[MRTG] icm mod_watch probleem
  • RutgerLAN
  • Laatst online: 25-08 12:46
Ik heb het volgende probleem. Heb mod_watch (zoals het moet) geinstalleerd, en dit werkt ook. Zodra ik van mod_watch een grafiekje wil laten maken in MRTG gaat het fout:
# mrtg /etc/mrtg/web.cfg
WARNING: Problem with External get '/usr/local/sbin/mod_watch.pl http://www.rutgerlan.com/watch-info': Expected a Number for 'in' but got ''
WARNING: Problem with Externale get '/usr/local/sbin/mod_watch.pl http://www.rutgerlan.com/watch-info': Expected a Number for 'out' but got ''
ERROR: Target[www.rutgerlan.com][_IN_] ' $target->[0]{$mode} ' did not eval into defined data
ERROR: Target[www.rutgerlan.com][_OUT_] ' $target->[0]{$mode} ' did not eval into defined data
De grafiekjes maakt MRTG keurig aan in de workdir. Echter komt er geen informatie (lijnen) in te staan.
De inhoud van web.cfg:
WorkDir: /var/www/stats/mrtg/mod_watch
WriteExpires: Yes
Title[www.rutgerlan.com]: www.rutgerlan.com Data Traffic
Target[www.rutgerlan.com]: `/usr/local/sbin/mod_watch.pl http://www.rutgerlan.com/watch-info`
MaxBytes[www.rutgerlan.com]: 1250000
PageTop[www.rutgerlan.com]: <h2><a href="http://www.rutgerlan.com/">www.rutgerlan.com</a> Data Traffic</h2>
Inhoud mod_watch.pl:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
#!/usr/bin/perl
# mod_watch.pl
# Interface for Apache mod_watch and MRTG
# Copyright 2001, 2002 by Anthony Howe.  All rights reserved.
# usage: mod_watch.pl [-f a,b] url
# Fetch the current counters associated with the given URL. The URL refers
# to either a virtual host, file owner, or the SERVER.
#       http://www.snert.com/watch-info
#       http://www.snert.com/~achowe/watch-info
#       http://www.snert.com/~SERVER/watch-info
# The mod_watch handler "watch-info" returns a line of plain text
# containing the following space separated fields:
#       ifName ifUptime ifInOctets ifOutOctets ifRequests ifDocuments ifAvgRate ifActive
# This script returns output suitable for MRTG's target script command
# directive: line with the input bytes, line with the output bytes, line
# with the web server uptime, and the target name.
#       Nothing to be configured below this point.
$VERSION = '2.6';
$AUTHOR = 'achowe@snert.com';
use Socket;
use Getopt::Std;
use Sys::Hostname;
use AnyDBM_File;
my $usage = "usage: mod_watch.pl [-f a,b] url\n";
die($usage) unless getopts('f:');
die($usage) unless @ARGV == 1;
#       Open connection to URL.
# Figure out who we have to call.
($host, $port, $path) = ($ARGV[0] =~ m!http://([^:/]+)(?:\:(\d*))?(/.*)!);
$port = 80 unless defined $port;
# Get a socket...
# TODO add Timeout support, eg.
#$sock = IO::Socket::INET->new(PeerAddr => 'www.vhost.com', PeerPort => 'http(80)', Proto => 'tcp', Timeout => 10);
unless (socket(HTTP, PF_INET, SOCK_STREAM, getprotobyname('tcp'))) {
#       print("0\n0\n0\n$host:$port ($!)\n");
        print("\n\n\n$host:$port ($!)\n");
        exit(0);
# ...set socket to be line buffered...
select( (select(HTTP), $| = 1)[0] );
# .. make the connection.
unless (connect(HTTP, sockaddr_in($port, inet_aton($host)))) {
        exit(0);
#       Make the HTTP request.
# Proxy request style.
#print HTTP "GET $ARGV[0] HTTP/1.0\n\n";
print HTTP "GET $path HTTP/1.0\nHost: $host\n\n";
$answer = <HTTP>;
($status, $reason) = ($answer =~ m!HTTP/1.[01] (\d+) (.*)!);
unless ($status == 200) {
#       print("0\n0\n0\n$host:$port ($reason)\n");
        exit(0);
# Discard remaining HTTP headers.
while (<HTTP>) {
        last if /^\s*$/;
#       Parse the information line.
# Field names in order.
@fieldnames = qw(ifName ifUptime ifInOctets ifOutOctets ifRequests ifDocuments ifActive ifOutRate);
# Default fields to return.
($a, $b) = qw(ifInOctets ifOutOctets);
# User wants other fields?
($a, $b) = ($opt_f =~ m!(\w+),(\w+)!) if defined $opt_f;
# Get the information line.
my $line = <HTTP>;
close(HTTP);
# Select the fields to return.
($in, $out) = (0, 0);
#if ($line =~ /^\S+\s\d+\s\d+\s\d+\s\d+\s\d+\s\d+\s\d+/) {
if ($line =~ /^\S+\s\d+\s\d+\s\d+\s\d+\s\d+/) {
        @counters{@fieldnames} = split(/\s+/, $line);
        ($in, $out) = ($counters{$a}, $counters{$b});
#       Write MRTG output.
sub ml_elapsed_time {
        my ($s) = @_;
        my ($d, $h, $m);
        $d = int($s / 86400);
        $s %= 86400;
        $h = int($s / 3600);
        $s %= 3600;
        $m = int($s / 60);
        $s %= 60;
        return sprintf("%lu+%02d:%02d.%02d", $d, $h, $m, $s) if 0 < $d;
        return sprintf("%d:%02d.%02d", $h, $m, $s) if 0 < $h;
        return sprintf("%d.%02d", $m, $s) if 0 < $m;
        return sprintf("%d", $s);
print "$in\n$out\n" . ml_elapsed_time($counters{ifUptime}) . "\n$counters{ifName}\n";
exit 0;
__END__
http://www.rutgerlan.com/watch-info werkt ook wel. Ik snap er niets meer van, waar kan die fout zitten? Iemand een idee :?
OS: Debian 3.0r2
[ Voor 5% gewijzigd door RutgerLAN op 02-05-2005 12:01 ]
  • Oezie Woezie
  • Registratie: December 1999
Oezie Woezie
Pim. is de beste
wat voor een info geeft mod_watch.pl http://www.rutgerlan.com/watch-info terug?
een mooi Tshirt met Pim. is de beste enzo
  • RutgerLAN
www.rutgerlan.com:80 (Bad file descriptor)
  • Oezie Woezie
Oezie Woezie
Pim. is de beste
RutgerLAN schreef op maandag 02 mei 2005 @ 19:11:
met die data kan mrtg niet overweg :). met het openen van de socket gaat het denk ik fout.(hier werkt het zelfde script wel, Fedora Core 3).
ik heb zelf ook iets gemaakt wat mod_watch uitleest, alleen ik heb het iets anders gedaan. ik maak gebruik van "use LWP::UserAgent;"
$ua = new LWP::UserAgent;
$ua->agent('Network Status/0.4; <erik@oezie.org>; ');
$ua->timeout(30);
$req = new HTTP::Request(GET => $ARGV[0]);
$res = $ua->request($req);
if($res->is_success)
##  print $res->content;
  ($ifName,$ifUptime,$ifInOctets,$ifOutOctets,$ifRequests,$ifDocuments,$ifActive,$ifOutRate) = split(/ /,$res->content);
//verdere dingen die je wil doen, voor mrtg print $variable die je wil.
mijn code is hier te vinden, nog lang niet perfect, maar misschien kan je er mee verder. http://haas.oezie.org/rrd/apache/apache.pl
geeft dit soort resultaat.
Afbeeldingslocatie: http://haas.oezie.org/rrd/apache/streetdance.gertje.org/traffic-year.png
Afbeeldingslocatie: http://haas.oezie.org/rrd/apache/streetdance.gertje.org/apache-year.png
  • RutgerLAN
Bedankt Erik, hier ga ik zekers wat mee doen! ;-)
