[Ervaringen] Acer 4150
ik ben opzoek naar een nieuwe laptop en ik kwam laats deze acer tegen
Afbeeldingslocatie: http://www.acer.nl/acereuro/wr-resource/2114140475/upload/E0Entity3/1/TM4100_normal.jpg
Operating System
Microsoft® Windows® XP Home
Processor & Chipset
Mobile Intel® Centrino™ Technology
Intel® Pentium® M processor with 2MB L2 Cache and supporting Enhanced Intel® SpeedStep® Technology
Intel® 915PM/915GM Express chipset with 533MHz FSB
Wireless: Integrated Intel® PRO/Wireless 2200 BG network connection
Memory
DDR333 memory, upgradeable to 2 GB using dual soDIMM modules
HDD
ATA/100 hard disc drive
Storage
Integrated DVD-Dual drive
Display
15.0" XGA TFT LCD with 1024 x 768 pixel resolution
15.4" WXGA TFT LCD with 1280 × 800 pixel resolution; 16:10 viewing ratio
16.7 million colours
MPEG-2/DVD hardware-assisted capability
Support S-video (NTSC/PAL) TV-out
Graphics
ATI MOBILITY™ RADEON® X600, with 64 MB of external DDR video RAM, supporting ATI POWERPLAY™ 5.0, Microsoft® DirectX® 9.0, PCI Express™ and DualView™
Simultaneous LCD and CRT display, with LCD panel resolution at 70 Hz
MPEG-2/DVD hardware assisted capability
Multimedia
Audio system with two built-in speakers
MS-Sound compatible
Built-in microphone
Communication
10/100Mbps Fast Ethernet; Wake-on-LAN ready
56K ITU V.92 modem with PTT approval; Wake-on-Ring ready
Integrated Intel® PRO/Wireless 2200BG network connection 802.11b/g dual band Wi-Fi CERTIFIED™ solution
Acer SignalUp wireless technology support
I/O Interfaces
3x USB 2.0
1x Infrared (FIR)
1x VGA for external monitor
1x PC Card slot (Type II)
1x S-video out (NTSC/PAL)
1x IEEE 1394 port
1x Modem (RJ-11) port
1x Ethernet (RJ-45) port
1x speaker/ headphone/ line-out jack
1x microphone/ line-in jack
1x DC-in jack for AC adapter
Security
Slot for Kensington lock
BIOS user and supervisor passwords
Power supply and battery
ACPI power management supporting Standby and Hibernation modes
65 W Li-ion battery pack
Battery life:
4 hours
1.5-hour rapid charge, 3.5-hour charge-in-use
65 W AC Adapter
Keyboard & Special Controls
88-/89-key Acer FineTouch™ keyboard with a 5-degree curve, inverted "T" cursor layout; 2.5 mm (minimum) key travelTouchpad with 4-way integrated scroll button
12 function keys; four cursor keys; two Windows® keys; hotkey controls; embedded numeric keypad; international language support
Four easy-launch buttons: Internet browser, email with LED, Empowering Key, and one user-programmable button
Weight and dimensions
364 (W) x 279 (D) x 33.9/38.9 (H) mm
(14.3 x 11.0 x 1.3/1.5 inches)
2.95 kg* (6.48 lbs.) for 15.4" WXGA LCD model
(*actual weight may differ, depending on configuration)
Quality & Reliability Tests
Temperature & humidity test
Free drop test
Acoustics test
Weight and pressure test
Shock and vibration test
MTBF (Mean Time Between Failure) test
Hinge life test
Keyboard-switch life test
Electrostatic discharge immunity test
Spillage test
Software
Norton AntiVirus™
Adobe Acrobat® Reader™
Cyberlink PowerDVD®
NTI® CD Maker™
Acer Launch Manager
Acer eManager
Acer System Recovery CD
Acer GridVista (on 15.4" Widescreen models only)
Options
Memory expansion modules
Additional battery
Additional AC adapter
Certifications
DMI 2.0
ACPI
Mobile PC2001
CCX
Wi-Fi®
er zijn nouwlijks reviews over kan iemand zijn ervaringen posten
[ Voor 95% gewijzigd door Verwijderd op 01-06-2005 21:57 ]
  • Ghannes
  • Laatst online: 09-10 08:37
cool?
  • .NCK
  • Laatst online: 14-10 22:28
Uhm, op de acer site zie ik staan dat hij met een nvidia gefore go 6200 chip uitgerust kan worden maar standaard maakt hij dus gebruik van de grafische mogelijkheden van de intel chip.
