ppstats wil niet lekker samenwerken met PProxy
Hee
Ik heb PProxy draaien, perfect doet gewoon
en ik heb een webservertje draaien met daarop: PPstats..
( http://www.hjsnetworks.com/stats/ )
Nu heb ik al 3uur geleden iets geflusht naar de server..is aangekomen maar komen niet in de stats?!?!
Snap ik niet.. (update van stats staan om de 30 minuten)
Config PProxy:
[KeyServer]
ipaddress=euro.v27.distributed.net
port=2064
connectperiod=600
connectivity=normal
;bindip= ; IP to talk out to keyserver from
;uuehttpmode=0
; 0=normal,1=uue,2=http,3=http+uue
; 4=socks4,5=socks5,6=genproxy,7=genproxy+uue
;httpproxy=wwwproxy.corporation.com
;httpport=8080
;httpid=
[ports]
;listenaddress= ; IP to accept clients on
port=2064
;port2=23 ; must be root for ports < 1000
;port3=80
testport=3064
timeout=30
[console]
logfileconsole=log_
logfileconsolerotation=daily
consoleverbosity="general stats keyblock server client buffers timestamp attention errlow errsevere"
timestampflags=130
[rc5-72]
logfilekeyblock=pproxyrc572
logfilekeyblockrotation=daily
minkeysready=100
maxkeysready=200
maxkeysdone=30
[misc]
proxymessage="TEAM EUROPE Proxy! MooHoooH!"
pidfile=rc5desproxy.pid
statusperiod=30
periodicperiod=120
;logfilecompressor=logcompressor.sh
Config ppstats:
#--- Team Information --------------------------------------------------------
Team = "Europe"
TeamHome = "http://www.hjsnetworks.com/stats/"
TeamID = 30564
# Use team logo? Specify full URL to *.gif or *.jpg image.
LogoURL="http://www.providencecatholic.org/fp-austrums/europe%20flag.gif"
#UseLogo = 0 # Do not use team logo.
UseLogo = 1 # Use team logo. Must specify full URL in LogoURL.
#--- Input Options -----------------------------------------------------------
# Logfile name format information. This script does not correctly support
# formats other than YYYYMMDD. The logs in this example are kept in a
# subdirector called "logrc5", which can be configured in the proxy's ini.
# This script does require that daily logfile rotation is enabled. Other
# rotation time periods are not yet supported. LogDir should end in a "/".
LogDir = "d:/proxy/"
LogPre = "pproxyrc572" # For rc5pkeyYYYYMMDD
LogSuf = "log_" # For rc5pkeyYYYYMMDD.log
# The personal proxy can read compressed log files after they have been
# rotated. If you have this proxy option enabled and want to use ppstats,
# configure the following settings. The defaults are for UNIX gzip. Command
# that unzips the logfile to stdout without deleting the file is required.
#ProcessZipLogs = 0 # Ignore zipped log files.
ProcessZipLogs = 1 # Unzip and process all log files.
LogZipSuf = "log.gz" # For rc5pkeyYYYYMMDD.log.gz
LogTmpSuf = "log.tmp" # For rc5pkeyYYYYMMDD.log.tmp
LogDecompressor = "gzip -d -c" # Command line zip decompressor.
# Maximum number of days to read log files. A value of zero means
# read all available log files without limit. A value of 365 would mean
# only read back blocks done in the last year and ignore anything older.
MaxDays = 60
# Set here the correct path to the proxyper.ini file.
# ppstats will try to read options out of it.
ProxyIni = "d:/proxy/proxyper.ini"
#--- Output Options ----------------------------------------------------------
# Full path to output file location. This should end in a "/".
HtmlDir = "f:/www_ftp/stats/"
# Full URL of output web file location. This should end in a "/".
HtmlRoot = "http://www.hjsnetworks.com/stats/"
# Realitive path to icon folder from htmldir and htmlroot. Default should work
# fine for most cases. This should end in a "/". If you haven't copied
# this folder from the zip distribution to your htmldir now is a good time.
IconDir = "icons/"
# All ip addresses from the proxy log files are converted to DNS names and
# then cached for a user defined amount of time. A value of zero means refresh
# on every run. This cache file is saved in your workingdir. If you run
# ppstats on a server with a slow internet connection, use a large cachedays.
CacheFile = "rc5-dns.cache" # DNS cache filename to be created.
CacheDays = 365 # Days to store cache before refreshing.
# GIF based chart options. Be sure to specify the full or relative path to the
# specially compiled GNUplot program with GIF support. Config and data files
# are create by ppstats for you.
GNUPlot = "f:/www_ftp/stats/gnuplot/wgnuplot.exe" # Path to GNUplot executable.
GNUPlotconfig = "gnuplot.ini" # GNUplot config file.
GNUPlotdata = "plot.data" # GNUplot data file.
GNUPlotoutput = "plot.gif" # Output GIF filename.
# The page counter component. See the documentation section above for details
# on how to obtain and use the Count.cgi program. To change the color of the
# displayed count number, change the prgb parameter. Note that you may have to
# do a 'echo "1" > rc5.dat' in your Counter/data folder for this to work. You
# can specify a different hit counter program by changing the counter variable.
UseCounter = 0 # Do not use the hit counter.
#UseCounter = 1 # Use the hit counter.
Counter = "/cgi-bin/Count.cgi?ft=0|tr=1|trgb=000000|srgb=00FF00|prgb=993333|md=8|dd=D|comma=T|df=rc5.dat"
# The By Host information page is sometimes not particularly practical for
# very large teams. You can display this section and ppstats will not record
# blocks submitted by host in any manner. The combined output file size and
# execution time will decrease substantially.
#ShowByHost = 0 # Do not show the By Host section.
ShowByHost = 1 # Show the By Host section.
# It is possible to search for teams and individuals right from the webpage. When
# enabled you will see 2 forms in the menu.
#ShowSearch = 0 # Do not show the search forms.
ShowSearch = 1 # show the search forms.
# An e-mail can been shown via a nickname. D.net also has nicknames on their
# site. The following file contains a mapping between email addresses
# and nicknames.
NameFile = "rc5-name.cache"
# Show a link to the other contest (OGR) in the header
ShowLink = 0 # Don not show the link
#ShowLink = 1 # Show the link in the header
# The location url of the other contest.
# Only needed when ShowLink equals 1
HtmlOtherContest = "/ogr/"
# The day winner page can be displayed using email/nick or
# using hostnames.
DayTopHosts = 0 # Display day winners by email
#DayTopHosts = 1 # Display day winners by hosts
# The entries in the rc5-names.cache and rc5-dns.cache
# can be made CaSe SenSiTiVe by usingthe following option.
PreserveCase = 0 # Display all names/hosts in lowercase
#PreserveCase = 1 # Leave cAsE alone
# This entry let you choose between the am/pm notation and a 24 hour clock on the by_hour page.
AmPm = 0 # 0:00 - 23:59
#AmPm = 1 # 12:00am - 11:59am, 12:00pm - 11:59pm
# Show animated arrows instead of the old frozen one's
#AniArrows = 0 # Frozen arrows
AniArrows = 1 # Animated arrows
# Days to track up/down movement.
MovementDays = 1
# Maximum number of rows to show per category page.
MaxRows = 100
# Number of days to display on the history pages.
DaysHist = 6
# Number of days to display for individual block history.
BlockHistory = 21
# Use header and/or footer banners?
UseHeaderBanner = 0 # Do not use header banner.
#UseHeaderBanner = 1 # Use header banner.
#UseFooterBanner = 0 # Do not use footer banner.
UseFooterBanner = 1 # Use footer banner.
# Consolidate numbers in hosts? ie, host12.myisp.com -> host?.isp.com
# See rc5-domain.cons for a list of domains you wish to manual consolidate.
# See rc5-ip.cons for a list of ip addresses you wish to manual consolidate.
# For instance, an entry in rc5-domain.cons like slashdot.org will consolidate
# the hosts www.slashdot.org, ftp.slashdot.org, and slashdot.org into
# ?.slashdot.org Some more examples are provided. Entries in rc5-domain.cons
# and rc5-ip.cons are processed regardless whether or not ConsHosts is
# enabled. Note that rc5-domain.cons works from the right, rc5-ip.cons the
# left. Note that the last entry in each array does not have a comma after it.
ConsHosts = 0 # Do not consolidate hosts.
#ConsHosts = 1 # Consolidate hosts.
# Last Seen column on the By Hosts page options. Times are defined in
# seconds. Colors are in RGB format, do not append a pound sign "#" to
# the front of the color string. Warning times should be less than
# Critical times. See default settings for examples on how to set these.
#ColorLastSeen = 0 # Do not color last seen.
ColorLastSeen = 1 # Color last seen column.
LastSeenWarningTime = 86400 # 24*60*60 default 24 hours warning time.
LastSeenCriticalTime = 604800 # 7*24*60*60 default 7 days critical time.
LastSeenWarningColor = "888800" # Dark yellow.
LastSeenCriticalColor = "BB0000" # Bright red.
# Category displacement colors for moving up or down in rank since
# yesterday. Defaults are green for up, red for down.
MoveUpColor = "009900" # Green
MoveDownColor = "990000" # Red
# Insert META REFRESH tag in html files? Refresh period in seconds.
#UseMetaRefresh = 0 # Do not use META REFRESH tag.
UseMetaRefresh = 1 # Use META REFRESH tag.
MetaRefreshPeriod = 900 # Refresh after this number of seconds.
Sommige DELEN uit ppstats.ini weggelaten omdat anders te groot word
ALVAST BEDANKT!!!
  • Pim.
  • Registratie: Mei 2001
  • Laatst online: 07-08 06:58
Pim.
Aut viam inveniam, aut faciam
worden de log files van de pproxy aangemaakt ?
krijg je foutmeldingen bij het handmatig runnen van de stats?
krijg je uberhaupt wel output (html files .e.d)
kloppen de paden naar de log files enz enz
"The trouble with quotes from the Internet is that you can never know if they are genuine." - Elvis Presley | Niet met me eens ? DM ME
1. De log files worden gemaakt.. een screenshot:
Afbeeldingslocatie: http://62.100.24.217/screens/1.jpg
2. nope krijg geen foutmeldingen
3. Screenshot Afbeeldingslocatie: http://62.100.24.217/screens/2.jpg
4. Voor mijn gevoel wel, maar ik heb daarom ook de CONFIGS erin geplakt (topic)
  • LXXI
Zo met een paar bevrijdingsbiertjes op... even vluchtig gekeken.
Volgens mij moet de _ weg uit: LogSuf = "log_" in je stats ini
LXXI schreef op donderdag 05 mei 2005 @ 23:34:
Hmm ga het proberen maar in de proxyper.ini staat ook
log_
Maar ik ga het proberen!
Morgen laat ik van me horen!
  • LXXI
Dat LogSuf slaat op dat het de extensie is van de logbestanden die je wilt laten verwerken. Dat log_ in je proxy ini slaat op de console logfiles.
_ in Logsuf weggehaald
en hij doet het }:O }:O }:O }:O
YEAH!
Thanks!!!!
Resultaat:
[ Voor 27% gewijzigd door Verwijderd op 05-05-2005 23:44 ]
