een tijdje geleden begon ik met zoeken naar een ideale DVD Speler met heel veel mogelijkheden, zoals HDTV, netwerk..
Vandaag vond ik ergens op web een mooie DVD speler: Momitsu V880N.
V880N Specifications
European Version Specs! (multi-region, scart)
Model Name
DVD-V880N
Support Media
Compatible with DVD, DVD-R, DVD+R, DVD-RW, DVD+RW, VCD, SVCD, CD-R, CD-RW, CD-DA, CDI-digital, MP3 ISO, MP4 ISO
Support Video Format
MPEG1, MPEG2, MPEG4 (AVI), JPEG (JPG)
Support Audio Format
MPEG 1, LAYER 1, LAYER 2, MPEG 3
TV System
NTSC/PAL
Audio System
2 Channels
5.1 Channels Dolby Digital AC-3 and DTS output
Audio DAC
96KHz/24-bit
Video D/A Converter
10 bit
Maximum DVI Resolutions
1920x1080
Video Output Terminals
NTSC/PAL 4:3, 16:9 Progressive Scan
1x Composite RCA output
1x S-Video
1x DVI-I supports 480p, 720p, 1080i output (also 50Hz)
1x Component (Y/Pb/Pr) , support 480p, 720p, 1080i output
1x SCART output
Video Input Terminals (Optional)
S-Video
Component (Y/Pb/Pr)
Audio Output Terminals
1x Built-in Headphone output with volume control
1x Coaxial output
1x Optical digital output
2x Stereo audio RCA output
Network Terminals
1x 100BASE-TX/10BASE-T (RJ-45)
1x PCMCIA expansion slot
supports wireless 802.11b network (card not included)
Support Format via Ethernet
• Video-on-demand supporting
- MPEG 1 VCD format (1150Kbps CBR) (.mpg, .mpe, .mpeg, .dat, .m1v)
- MPEG 2 up to 9Mbps (.mpg, .mpe, .mpeg, .m2v, .vob, .vro)
- MPEG 4 (OpenDivX, XviD, RMP4) (.m4v, .avi, .divx, .xvid, .rmp4, .mov, .mp4)
- AVI audio codec: MP3, AC3, PCM, WMA, Ogg
- MOV : 3ivX + MP3, 3ivX + PCM, 3ivX + AAC (3ivX converted from supported MPEG 4 video codec using Dr. DivX II for MAC OS)
- MP4 : MP4V + MP4A (AAC) (only support non-hinted MP4)
• Audio-on-demand supporting
- MPEG I Layer 1 (MP1) (.mp1, .mpa)
- MPEG I Layer 2 (MP2) (.mp2)
- MPEG I Layer 3 (MP3) (.mp3)
- Ogg Vorbis (OGG) (.ogg)
- AC3 5.1 (AC3) (.ac3)
- Microsoft PCM Wave (WAV) (.wav)
- Advanced Audio Coding (AAC, ADIF, ADTS) (.aac)
- Apple MPEG4 AAC Audio (M4A) (.m4a)
- Microsoft Windows Media Audio version 1 and version 2 (WMA) (.wma)
• Photo Album (JPEG) with all the supported audio format as background music.
• Internet Radio supporting Shoutcast server MP3 Internet Radio stream.
• Picture-in-Picture (Video in window) feature supported.
• Playback controls: Play/Pause, Go to (seeking), Fast Forward/Rewind, Slow Motion (MPEG 1 and 2 only).
• Audio and Video Playlist supported.
http://www.momitsu.nl/v880n/
Iemand ervaring? Het is wel best duur..
Je kunt em via DVI beamer aansluiten, dus via topkwaliteitskabel naar beamer zonder kwaliteitverlies.
Model Name
DVD-V880N
Support Media
TV System
NTSC/PAL
Audio System
2 Channels
Audio DAC
96KHz/24-bit
Video D/A Converter
10 bit
1920x1080
1x S-Video
1x SCART output
S-Video
Component (Y/Pb/Pr)
1x Coaxial output
Network Terminals
