VB . NET 2005 communicatie met access database
  • 58 views sinds 30-01-2008
hoi, ik was een check in list aant maken voor mijn LAN organisatie, maar nu lukt me 1ding nie, schrijven-delete-update van de database wilt niet. er uit lezen gaat wel
hier is mijn code:
Imports System.Data.DataSet
Imports System.Data
Imports System.Xml
Public Class Form1
Public MaxRows
Dim inc As Integer
Dim con As New OleDb.OleDbConnection
Dim ds As New DataSet
Dim da As OleDb.OleDbDataAdapter
Dim temp As Integer
Dim sql As String
Private Sub NavigateRecords()
IDTextBox.Text = ds.Tables("list").Rows(inc).Item(0)
UsernameTextBox.Text = ds.Tables("list").Rows(inc).Item(1)
VoornaamTextBox.Text = ds.Tables("list").Rows(inc).Item(3)
AchternaamTextBox.Text = ds.Tables("list").Rows(inc).Item(4)
PostcodeTextBox.Text = ds.Tables("list").Rows(inc).Item(5)
PlaatsTextBox.Text = ds.Tables("list").Rows(inc).Item(6)
LandTextBox.Text = ds.Tables("list").Rows(inc).Item(6)
GeslachtTextBox.Text = ds.Tables("list").Rows(inc).Item(8)
txtgebdat.Text = ds.Tables("list").Rows(0).Item(inc)
HomepageTextBox.Text = ds.Tables("list").Rows(inc).Item(10)
Msn_adressTextBox.Text = ds.Tables("list").Rows(inc).Item(11)
EmailTextBox.Text = ds.Tables("list").Rows(inc).Item(2)
ProcessorTextBox.Text = ds.Tables("list").Rows(inc).Item(12)
Inter_geheugenTextBox.Text = ds.Tables("list").Rows(inc).Item(13)
Video_GPUTextBox.Text = ds.Tables("list").Rows(inc).Item(14)
End Sub
Private Sub btnnext_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnnext.Click
If inc <> MaxRows - 1 Then
inc = inc + 1
NavigateRecords()
Else
MsgBox("No More Rows")
End If
End Sub
Private Sub btnvorig_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnvorig.Click
If inc > 0 Then
inc = inc - 1
NavigateRecords()
ElseIf inc = -1 Then
MsgBox("No Records Yet")
Else
MsgBox("First Record")
End If
End Sub
Private Sub btnlast_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnlast.Click
inc = MaxRows - 1
NavigateRecords()
End If
End Sub
Private Sub btnfirst_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnfirst.Click
If inc <> 0 Then
inc = 0
NavigateRecords()
End If
End Sub
Public Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
'TODO: This line of code loads data into the 'ListDataSet11.gegevens' table. You can move, or remove it, as needed.
Me.GegevensTableAdapter1.Fill(Me.ListDataSet11.gegevens)
con.ConnectionString = "PROVIDER=Microsoft.Jet.OLEDB.4.0;Data Source = C:\Program Files\VB log in systeem\list.mdb"
con.Open()
sql = "SELECT * FROM gegevens"
Dim da = New OleDb.OleDbDataAdapter(sql, con)
da.Fill(ds, "list")
da.update(ds, "list")
con.Close()
MaxRows = ds.Tables("list").Rows.Count
inc = -1
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
End
End Sub
Private Sub btnupdate_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnupdate.Click
con.Open()
sql = "Update list SET list WHERE list"
Dim cb As New OleDb.OleDbCommandBuilder(da)
ds.Tables("list").Rows(inc).Item(0) = IDTextBox.Text
ds.Tables("list").Rows(inc).Item(1) = UsernameTextBox.Text
ds.Tables("list").Rows(inc).Item(3) = VoornaamTextBox.Text
ds.Tables("list").Rows(inc).Item(4) = AchternaamTextBox.Text
ds.Tables("list").Rows(inc).Item(5) = PostcodeTextBox.Text
ds.Tables("list").Rows(inc).Item(6) = PlaatsTextBox.Text
ds.Tables("list").Rows(inc).Item(6) = LandTextBox.Text
ds.Tables("list").Rows(inc).Item(8) = GeslachtTextBox.Text
ds.Tables("list").Rows(0).Item(inc) = txtgebdat.Text
ds.Tables("list").Rows(inc).Item(10) = HomepageTextBox.Text
ds.Tables("list").Rows(inc).Item(11) = Msn_adressTextBox.Text
ds.Tables("list").Rows(inc).Item(2) = EmailTextBox.Text
ds.Tables("list").Rows(inc).Item(12) = ProcessorTextBox.Text
ds.Tables("list").Rows(inc).Item(13) = Inter_geheugenTextBox.Text
ds.Tables("list").Rows(inc).Item(14) = Video_GPUTextBox.Text
da.Update(ds, "list")
con.Close()
MsgBox("Succesvol geupdate")
End Sub
Private Sub btnaddnew_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnaddnew.Click
If inc <> -1 Then
Dim dsNewRow As DataRow
dsNewRow = ds.Tables("AddressBook").NewRow()
ds.Tables("list").Rows.Add(dsNewRow)
MsgBox("New Record added to the Database")
End If
End Sub
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
If MessageBox.Show("Do you really want to Delete this Record?", _
"Delete", MessageBoxButtons.YesNo, _
MessageBoxIcon.Warning) = DialogResult.No Then
MsgBox("Operation Cancelled")
Exit Sub
Else
ds.Tables("list").Rows(inc).Delete()
MaxRows = MaxRows - 1
inc = 0
NavigateRecords()
End If
End Sub
End Class
dank bij voorbaat
Cassini
  • gorgi_19
  • Laatst online: 09-10 17:28
gorgi_19
Kruimeltjes zijn weer op :9
En verwacht je dat we nu gaan raden waar de fout zit, welke foutmelding je krijgt en wat de oplossing is? :?
Digitaal onderwijsmateriaal, leermateriaal voor hbo
dat er een syntaxisfout in UPDATE zit
en ik vind ze echt nier ;(
  • gorgi_19
gorgi_19
Verwijderd schreef op dinsdag 07 juni 2005 @ 20:02:
En nu de precieze foutmelding?
En echo je update statement eens; de rest van je code hebben we niet nodig
En je UPDATE statement heeft niet de juiste syntax. Zie http://www.w3schools.com/sql/sql_update.asp
[ Voor 16% gewijzigd door gorgi_19 op 07-06-2005 20:15 ]
Afbeeldingslocatie: http://users.skynet.be/fa040582/update.JPG
con.Open()
con.Close()
End Sub
volgens mij scheeld er wat aan die sql regel
maar ik zie niet goed in hoe ik da van www.w3schools.com in deze code kan verwerken...
  • NMe
  • Laatst online: 29-09 10:17
NMe
Quia Ego Sic Dico.
Sorry, maar hier beginnen we niet aan. Als je een probleem hebt, isoleer dan het stukje code waar de fout zit, en post dat stukje (tussen [code]-tags). Als je dat gedaan hebt dan kun je een nieuw topic openen, waarin je de exacte foutmelding vermeldt, en ook wat je al gezocht en gevonden hebt, en waarom je er daarmee niet uit kwam. Lees ook de volgende stukjes uit de FAQ even:
P&W FAQ - De "quickstart"
P&W FAQ - Leer **** debuggen!!
Overigens:
WTF? :? Lees even een tutorial: www.sqlcourse.com
[ Voor 10% gewijzigd door NMe op 07-06-2005 20:27 ]
