Suse 93 installeren vanaf harde schijf ipv (opstart)DVD ...
  • rschu68
  • Laatst online: 08-09 13:35
k heb Suse92 geinstalleerd staan en heb net de iso (7 - 8 GB) van 9.3 binnen.
Omdat ik liever (nog) niet een DoubleLayer DVD wil branden vraag ik me af hoe ik eventueel kan upgraden/installeren van versie 9.2 naar 9.3 (met behulp van de gedownloade iso !)
Wie zou me op de juiste weg kunnen helpen ?
(r.schuurmans [at] gmail [dot]com ; msn = rschu68 [at] yahoo [dot] com
Ik had al iets gevonden met (maar dat begreep ik niet helemaal).... :
> > Second, can I install SuSE 9 from loop-mounted DVD disk images, or in
> > some other way directly from hard drives within the existing installation?
> > I don't have a floppy or CD/DVD drive on this unit, though I could plug
> > one in for this purpose.
> On my Shuttle AMD64 Board AN5OR I did create a separate partition
> /dev/hde11 and mounts this to directory /local.
> Then I did copy the the two DVD's to a local partition directory on my
> SATA harddisk, for instance: /local/install/SuSE_90/DVD1 and .../DVD2.
> The starting point for installation is then the mounted partition
> /dev/hde11 on directory /local with directory (absolute path)
> and not the CDROM device.
> You can copy the DVD's via network connection from another computer.
> Then you can install always again and again from harddisk directly.
> This partition you can mount as installation source from any running
> SuSE-System.
> The next is to configure the booting maschine for the first setup from
> harddisk and not CDROM, DVD or floppy.
> My idea is, than they can edit a additional entry in existing GRUB
> installation on harddisk.
> I think, you can add following lines in /boot/grub/menu.lst
> if booting device is /dev/hde13.
The booting device is /dev/hde11 (/local).
> title Installation (initial from harddisk)
> kernel (hd0,12)/linux ramdisk_size=65536 splash=silent manual=1 showopts
> initrd (hd0,12)/initrd
I forgot the path's, but following works for my maschine:
kernel (hd0,10)/install/SuSE_90/DVD1/boot/loader/linux
initrd (hd0,10)/install/SuSE_90/DVD1/boot/loader/initrd
The installation path is then "install/SuSE_90/DVD1".
Additional can you start the rescue system if you create a new
entry and then replace the option manual=1 through rescue=1.
  • cool_zero
  • Laatst online: 08-07 21:36
Als je iso9660 en loop in je kernel/als modules hebt geladen kun je de iso gewoon mounten:
mount -r -t iso9660 -o loop /path/to/image.iso /mnt/hd
Je moet dan alleen nog de installantie starten en dan doen ze hierboven door grub aan te passen zodat die vanaf de dvd locatie opstart. Maar ik heb geen ervaring met de suse setup/install/upgrade dus meer dan dat kan ik er ook niet over zeggen.
  • rschu68
Uitleindelijk mijn brander (DELL6000-sony, DVD_RW= Sony D56A) geflash't:
tip: Firmware DVD-brander, D56A -> SOSW-852S
  • alt-92
alt-92
ye olde farte
remke schreef op vrijdag 13 mei 2005 @ 16:36:
In het belang van forum survival:
Hiermee haal je natuurlijk het hele idee van op een forum je vraag te posten onderuit he.
Hier posten == hier antwoord krijgen, en niet per mail. Schrijf je dan in op een mailinglist in plaats van een forum.
[ Voor 12% gewijzigd door alt-92 op 15-05-2005 19:17 ]
  • rschu68
Je hebt helemaal gelijk ... sorry
