Benchmark Turion64 vs. P-M vs. Athlon64
  • 221 views sinds 30-01-2008
  • Polster
  • Laatst online: 21:59
Ik kwam een interresant artikel tegen op GamePC.com waarin de Turion64 tegenover een Pentium-M en Athlon 64 wordt gezet.
Prestaties van de Turion zijn redelijk goed maar de P-M lijkt toch op veel terreinen nog beter te presteren.
Paar quotes uit de conclusie:
The Turion64, for the most part, gives nearly identical performance per clock compared to AMD’s Socket-754 Athlon64 processors.
The Turion64’s low power consumption and heat production attributes finally give AMD a viable competitor to Intel’s Pentium-M processor, which has dominated the mobile arena with its efficient architecture. Battery life between Turion64 and Pentium-M systems should be very similar, assuming both mobile systems are equipped with similar hardware and batteries. While the Pentium-M delivers better performance per clock over the Turion64, the Turion64 does have some fairly significant features which should not be overlooked. The Turion64 has an integrated memory controller, for smoother application performance, in addition to DDR-400 memory support (opposed to DDR-333). The Turion64 also has the ability to execute 64-bit code, whereas the Pentium-M does not. One could pick up a Turion64 for a low-power, ultra-portable Windows XP X64 Edition 64-bit mobile platform, whereas the Pentium-M is stuck in 32-bit land at this time, and will likely continue to stay here until mid-2006 at the earliest.
The Turion64 certainly delivers for the mobile arena, and will give finally AMD a viable candidate for the thin-and-light notebook market. Honestly though, I’m a bit under whelmed by the performance of our first generation Turion64 processors, especially in comparison to Intel’s latest generation Pentium-M chips. If AMD is able to push out another clock speed boost or two without pushing up power levels, they should be able to give Intel’s top Pentium-M chips a run for their money.
Benchmark resultaten zijn te vinden in het artikel.
  • ACM
ACM
Software Architect
Werkt hier
Ik mis alleen wel een prijs-performance indicatie, als de turion aanzienlijk goedkoper is dan de P-M voor vergelijkbare kloksnelheden is het performanceverschil veel minder interessant.
Sowieso is bij laptops met dit soort processoren de batterijlevensduur, formaat en gewicht vaak belangrijker dan de pure performance :)
  • pierre-oord
  • Laatst online: 16-08 20:53
Wat ik even vreemd vind: Ik dacht dat de 754 CPU's geen memory controller hadden, en dat alleen de 939 cpu's dat hebben. Toch lijkt het erop dat de turion wel een memory controller heeft, ik geloof dat op deze asus laptop ook 2 geheugen bankjeszitten speciaal voor dual channel. Beetje vreemd, want die extra pinnen waren toch nodig voor het geheugen?
Ondernemer in tech (oud LOQED.com, nu UpToMore.com)
  • mad_max234
  • Laatst online: 06-12-2025
mad_max234
AMD Athlon II M320
pierre-oord schreef op dinsdag 31 mei 2005 @ 11:26:
754cpu's hebben ook een mem. controller, maar de 939 heeft deul-channel geheugen en de 754 niet.
[ Voor 15% gewijzigd door mad_max234 op 31-05-2005 11:39 ]
  • DP Kunst
  • Laatst online: 22:34
maarre, wanneer komen die dingen nou een btj op de markt. k heb als t goed is volgend jaar een laptop nodig voor mn opleiding en k wil toch t liefst AMD. de enige die nu een turion heeft is de acer ferrari 4000, maar die is nog nergens te vinde.
enne, die turion heeft dus socket 754, is het dan ook mogelijk om die op een gewoon desktop moederbord met socket 754 te zetten met een eventuele bios update ?
Mijn nieuwe portfolio (Under Construction) | Benieuwd wat Solar Team Twente gaat doen?
  • Pubbert
  • Laatst online: 08-09 09:39
Pubbert
random gestoord
Ergens in Duitsland zijn ook PowerLine notebooks met Turions te krijgen zover ik me niet vergis.
In de pricewatch staan 2 Acer aspires met een turion.
DaNiEl KuNsT schreef op dinsdag 31 mei 2005 @ 11:42:
Of je kijkt even verder: ACER Aspire 5024WLMi
  • Mr_Groovy
  • Laatst online: 02-12-2021
Mr_Groovy
Designlapp
Het is heel leuk wat de turion KAN doen voor je, alleen 1 probleem. Al de laptops die ik met een turion heb gezien zijn met a) een laag resolutie scherm :r , en b) met een crappy video kaart. }:O
De acer ferrari 4000 heeft dan wel een X700 128mb, maar ik zou liever een nvidia 6600 of 6800 go willen zien. ( te minste upgradeble, en pixelshader 3.0, betere open gl ondersteuning voor prof. programma's zoals maya of autocad.)
Dus mijn keuze gaat nog steeds uit naar de Inspiron 9300 ( met wuxga, en 6800 go). Ik denk niet dat ms zo snel 32-bit cpu ondersteuning laat vallen ( ook niet in longhorn, aan gezien 90% van de pc's een 32 bit proc hebben). :O .
Just my 2 cents
Macbook Pro 15" Late 2013, iPhone 7+ 128gb, iPad Pro, Canon M3, Tamron 18-200, Canon 22 @2.0, Canon 11 -22, Nintendo Switch
  • theroman
  • Laatst online: 30-06 17:41
op notebooksbilliger.de staat sinds kort ook de ASUS A6K met Turion en GO 6200
Mja, dan heb je het over videokaarten :)
Dit is vergelijkbaar met een? X300? Iig on-board shit.
