Java Paint Probleem
  • 47 views sinds 30-01-2008
Ik kom niet uit de volgende code:
Het is de bedoeling dat in de subklasse kleur de methode draw hergedefinieerd wordt met de kleur die opgegeven wordt in het Jmenu.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
//Kleur.java
import java.awt.*;
import java.io.*;
public class Kleur extends Line {
private String kleur;
public void draw(Graphics g){
    g.setColor(Color.RED);
    g.drawLine(p1.x, p1.y,p2.x, p2.y);
[i]//Line.java[/i]
import java.awt.*;
import java.io.*;
public class Line implements Serializable {
  public Point p1;
  public Point p2;
  public Line() {
    p1 = new Point();
    p2 = new Point();
  public Line(Point a, Point b) {
    p1 = new Point(a);
    p2 = new Point(b);
  public void draw(Graphics g) {
    g.drawLine(p1.x, p1.y, p2.x, p2.y);
//Main.java
public class Main {
  public static void main(String arg[]) {
    new MyFrame();
//MyFrame.java
import java.awt.*;
import javax.swing.*;
import java.awt.event.*;
import java.io.*;
public class MyFrame extends JFrame {
  public MyFrame() {
    getContentPane().add(new PaintPanel2(),
    BorderLayout.CENTER);
    setSize(300, 300);
    setTitle("PaintJava");
    setDefaultCloseOperation(EXIT_ON_CLOSE);
    JMenuBar mb = new JMenuBar();
    setJMenuBar(mb);
    JMenu colMenu = new JMenu("Kleur");
    mb.add(colMenu);
    final JRadioButtonMenuItem rood = new JRadioButtonMenuItem("Rood");
    final JRadioButtonMenuItem geel = new JRadioButtonMenuItem("Geel");
    final JRadioButtonMenuItem groen = new JRadioButtonMenuItem("Groen");
    final JRadioButtonMenuItem blauw = new JRadioButtonMenuItem("Blauw");
    final JRadioButtonMenuItem zwart = new JRadioButtonMenuItem("Zwart");
    ButtonGroup g = new ButtonGroup();
    g.add(rood);
    g.add(geel);
    g.add(groen);
    g.add(blauw);
    g.add(zwart);
   colMenu.add(rood);
   colMenu.add(geel);
   colMenu.add(groen);
   colMenu.add(blauw);
   colMenu.add(zwart);
ActionListener al = new ActionListener() {
      public void actionPerformed(ActionEvent e){
          if (e.getSource() == rood){
            //g.setColor(Color.BLUE);
          if(e.getSource() == geel){
          if(e.getSource() == groen){
          if(e.getSource() == blauw){
          if(e.getSource() == zwart){
       rood.addActionListener(al);
       geel.addActionListener(al);
       groen.addActionListener(al);
       blauw.addActionListener(al);
       zwart.addActionListener(al);
    setVisible(true);
//PaintPanel2.java
import java.awt.*;
import java.util.*;
public class PaintPanel2 extends JPanel {
  private Vector lines = new Vector();
  private Line newL = null;
  private Graphics g;
  public PaintPanel2() {
    setBackground(Color.WHITE);
    addMouseListener(ml);
    addMouseMotionListener(mml);
  public void paintComponent(Graphics g) {
    super.paintComponent(g);
    ListIterator i = lines.listIterator();
    while (i.hasNext()) {
     ((Line)i.next()).draw(g);
MouseListener ml = new MouseAdapter() {
    public void mousePressed(MouseEvent e) {
      if (newL == null) {
        newL = new Line(e.getPoint(), e.getPoint());
        g = getGraphics();
        g.setXORMode(getBackground());
        newL.draw(g);
    public void mouseReleased(MouseEvent e) {
      if (newL != null) {
        newL.p2 = e.getPoint();
        lines.add(newL);
        g.setPaintMode();
        newL.draw(g);
      newL = null;
  MouseMotionListener mml = new MouseMotionAdapter() {
    public void mouseDragged(MouseEvent e) {
      if (newL != null) {
        newL.draw(g);
        newL.draw(g);
Please kan iemand mij helpen
EN JA IK HEB AL GEGOOGLED.
Maar ik kom er niet uit
Alvast bedankt
Greetz,
Tha Skywalker
[ Voor 4% gewijzigd door Verwijderd op 24-05-2005 09:58 ]
  • ThunderNet
  • Laatst online: 15:10
ThunderNet
Flits!
Je moet je code even tussen [ code ] [ /code ] tags zetten, wordt het een stuk leesbaarder van.
Deze moet je juist invullen?
Hier laat je ze leeg, het is voor mij poosje geleden dat java maar volgens mij zit hier je probleem :)
Heb je liever vooraf, of achteraf, dat ik zeg dat ik geen flauw idee heb wat ik doe?
Ze zijn leeg omdat ik niet precies weet wat ertussen moet.
           Kleur.g.setColor(Color.BLUE);
De code hierboven heb ik ingeklopt maar dan geeft ie :
MyFrame.java:46: cannot resolve symbol
symbol : variable g
deze error
[ Voor 72% gewijzigd door Verwijderd op 24-05-2005 10:13 ]
  • bigbeng
  • Laatst online: 26-11-2021
Misschien een tikje bot, maar zou je niet eens de Swing Tutorial gaan doorwerken? Hoe kun je klasses gaan overerven als je de parent klasse niet eens kent? Je mist blijkbaar een bepaalde basiskennis die je eerst zult moeten opdoen. Volgens mij staat in de FAQ daar ook een opmerking over.
  • whoami
  • Laatst online: 13:30
Ehm, het is niet de bedoeling dat jij anderen jouw code laat debuggen.
Je post hier een hele lap code, met een minieme omschrijving v/h probleem; dat is nu ook niet de bedoeling.
Het is de bedoeling dat je zelf eens een en ander uitzoekt, ipv zomaar je code hier neer te kwakken en gewoon zeggen '(ik kom er niet uit'.
Wat heb je al geprobeerd ? Wat lukt er niet ? Welke foutmelding krijg je, of welke onverwachte resultaten krijg je ?
Debuggen is iets wat je zelf moet doen.
Mag ik je trouwens ook eens op onze quickstart wijzen.
[ Voor 13% gewijzigd door whoami op 24-05-2005 10:30 ]
https://fgheysels.github.io/
