[ASP.NET] Opbouwen tabel gaat verkeerd
  • 37 views sinds 30-01-2008
Ik heb de fout zelf al gevonden! Na langetijd staren zag ik dat ik in de for each next loop die genest is in de andere de tablerow van de andere blijf gebruiken. Ik heb na het plakken en knippen van stukken code niet alles goed aangepast.
Het is in ieder geval opgelost.
Bedankt voor je interesse in dit topic
Om maar met de desbreffende code in huis te vallen:
Visual Basic .NET:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
Dim dsCategories As New DataSet
        dsCategories = Forum.GetCategories()
        For Each Category As DataRow In dsCategories.Tables(0).Rows
            Dim RowCategory As New TableRow
            RowCategory.BorderWidth = System.Web.UI.WebControls.Unit.Pixel(1)
            Dim CellCategoryName As New TableCell
            CellCategoryName.BorderColor = System.Drawing.Color.DarkBlue
            CellCategoryName.BackColor = System.Drawing.Color.LightBlue
            Dim CellDeleteCategory As New TableCell
            CellDeleteCategory.BorderColor = System.Drawing.Color.DarkBlue
            CellDeleteCategory.BackColor = System.Drawing.Color.LightGray
            Dim CellEditCategory As New TableCell
            CellEditCategory.BorderColor = System.Drawing.Color.DarkBlue
            CellEditCategory.BackColor = System.Drawing.Color.LightGray
            CellCategoryName.Text = Category("CategoryName")
            CellDeleteCategory.Text = "<a href=""ManageForums.aspx?Action=DeleteCategory&CategoryID=" & Category("CategoryID") & """> [img]""images/deletesmall.gif""></a>"
[/img] [img]""images/controlpanelsmall.gif""></a[/img]"
            RowCategory.Cells.Add(CellCategoryName)
            RowCategory.Cells.Add(CellDeleteCategory)
            RowCategory.Cells.Add(CellEditCategory)
            Table1.Rows.Add(RowCategory)
            Dim dsForums As New DataSet
            dsForums = Forum.GetForums(Category("CategoryID"))
            For Each Forum As DataRow In dsForums.Tables(0).Rows
                Dim RowForum As New TableRow
                RowForum.BorderWidth = System.Web.UI.WebControls.Unit.Pixel(1)
                Dim CellForumName As New TableCell
                CellForumName.BorderColor = System.Drawing.Color.DarkGreen
                CellForumName.BackColor = System.Drawing.Color.LightGreen
                CellForumName.Text = vbTab & Forum("ForumName")
                Dim CellDeleteForum As New TableCell
                CellDeleteForum.BorderColor = System.Drawing.Color.DarkBlue
                CellDeleteForum.BackColor = System.Drawing.Color.LightGray
                Dim CellEditForum As New TableCell
                CellEditForum.BorderColor = System.Drawing.Color.DarkBlue
                CellEditForum.BackColor = System.Drawing.Color.LightGray
                CellDeleteCategory.Text = "<a href=""ManageForums.aspx?Action=DeleteForum&ForumID=" & Forum("ForumID") & """> [img]""images/deletesmall.gif""></a>"
                RowCategory.Cells.Add(CellDeleteForum)
                RowCategory.Cells.Add(CellEditForum)
            Next
        Next
In code hierboven bouw ik een tabel op. De tabel moet een forum weergegeven. Categories en daarin zijn forums gehangen. In de eerste for each next haal ik de categorien op en schrijf ik deze naar een tabel door voor elke categorie een datatrow toe te voegen. In deze for each next om de Cateories op te halen, haal ik de desbetreffende Forums op. Dit doe ik door in de for each next loop van de Categories een 2de for each next loop te nesten die de forums ophaalt die bij de Categories haalt. Dit gaat op dezelfde manier door een datarow toe te voegen aan de tabel.
Het probleem is dat hij als eerste een tablerow naar de pagina schrijft die een forum bevat. Hierdoor is de tabellayout naar de knoppen en staat alles verkeerd. Hoe kan dit? Ik maak toch eerst de tablerow voor de categorie aan?
[ Voor 12% gewijzigd door Verwijderd op 11-05-2005 16:00 ]
  • gorgi_19
  • Laatst online: 09-10 17:28
gorgi_19
Kruimeltjes zijn weer op :9
Dan kan deze ook wel weer dicht. :)
Digitaal onderwijsmateriaal, leermateriaal voor hbo
