpm.
[flash]
name=macromedia.mplug.org - Flash Plugin
baseurl=http://macromedia.mplug.org/apt/fedora/$releasever
http://sluglug.ucsc.edu/macromedia/apt/fedora/$releasever
http://ruslug.rutgers.edu/macromedia/apt/fedora/$releasever
http://macromedia.rediris.es/apt/fedora/$releasever
enabled=0
#gpgcheck=1
Fedora Core 4 is nog niet uit, maandag pas :)
[extras-development]
name=Fedora Extras $releasever - Development Tree
#baseurl=http://download.fedora.redhat.com/pub/fedora/linux/extras/development/$basearch/
mirrorlist=http://fedora.redhat.com/download/mirrors/fedora-extras-devel
enabled=1
gpgcheck=0
Probeer dit eens voor extra's
Dit is de test versie Fedora core 4 test3
en nog bedankt voor je post ik ga het nu testen.
ik heb het gedaan hij doet het nu wel maar soms hangt hij als ik aan het dupdaten ben.
maar daar ga ik nu ff naar kijken maar ik heb nog 1 noob vraagje.
als je een rpm installeert waar kan je hem vinden als hij geinstalleert is ? hoe moet je hem opstarten?
  • Emielio
  • Laatst online: 25-10 19:23
Als het goed is kan je hem dan van overal starten.
Opleiding Brandveiligheid
Verwijderd schreef op zaterdag 11 juni 2005 @ 02:17:
Dat komt dan vast omdat je zoveel repositories hebt en er eentje stuk is ofzo :) Haal de reps die je niet gebruikt gewoon weg...
Voor console apps kun je meestal als volgt de 'binaries' die een pakket geinstalleerd heeft vinden:
rpm -ql <packagename> | grep bin
Bijvoorbeeld:
[fkooman@dilithium ~]$ rpm -ql less | grep bin
/usr/bin/less
/usr/bin/lessecho
/usr/bin/lesskey
/usr/bin/lesspipe.sh
Dit geldt dus voor console appjes, voor grafische apps hoort er gewoon een item in 't menu bij te komen, zoniet is 't een bug :)
Ja bedankt hij was eerst niet goed geinstalleerd daarom zag ik de rpm's niet terug maar alles doet het nu:D
Oke maar ik ben nu bezig met linux maar dan heb ik een totaal andere vraag.
Ik heb een txt file met een uitleg erin staan, en helemaal aan de onderkant staat dit.
Below is the schematic diagram (gps_jammer.ps) in an uuencoded gzipped
PostScript file. This is the native Xcircuit[12] format and is used for
ease of viewing, printing and modification.
<++> ./gps_jammer.ps.gz.uue
begin 644 gps_jammer.ps.gz
M'XL("&A2XST``V=P<U]J86UM97(N<',`[7UKCQNYLMAGZU<P"`QHL5<SW>RW
MD1/$'MN[>ZX?$X_W$62#A4;JF=%:H]:1-'X<8_][ZL%7=Y/J'I\)@@1WX94X
MS6*Q6"P6JXK%UN/_='XQ>[IL+NM9<A*)%^<7+[$P>?SX_>JPKI^(Z^W^CS_G
Zo gaat het maar door, en helemaal onder.
M1'[Q+5I+7(I"N=Q\]&//L@W0]GH__UCCO@2[4HW)7)^V\^MZ,GG\^/UNOEK7
9N\EO9S^].W.AH.[%VY>3_PU'_`Z`=[X`````
end
<--> ./gps_jammer.ps.gz.uue
|=[ EOF ]=---------------------------------------------------------------=|
  • VROEM!
  • Laatst online: 18-05-2025
VROEM!
broembroem!
Het is een postscript file, ofwel de code die je anders 1:1 de printer in prakt als je print :)
Jij kunt er geen chocola van maken, maar de printer weet wel wat ie er mee moet.
ieeeepppppp :P
